Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 136 votes, 4.94 average.
Old 07-27-2010, 09:30 PM   #441
mthreezycrazy
My Ride: ///M3
wow. alright im ganna post new ones in a bit
-Aria
mthreezycrazy is offline   Reply With Quote
Old 07-27-2010, 09:47 PM   #442
m3collins
My Ride: 2002 Carbon Black M3
Looks like you just highlighted the string and pasted. That copies the .... and all which obviously doesn't work.
m3collins is offline   Reply With Quote
Old 07-27-2010, 09:58 PM   #443
mthreezycrazy
My Ride: ///M3
-Aria
Old 07-27-2010, 09:58 PM   #444
mthreezycrazy
My Ride: ///M3
there you go!
-Aria
Old 07-27-2010, 10:07 PM   #445
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
I know I just PMed you but.......a couple questions .....what is the other end of the white wire hooked to??? Have you measured the voltage on the orange wire....what does it read?
also, you are playing with fire going the twist and tape route.....go down to your local auto parts store and pick yourself up a basic wire splice kit and some butt connectors, spend about $30 and re-do all your connections. That tape WILL come off and things will short out at some point in the future and then you will have another whole batch of problems.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 07-27-2010, 10:25 PM   #446
mthreezycrazy
My Ride: ///M3
yea ill do the tape stuff over with the splice kit. the white wire is conneced to another white wire that just goes towards my steering wheel. thats why we did that since we thought it might be something with the steering wheel controls
-Aria
Old 07-27-2010, 10:32 PM   #447
carcus
My Ride: 2006 BMW M5
Wow!!! Looks like you got it to work, but dang.....that is alot of splicing and stuff. I loved that mine was just plug and play.
2006 M5 E60, "Lord Vader" Last real NA M series
German Car Fanatic. Colorado ///M Flight member, BMW CCA member.
carcus is offline   Reply With Quote
Old 07-27-2010, 10:48 PM   #448
mthreezycrazy
My Ride: ///M3
hey collin you have oem nav too right? if so did you buy the fakra cable?
-Aria
Old 07-28-2010, 11:59 AM   #449
m3collins
I am installling now. Have the fakra cable. The big plug in your pic here you have to slide out the blue pieces....they are covering the pins the fakra uses but OEM doesn't.
[img]http://i24.photobucket.com/albums/c28/Aria-Ashir/IMG_0312.jpg[img]
However right off both the Dynavin harness (which I don't use since I have to use the Fakra) and the Fakra there is a little 14 pin connector with only 4 wires/pins being used. They are red, black, yellow, and white (the white is pink on my Fakra). Where does this plug into? I can't find ANYTHING in the trunk that has this. Is this the main power connector?
Old 07-28-2010, 01:20 PM   #450
J&T Distributing
My Ride: BMW
that plugs into the steering wheel interface
Old 07-28-2010, 01:59 PM   #451
mthreezycrazy
My Ride: ///M3
where is the steering wheel interface?? i have been looking for it forever (from the bmw side)
-Aria
Old 07-28-2010, 02:17 PM   #452
m3collins
Its in the trunk. I can't get any freaking sound. I have the harmon kardon system.
Old 07-28-2010, 02:21 PM   #453
mthreezycrazy
My Ride: ///M3
damn looks like im ganna order the fakra then and do this all over
-Aria
Old 07-28-2010, 02:26 PM   #454
m3collins
You still have to somehow get a wire from the trunk to the front. I have no clue why the sys8 box connection is in the back on the Fakra. I can connect the fakra to the sys8 but the sys8 has a headphone jack looking plug and no clue where it goes to.
Old 07-28-2010, 02:27 PM   #455
mthreezycrazy
My Ride: ///M3
yea i was just looking at the picture and realized that. thats a weird design if the whole point of the cable is to be for nav cars
-Aria
Old 07-28-2010, 02:50 PM   #456
J&T Distributing
My Ride: BMW
m3collins, you are confirming something I have suspected but didnt know for sure, you will need an extension to get the "headphone" style plug up to the front......it will then plug into the plug labled "IR IN." You may also need an antenna extension as well, but you would know that better than I would....
Old 07-28-2010, 02:55 PM   #457
mthreezycrazy
My Ride: ///M3
yea thats something i saw with the fakra too when i checked out the picture. only problem is i dont know which part of the harness i took pictures of in the trunk has to do with steering wheel control buttons. if i figure that out then i can route a cable up front from that pin.
-Aria
Old 07-28-2010, 03:00 PM   #458
J&T Distributing
My Ride: BMW
now you are thinking! the steering wheel control pin is in fact in the trunk, I just got off the phone with M3collins, I bet he can tell you which pin it is.
Old 07-28-2010, 03:19 PM   #459
mthreezycrazy
My Ride: ///M3
yea i just talked to him too but he said he doesnt know exactly which part of the rear is harness is for steering wheel control. that part is crucial to figure out. And then i need another cable (not sure what kind) that can just extend to the front, and tap into the sy8 which can then be connected to the ir plug of the unit. just need to find out what cable to use and what pin in the back
-Aria
Old 07-28-2010, 03:29 PM   #460
J&T Distributing
My Ride: BMW
it would just be a single wire from the sy8 white wire back to the trunk to whatever pin the steering wheel button wire is on the oem plug......m3collins mentioned it here....
you are very close to having this figured out!
Rate This Thread
