Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 136 votes, 4.94 average.
Old 03-01-2010, 01:45 AM   #101
jeffb325
My Ride: 325ci
Not for sure as i dont have the dynavin yet but i do have bluetooth in both of my cars. Typicaly both the blutooth device AND the phone have volume controls that are bluetooth specific, are you saying that the dynavin takes on the current volume of whatever you are listening to? Not right but if thats how it is its not that bad, i find myself fidling with the volume on my calls every time anyway as every call is different. Thats not ideal however, hopefully fixable or a settings issue.
jeffb325 is offline   Reply With Quote
Old 03-01-2010, 10:22 AM   #102
mass03m3
My Ride: e46 M3
Line output converter
Ok,
I have installed a line ouput converter(loc) on my Dynavin e46 headunit. And much to my suprise, IT WORKS!!!!!!!!!!!!!!
I was waiting on the PAC oem2 in the mail and ran out of patience. I went down to my local installer and told him my situation and he gave me a 4 channel line level converter made by Neucleus(nc-sc400t). I would probably go with the PAC loc as it has adjustments for line level and the neucleus does not. It said in the Neucleus instructions that this unit is made for Harmon Kardon system. The best part is you can pick a loc up online for way under $50!!!
I no longer have hiss or radio interference in the background. This Definetely makes this dynavin sooo much better. I can also use other settings on the eq such as rock,pop,jazz etc. and I don't get any popping or hiss. It is a very simple install as you Just install it inline on your Dynavin harness speaker outputs. The worst part is you have more wires to shove into the dash.
Many thanks to jeff325 as he is the one who suggested the LOC!!!!
ID:	350406   Click image for larger version
ID:	350407   Click image for larger version
mass03m3 is offline   Reply With Quote
Old 03-01-2010, 11:27 AM   #103
ZZen330
My Ride: 2002 330Ci
So does that indicate dynavin should just reduce the amp gain rather than band aid fix with capacitors which may affect sound quality?
ZZen330 is offline   Reply With Quote
Old 03-01-2010, 11:51 AM   #104
mass03m3
My Ride: e46 M3
I am in no way a car audio expert but I can tell you that the improvement for me is excellent. My understanding is, When you are hooking the wiring harness of the Dynavin unit , You are basically blasting 45w X 4 into your harmon kardon amplifier. So, I would have to say "yes" just turn down the amp gain of the Dynavin unit.
For me, There was no way I was going to send my unit back to have it fixed and have them rip it apart to add some capacitors. Who knows how long that would take and if it even works. This worked out perfect for me and all I can say is try it for yourself. I basically have no complaints about this unit now(except SWC for Bluetooth and Screen glare.) I fixed screen glare with a nushield screen protector and I would hope dynavin would come out with another harness for bluetooth.
Jeffb325 can probably explain it better.
Old 03-01-2010, 01:20 PM   #105
Dreamliner330
My Ride: 330xi
Have you noticed the DVD volume is significantly less than any other input?
Every time I switch to the DVD, it seems it is far lower in volume, and I fear that although the Line Output Convertor will fix most of these issues, the DVD will be even more quiet.
mass03m3, in comparison to radio/usb/ipod how is the DVD volume for you now?
Dreamliner330 is offline   Reply With Quote
Old 03-01-2010, 01:58 PM   #106
cdm3
My Ride: 2005 m3 Vert
Can any of these setting you refer to be adjusted under Settings. From memory there are a number of specialized frequency settings....I am not referring to the basic equalizer
cdm3 is offline   Reply With Quote
Old 03-01-2010, 02:03 PM   #107
mass03m3
My Ride: e46 M3
I get plenty of volume in the dvd to satisfy my needs. As you have said, the dvd seems to be the most quiet of all the modes(radio,ipod, bluetooth etc.) with the radio being the loudest mode. Basically, If i have the radio at a volume of 15 now and I switch to the dvd mode, I have to turn the dvd up to about 20 to 25 to satisfy me. The loc will improve the signal to noise ratio and will clear up the radio bleed.
By the way if anyone needs an LOC I have an extra PAC oem2 that I bought off ebay that just came in the mail this afternoon. Just want what I paid for it $15 + $5 for shipping. The guy I bought it from cut the rca jack off it(I don't know why) but it will still work for this application. pm me if interested.
Old 03-01-2010, 02:05 PM   #108
TR_MS3
Banned
My Ride: 2002 M3 Convertible
so you went from the output RCA's to speaker wires? or vise-versa?
