Old 02-18-2010, 02:38 PM   #1
slickware
My Ride: 323i
EVAP LDP reed switch doesn't open?
I searched forums but I only found a few posts about this particular issue... I only have one code getting thrown. It IS triggering a CEL. Peake tool says "EVAP LDP reed switch doesn't open".
What's this mean? I did just have my charcoal canister replaced - could I have a loose connection on something?
Oddly enough, this code just started happening after I did all my VANOS repair work - but the charcoal cannister was replaced months ago.
I feel like they're related, although I have no idea how they possibly could be.
Any thoughts?
slickware is offline   Reply With Quote
Old 02-19-2010, 11:47 AM   #2
slickware
My Ride: 323i
hmm... bump
I've cleared the CEL and it comes back in a few start cycles.
Old 03-07-2010, 04:08 PM   #3
slickware
My Ride: 323i
last bump... only thing still wrong with my car
Old 03-07-2010, 05:56 PM   #4
hvirani
My Ride: e46 320i
LDP is related to the charcoal cylinder.
Read: http://repairpal.com/evaporative-leak-detection-pump
BMW uses the fuel vapor during startup to richen the air/fuel mix to heat up faster.
hvirani is offline   Reply With Quote
Old 03-08-2010, 08:28 AM   #5
slickware
My Ride: 323i
I get what the LDP system is, but I'm curious as to why the "switch doesn't open"? I just had my whole charcoal canister replaced with a new one.
Does this mean the new canister isn't working correctly?
Is the Leak-Detection *pump* actually IN the charcoal canister, or is it a separate, replaceable, part?
Old 08-04-2010, 01:28 AM   #6
jorg323
My Ride: 1999 323i
Bump on this... same/similar problem here and would like to know if this got solved.
18" Black ASA AR1 Rims | Yokohama Advan S4 Tires | Bilstein Sport Shocks | Eibach Pro-Kit Springs | Brembo Slotted Rotors | 6000k Xenons | 6000k P. Chrom. Angel Eyes | Eagle Eye LED Tail Lights | K&N FIPK CAI | M-Tech II Front Bumper | 35% Tint | Clear Corners | Matte Black Grille
jorg323 is offline   Reply With Quote
Old 08-04-2010, 09:27 AM   #7
slickware
My Ride: 323i
Wouldn't know... I sold the car
Old 08-04-2010, 12:05 PM   #8
jorg323
My Ride: 1999 323i
Haha with the CEL still on? Didn't the buyer have a problem with that?
Old 08-04-2010, 01:09 PM   #9
shanneba
My Ride: 2003 330Ci
Maybe this will help a little - look at pages 17 - 23
http://www.bmwmotorsports.org/BMW_docs/m54x5.pdf
Might be this- I don't know if that was part of what you replaced or not.
http://www.realoem.com/bmw/showparts...20&hg=16&fg=10
20 Leak diagnostic pump 1 09/2001 16137193479
Might also it be related to the purge valve
http://www.realoem.com/bmw/showparts...98&hg=13&fg=15
No. Description Supplement Qty From Up To Part Number
01 FUEL TANK BREATHER VALVE 1 13901433603
Join BMWCCA
Old 08-04-2010, 01:49 PM   #10
slickware
My Ride: 323i
I was upfront about it and explained the research and testing I had done on it thus far. Since the only thing I hadn't replaced was the LDP (charcoal canister), I knocked the price of that repair off the selling price of the car.
