#1 |
Request for a picture of fan clutch tool
i was gonna make my own tool but was wondering if someone can provide a scan or a picture with some measurements of the holes that hold the fan. i know one is 32 mm but what is the one with the nuts like this picture
#2 |
just a suggestion.. it's on ebay for about $30..good luck
#3 |
Just out of curiosity doesn't the e46 use an electric fan? I know my e30 uses a viscous clutch I just replaced it, but my 325ci has an electric fan, and no I'm not talking about the aux fan.
![]() "Screwed" by ESS Tuning |
#4 |
the automatic e46 uses a mechanical and the manuals have an electric.
i already have some spare sheet metal at home so i was going to try to diy |
#5 |
The top tool you have pictured has the notch to clear the shaft and the holes/slots to fit over a pair of the bolt heads so the pulley doesn't turn, allowing you to turn the 32mm nut on the fan clutch. The same thing can be achieved with a long screwdriver shaft, but not as elegantly!
John in VA
'03 530i '00 328i '86 535i '85 535i '85 325e - RIP '74 2002tii |
