Old 06-12-2010, 12:56 PM   #281
kai-
My Ride: three two slow
is it possible to use an adaptor of sorts to fit this on a non 330?
or would you need a proper tailor made one? if so, any plans on a boot for non 330's?
kai- is offline   Reply With Quote
Old 06-15-2010, 01:34 PM   #282
cabl3i
My Ride: 03 330i ZHP
So I installed this yesterday, the hardest part was getting the clamp to fit flush over the very edge of the boot right at the throttle body. I kept tightening the boot only. I was surprised to find a gaping hole in the smaller secondary hose that connects to the engine block :S
Now I know where those lean bank codes were coming from. Car runs great now...will
post pics of my engine bay once I dust it off.
cabl3i is offline   Reply With Quote
Old 06-16-2010, 03:19 PM   #283
cabl3i
On a side note, did anyone else have to modify the upper intake boot? In spite of how far in to the throttle body I pushed in the lower intake boot, the fitment was still so off that there was simply no way of getting the MAF in the intake box (end section of boot seemed to be too long).
I ended up having to cut off about 1.5cm from the end of the upper intake boot where the MAF is held...the cut also had to be angled downwards as the boot was jutting the MAF upwards instead of straight. In the end I got it to fit perfectly with hose clamps holding everything tightly...just thought I'd get that out there in case anyone else is having the same problem as me.
Old 06-16-2010, 03:27 PM   #284
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Nope, fit perfectly!
Old 06-16-2010, 05:05 PM   #285
cabl3i
Damn, I'm pretty sure I pushed the lower boot as far in as I could over the TB...even then, pushing it further in would result in lateral relocation of the upper boot, not the depth.
Strange...in any case, that nasty whistle is gone now and my car seems to respond better...placebo effect maybe? I dunno, but I do sleep better at night now.
Old 06-18-2010, 06:47 AM   #286
Hageee
My Ride: E46 330xiA
Send a message via ICQ to Hageee
Can i buy one set for my 330i, in germany?
Hageee is offline   Reply With Quote
Old 06-28-2010, 05:41 AM   #287
Hageee
My Ride: E46 330xiA
No answer?
Old 06-28-2010, 09:04 AM   #288
aggieE46
Keep it clean
aggieE46's Avatar
Guys, you have to buy these straight from Stett.
Old 07-29-2010, 11:01 AM   #289
kai-
http://forum.e46fanatics.com/showthr...2#post12052302
for any 323/325/328 who want these too.
