Sponsored by The Tire Rack
Old 02-19-2010, 08:09 PM   #1
BioBa
My Ride: Evoque 2door
HELP - 18" rims to fit AP big brake kits???
I am having a hard time finding 18" rims to fit my M3 E46 fitted with 14" rotor AP brake (six caliper) kit. I want to keep the staggered set up. I am pretty sure the BBS Ch fit but I do not want to spend that much. Can anybody help? What 18" rims are you using on your track set up with the big brakes?
BioBa is offline   Reply With Quote
Old 02-19-2010, 08:50 PM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
The APEX ARC-8 should fit. The 18" group buy is over but they might still have something in stock for you.
http://forum.e46fanatics.com/showthread.php?t=711903
Old 02-19-2010, 10:38 PM   #3
BioBa
Yes they look good!!! I have contacted them to make sure they will fit.
What offset do you guys use in the rear? Factory wheel is +22.