Old 11-10-2012, 06:25 PM   #11
onebad328i
My Ride: BMW 328i
e46 8D EVAP LDP reed switch doesn't open
I have a peak tool from bavarian auto, my car is a 99 bmw 328i, ive basically replaced all the vacumes in the car, and recently did the LDP pump, not the canister, and the ccv and all its hoses, car runs super good, but i get that damn CEL with code 8D EVAP LDP reed switch doesn't open, the only thing that was suggested here and i have not swap its the fuel breather valve, which was suggested here to replace, but i dont know??? i dont just want to keep replacing parts that are not broke! has anyone got a fix on this issue yet??? please help guys i need ur imput... i replaced the pump on the canister and tripple checked the connection and hoses they all look good, i clear the CEL and then 2 or 3 cycles later she comes right back up..... DAMNNNNN it .. HELPPPPP!
onebad328i is offline   Reply With Quote
Old 11-10-2012, 09:24 PM   #12
sidct
My Ride: 2004 330Xi
You need to change fuel breather valve (part number: 13901433603).
sidct is offline   Reply With Quote
Old 11-11-2012, 02:32 PM   #13
onebad328i
My Ride: BMW 328i
well instead of the canister, will go with the breather valve, i hope this ends my nightmare with this car, because even with all the issues at least the car never left me stranded, BMW still is a supercar....
Old 11-17-2012, 05:40 PM   #14
onebad328i
My Ride: BMW 328i
Im in the process of purchasing the fuel breather valve, will see if this is the culprit of the LDP issue and code 8D. I will update after replacing the valve and CEL, crossed fingers....
Old 12-04-2012, 09:07 PM   #15
NFSx328ci
My Ride: TiAg E46
Anything? I just got this code today
My babies; Supercharged 328ci, 2009 Alpine White 135i.
625awhp 99 GSX(SOLD), Straight Piped 2011 Grand Cherokee (SOLD)
NFSx328ci is offline   Reply With Quote
Old 12-05-2012, 05:58 PM   #16
onebad328i
My Ride: BMW 328i
Im fixing to buy the fuel breather valve this week, its a very simple job, the fuel breather valve sits right behind the alternator, but you must check all your vacumes, the lines next to the tank inlet where you pump fuel, you must take the rear passenger tire off and remove the back mudguard and inspect fuel lines back their, then next to it is the LDP canister, and the LDP pump checked the hoses for cracks or looseness, if this does not work then i would go for the fuel breather valve, which is what im going to do this week, the unit is not cheap i think it varies from 80$ to a 100$ after i replace it and clear the light ill give it a few days and post the updates of the outcome, you could also do a smoke test, thats the fastes route to find the leak, the problem with this code is that two times during the cycle of the motor while the car is running the ECU will run the Leak detection diagnosis test on the car, this trys to pressurize the fuel tank, if theirs a leak the leak detection pump will continue to pump air to pressurize the system until the ECU tells it to stop, but if this continues to happen eventually it burns the pump or damages the canister, thats why if u got the money do a smok test and that way dont pay for parts that dont need replacement, good luck ill keep u guys posted on the outcome, wish me luck hehehehe....
Old 12-05-2012, 06:01 PM   #17
onebad328i
My Ride: BMW 328i
OHH i forgot to mentioned the unit price, 80 to a 100 that is online, through ebay or other websites, IF you go to the STEALERSHIP, get ready to be raped.....
Old 12-05-2012, 07:46 PM   #18
NFSx328ci
My Ride: TiAg E46
Thanks for keeping us updated. I'm gonna try and work mine aswell
Old 12-12-2012, 10:04 PM   #19
PalBmw
My Ride: 328i
I am having the same issue. Will wait to see if you can resolve it. Also would like to know if this will have an impact on the performance of the car.
PalBmw is offline   Reply With Quote
Old 12-14-2012, 08:33 AM   #20
onebad328i
My Ride: BMW 328i
Evap LDP swapping fuel breather valve!
This does not affects the performance of the car, at least not on mine, i can imagine this only affects the car if you have vacume leaks, but if the pump is bad or the fuel breather valve is bad the vacumes are still sealed wich after the computer runs its test, is pretty much useless, but anyways i will be replacing the fuel breather valve this week, ill be ordering it today, lets hope this fixes this damn problem, because this issue has various variants that can be causing this problem.
