Old 02-23-2010, 01:20 AM   #1
khbiesfd
My Ride: 2000 BMW 323ci
Radiator help
My 323ci has a leak in the radiator. I want to get a performance radiator but the only one i saw was about 500 bucks. I was wondering if the radiators on the more powerful models are bigger or better cooling such as 325, 328, and 330. Would any of the radiators out of these cars fit into mine and be beneficial? Thanks.
khbiesfd is offline   Reply With Quote
Old 02-24-2010, 12:53 AM   #2
khbiesfd
hellooooooooo?
Old 02-25-2010, 01:34 PM   #3
khbiesfd
can anybody help?
Old 02-25-2010, 10:47 PM   #4
khbiesfd
Bump!!!!
Old 02-25-2010, 11:57 PM   #5
///Orient3
My Ride: can't be defined
I'm just curious, did you try looking up part numbers, or searching? They are all the same. You would be better off upgrading to a stewart water pump. There are people with race cars around here who run the stock radiator. Mr. Shelley is one of them, I believe. Research, research, research. Good luck replacing your radiator, should a relatively easy diy.
[url=http://photos.e46fanatics.com/showphoto.php/photo/90077]
///Orient3 is offline   Reply With Quote
Old 02-26-2010, 07:45 AM   #6
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Your only bolt on option that I know of is Zionsville Autosport which costs $1200.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
