Sponsored by The Tire Rack
Old 02-16-2010, 10:47 PM   #1
Bdubbin
My Ride: clean e46
snow tire ?
I'm running 225-45-17 Bridgestone Blizzaks in the rear. I have been noticing on the highway its been wandering a bit after 70 and any quick lane change or corner it goes allover the place. Is it possible that the tires would be causing this? i checked the toe on the rear and front and theyre both to spec
Bdubbin is offline   Reply With Quote
Old 02-17-2010, 12:21 AM   #2
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Hard to say without knowing your car (your "my ride" is lacking") and standard wheel/tires setup so this is a guess. If you're running low profiles that doesn't seem unreasonable, going from my awesome Nitto NT05 (http://forum.e46fanatics.com/showthread.php?t=709963) to my blizzak 17s its not the same car, under acceleration its all over the place. That being said it snowed 4" today and I was able to drive home, where my Nittos I would have been walking.
Summer tires/winter tires is the way to go, can't believe I didn't have this before. Its really the best of both worlds.
Tim
tim330i is offline   Reply With Quote
Old 02-17-2010, 08:23 AM   #3
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Please tell me you aren't running two snow tires in the rear only...if so, that is certainly your problem!
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
