Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 136 votes, 4.94 average.
Old 03-22-2010, 10:56 PM   #181
doubledees
My Ride: 2005 M3 Jet Black
Hey mass,
Is there a way to get the radio to not scan stations everytime the engine is turned off and turned on again. I get that everytime I hop in the car and have to press the right knob to get it to stop scanning. I don't have it on auto scan so I'm not sure what the problem is.
Also I notice with the SY8 box the steering controls work, I get volume control, picking up the phone if there is incoming but if you end a call the button does not work. the R/T dosen't work. The button that switches stations work but I have yet to figure out how to get it to preset stations once you press up or down, at this moment it just goes by .1 increments.
On CD mode, it'll skip to the next track and back so that is fine. Are you getting the same symptoms as I?
doubledees is offline   Reply With Quote
Old 03-23-2010, 11:06 AM   #182
cdm3
My Ride: 2005 m3 Vert
Turn off TA and I think TF functions and it will stop automatic seek... The only functions I have on steering wheel are volume but I have not tried pickup as i push the phone button on unit. Next station does not work on mine which is version2
cdm3 is offline   Reply With Quote
Old 03-23-2010, 11:14 AM   #183
NIVO
My Ride: 2004 330Ci ZHP
Send a message via AIM to NIVO
what are the rca voltages?
NIVO is offline   Reply With Quote
Old 03-23-2010, 11:50 AM   #184
mass03m3
My Ride: e46 M3
Originally Posted by doubledees View Post
Hey mass,
turn AF and TA off. Make sure AS is not on to fix scanning problem. I have the sy8 box but my steering wheel controls do not work at all for phone use. My volumecontrol on steering wheel is the only control that works in bt mode. My SWC work in all other modes. Volume works, The radio scan up and down works but does not go to preset channels. it just goes to next available channel. My radio also goes by .1 increments(I think that is a Chineese thing) and cd also goes to next track. Same with ipod up and down buttons on swc go to next or previous track.
mass03m3 is offline   Reply With Quote
Old 03-23-2010, 02:58 PM   #185
cdm3
Anyone have a wiring diagram of the Business CD unit with HK?
Old 03-23-2010, 03:27 PM   #186
mass03m3
My Ride: e46 M3
I am pretty sure you can get it in the back of the bentley service manual. I have the manual but unfortunately I don't have a scanner at the moment. Maybe, Bentley has something online.
This is for 2003 e46 m3:
WIRE COLOR POLARITY LOCATION
Battery RED/WHITE (+) RADIO HARNESS
Accesory VIOLET/WHITE (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Power Antenna WHITE (+) RADIO HARNESS
LF Speaker (+) YELLOW/RED
LF Speaker (-) BROWN/ORANGE
RF Speaker (+) BLACK/RED
RF Speaker (-) BROWN/ORANGE
LR Speaker (+) YELLOW/BLACK
LR Speaker (-) BLACK/ORANGE
RR Speaker (+) BLUE/BLACK
RR Speaker (-) BROWN/ORANGE
Old 03-23-2010, 07:01 PM   #187
doubledees
Thanks i will try that.
Old 03-24-2010, 10:26 AM   #188
cdm3
Thanks Mass03M3! I will look online. Dynavin BBS is asking me for schematics to solve my reset issues indicating my wiring is different and I should switch/swap power wires. I am reluctant to do so....
Old 03-24-2010, 01:08 PM   #189
jeffb325
My Ride: 325ci
you can check this real easy with a test light or a voltmeter.
jeffb325 is offline   Reply With Quote
Old 03-24-2010, 04:16 PM   #190
damills
Modded ///Member
My Ride: 2002 m3 & 2014 650i
radio or vents first
When putting dynavin unit in, which goes in first, radio or vents, just want to clarify?
damills
damills is offline   Reply With Quote
Old 03-24-2010, 04:51 PM   #191
Alex323Ci
My Ride: M3 & 323Ci (sold)
pretty sure it's vents. because the radio mount goes over the vent mount at the top corners.
Old 03-24-2010, 05:51 PM   #192
mass03m3
My Ride: e46 M3
On my car, I had to put the radio in first because the vents didn't line up on the bottom with the rest of the dash. It kind of sucked them in at the bottom. this picture is with vents in first. It might be different on other cars.
Old 03-25-2010, 01:27 AM   #193
doubledees
When I did it, vents came out first then headunit, going back in should be headunit then vents.
Old 03-25-2010, 02:40 AM   #194
Alex323Ci
maybe i'm mistaken then. i've done it like 5 times now recently, but certainly could have forgotten how i did it without seeing it again.
Old 03-25-2010, 08:50 AM   #195
cdm3
Radio first, vents last here..
Old 03-25-2010, 12:34 PM   #196
damills
Modded ///Member
There is a 2"x3" black box with a SY8 on it that plugs into the connector harness. It has a small male jack on the other end, this jack plugs into the female connector coming out of the headunit labeled IR. This is for your steering wheel control. There are a lot of plugs that don't connect to anything if you are not using such things as aftermarket amp, Reverse camera etc.
Looking at the OEM connector before plugging into the dynavin, what is the small female plug at the bottom of the connector, looks like it has a place for 2 of them but on my car there is only one, if directly below that larger holes that plug into the radio. This small plug at the bottom of the OEM connector inside the car plug into the back of the OEM radio but nothing when you plug into the dynavin harness?
If this what you were trying to tell me is that for the OEM radio, that plug at the bottom of the OEM harness inside the car is for steering wheel controls and is replaced with the sys8 box with the dynavin unit?
damills
Old 03-25-2010, 04:31 PM   #197
mass03m3
My Ride: e46 M3
I'll attach a picturefrom dynavin's site.sys8 box is very dark on the right hand side.
Old 03-25-2010, 05:21 PM   #198
damills
Modded ///Member
I see what your saying but on the bottom of my connetor that is inside the BMW that is part of the BMW wiring, that connector, its a femal plug, I have the part at the top of that plug that plugs into the dynavin harness but at the bottom of the wire that comes out of the car (one you have to pull up on to detach from the original radio in the car), at the bottom of that connector is a small plug, could be the difference in the year of our cars if you dont have it??
damills
Old 03-25-2010, 05:48 PM   #199
Alex323Ci
that sounds like(but not sure exactly what part you're trying to say) the section that is for the oem CD changer. which the Dynavin does not support.
Old 03-25-2010, 07:12 PM   #200
mass03m3
My Ride: e46 M3
Yeah, I don't Believe I have that connector. Could be cd changer as I don't have a changer installed. Maybe, someone else can answer this one for you.Here is the back of my cd business deck. Where does it plug in?
Rate This Thread