TR_MS3 is offline   Reply With Quote
Old 03-01-2010, 02:08 PM   #109
Dreamliner330
My Ride: 330xi
The LOC he is using is simply inline from the speaker out wires on the Dynavin. Interestingly enough, coming off the Dynavin's RCA outputs to bare wires may work too (not needing a LOC then), no telling if the output is strong enough though, probably not.
Old 03-01-2010, 02:12 PM   #110
mass03m3
My Ride: e46 M3
As dreamliner said the loc is just inline on the Dynavin harness. I prefer the loc as it is adjustable and you can set it to where you want it.
Old 03-01-2010, 02:14 PM   #111
mass03m3
My Ride: e46 M3
I have not messed around with the specialized frequency settings yet. But as I said the basic eq with the pop,rock,jazz etc can be used now.
Old 03-01-2010, 02:16 PM   #112
TR_MS3
Banned
Dynavin says the RCA is .5 volt right?
Old 03-01-2010, 02:26 PM   #113
jeffb325
My Ride: 325ci
Success! Your explination here is pretty much correct. Great to hear that it worked. Im a little suprised that it got rid of your radio bleed issue...it probably just reduced it enough to make it inaudible with the car running but thats good enough!
Old 03-01-2010, 02:39 PM   #114
mass03m3
My Ride: e46 M3
Thanks for the help. Actually, I can't hear any bleed with the car off. I got sick of waiting this morning for the mailman and went out and bought a different loc and sure enough after i put the different loc in the mailman walks up with the other one!! Well, it's all good. Don't have the hi/lo settings on this loc but it does the trick.
Old 03-01-2010, 02:39 PM   #115
jeffb325
My Ride: 325ci
I have a full aftermarket system running off the factory headunit so I am familiar with what kind of output it has and what adjustments I had to make to match up all my components, thats why I had the LOC idea in the first place.
Since the LOC worked dynavin obviously has WAY too much output voltage through the speaker wires for factory amp to handle BUT I would think .5 volt RCA outputs isnt nearly enough. Somebody should give it a try anyway though, you never know!
Old 03-01-2010, 02:54 PM   #116
jeffb325
My Ride: 325ci
By the way, before everyone starts ripping dynavin let me explain what I think is going on here. First off, The OEM headunit outputs a high level speaker output to the amp not a low line level output. I think this is for universal compatibility, it can drive speakers or the amp and I think the "amp" may be more of a powered crossover than a traditional amplifier.
Dynavin is selling these units globally and I would bet that E46s sold overseas can be had without the "amp" that the US cars have. In these cars the higher power of the dynavin would be an asset, but in our cars with our amps its a bit of a liability. Dynavin probably either didnt realize the potential problem or didnt think it financialy viable to make different units for amp and non amp cars when the differences are minor. I wonder if thier "fix" doesnt just reduce the output a bit.
I guess more isnt always better.
Old 03-01-2010, 02:56 PM   #117
mass03m3
My Ride: e46 M3
Ok - I have another question regarding bluetooth. On the Dynavin unit when you are in bluetooth mode, What does the round knob(the one that everyone is complaining that it is chrome) with the phone symbol on it do? I have turned it and pushed it and does nothing for me in bluetooth mode. Do I need to change a setting somewhere to make this work.
Old 03-01-2010, 03:27 PM   #118
XIinSC
My Ride: 2004 M3 98 M3
Turning it does nothing that I know of. When connected to my Iphone you can push to answer if you have a call incoming and auto answer is turned off in settings.
If no call is incoming, pushing it redials the last number.
XIinSC is offline   Reply With Quote
Old 03-01-2010, 08:48 PM   #119
doubledees
My Ride: 2005 M3 Jet Black
This is great news!! Good job mass03, so you are using the rca's provided to plug this line level converter into? Which labeled plugs are you using...sorry novice at all this stereo talk. Thanks.
doubledees is offline   Reply With Quote
Old 03-01-2010, 09:22 PM   #120
mass03m3
My Ride: e46 M3
No, I am not using rca's. I bought a 4 channel Line ouput converter (stereo wire to stereo wire). An example of these units is a PAC oem2 or PAC soem4 or NEucleus nc-sc400t. Basically, cut all 8 speaker wires on the dynavin wiring harness and put the Line output converter inline. the speaker wires you cut on the dynavin wiring harness are:
White(front left speaker+)
White/black(front left speaker-)
grey(front right speaker+)
grey/black(front right speaker-)
green(back left speaker+)
green/black(back left speaker-)
purple(back right speaker+)
purple/black(back right speaker-)
then make adjustments to the 4 channels until the sound and volume is what you desire. The directions that come with the loc are pretty straight forward.
Rate This Thread
