Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 136 votes, 4.94 average.
Old 03-01-2010, 09:24 PM   #121
jeffb325
My Ride: 325ci
Originally Posted by doubledees View Post
This is great news!! Good job mass03, so you are using the rca's provided to plug this line level converter into? Which labeled plugs are you using...sorry novice at all this stereo talk. Thanks.
No, everything that has been done so far is using the speaker outputs, the discussion of using the RCAs is thoretical at this point (and unlikely!)
jeffb325 is offline   Reply With Quote
Old 03-01-2010, 11:05 PM   #122
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
Originally Posted by mass03m3 View Post
Ok,
I have installed a line ouput converter(loc) on my Dynavin e46 headunit. And much to my suprise, IT WORKS!!!!!!!!!!!!!!
I was waiting on the PAC oem2 in the mail and ran out of patience. I went down to my local installer and told him my situation and he gave me a 4 channel line level converter made by Neucleus(nc-sc400t). I would probably go with the PAC loc as it has adjustments for line level and the neucleus does not. It said in the Neucleus instructions that this unit is made for Harmon Kardon system. The best part is you can pick a loc up online for way under $50!!!
I no longer have hiss or radio interference in the background. This Definetely makes this dynavin sooo much better. I can also use other settings on the eq such as rock,pop,jazz etc. and I don't get any popping or hiss. It is a very simple install as you Just install it inline on your Dynavin harness speaker outputs. The worst part is you have more wires to shove into the dash.
Many thanks to jeff325 as he is the one who suggested the LOC!!!!
Thanks for the daytime pictures!
delmarco is offline   Reply With Quote
Old 03-02-2010, 11:38 AM   #123
mass03m3
My Ride: e46 M3
They have the dynavin 5m harness available at cardvdkit.com for trunk interface.
mass03m3 is offline   Reply With Quote
Old 03-02-2010, 04:15 PM   #124
jzwu
My Ride: 2005 BMW 330Cic
Who/what kind of factory setup needs this harness? I know Dynavin was working on it.
jzwu is offline   Reply With Quote
Old 03-02-2010, 04:58 PM   #125
BG in NJ
My Ride: 06 AW/Cinn M3 Cab.
Has anyone who has replaced their business CD HU with the Dynavin checked to see if their OBC still displays MPG, Distance to empty, etc?
Thanks,
BG in NJ is offline   Reply With Quote
Old 03-02-2010, 05:16 PM   #126
Alex323Ci
My Ride: M3 & 323Ci (sold)
Thanks,
Yes it all works as before. I have not seen anything different at all.
Old 03-02-2010, 06:07 PM   #127
mass03m3
My Ride: e46 M3
You need this 5m harness if you currently have the oem bmw navigation head unit and want to replace it with the e46 dynavin unit.
Old 03-02-2010, 08:29 PM   #128
fotoflojoe
My Ride: 2006 M3
Mine arrived a week ago, it's been sitting on my desk mocking me since then. Well, my HVAC relocation kit was waiting on my doorstep when I got home from work, so off to install I went.
w00t!
Got the new bracket swapped out, and the Dynavin initially wired up in about 45 minutes - it's really not difficult. Biggest worry for me was removing the dash trim without cracking it.
A big THANK YOU to everyone who's posted in this thread with tips and tricks for setting up the unit properly. Nick, this means you!
First impression, I really like this thing. I don't seem to be getting any bleed through from the radio - at least none that I can hear. My phone was a little cranky when I paired it, but then, my phone always seems to be cranky. The "gee-whiz" feature for me is playing DVDs (got sucked into watching Wedding Crashers for about 20 minutes. ).
So far, the only thing I don't really like is the look of the nav software - iGo looks a little cheesy. But then, I always knew that I was gonna experiment with other GPS apps once I got the thing completely installed.
Before the Dynavin gets buttoned up, I need to install the backup camera; installing a Pioneer universal camera. Not really looking forward to that.
fotoflojoe is offline   Reply With Quote
Old 03-03-2010, 08:03 AM   #129
BG in NJ
Thanks......
Going to give it a try. Ordered from Euro-Spec
Old 03-04-2010, 12:03 AM   #130
doubledees
My Ride: 2005 M3 Jet Black
Does anyone know how to deactivate the safe mode on the DVD while driving so that it will still play? Mine will go on for a few seconds and will switch to a blue screen saying it is unsafe to watch while driving.
Also does anyone know if it is possible to turn off the transition phase say if I had the cd player on and i switch to navi screen, is there a way for the music to still be on while on another screen without pausing? It pauses for a while and then the music comes back on and is quite annoying.
Sorry if this has been discussed. thanks.
doubledees is offline   Reply With Quote
Old 03-04-2010, 12:16 AM   #131
fotoflojoe
My Ride: 2006 M3
To deactivate DVD safe mode, simply ground the wire labeled "Parking". I just tapped it into the unit's power ground. Works great.
Old 03-04-2010, 12:17 AM   #132
fotoflojoe
My Ride: 2006 M3
Has anyone bothered to hook up an antenna to see what, if anything comes through in TV mode?
Old 03-04-2010, 02:58 AM   #133
damills
Modded ///Member
My Ride: 2002 m3 & 2014 650i
Looks like these units are the same, looked around on cardvdkit.com, found a VW model that looks if not identical very close to the dynavin unit, compare these 2 links
http://www.dynavin.com/products/product_dnv_vw.php
http://www.cardvdkit.com/index.php?m...roducts_id=134
Looks like there are others out there producing not standard headunits for Ford, Nissan and others, maybe there is a market out there and there is hope for us afterall , maybe dynavin is making units, decided to go on their own, who knows, comments?
Hope the links show up as I seen them but compare the VW units on both cardvdkit.com (v7204) and dynavin.com (dvn-vw)
damills
damills is offline   Reply With Quote
Old 03-04-2010, 11:44 AM   #134
mass03m3
My Ride: e46 M3
I was going to ask the same thing. I know everything is digital now(in my area anyways). But, what would happen if I picked up one of these digital tv antennas(i'v only seen them made for home use) and hooked it to the Dynavin? Maybe put the antenna in the trunk. Does anyone think this would work?
Old 03-04-2010, 11:48 AM   #135
mass03m3
My Ride: e46 M3
Ok, REgarding the navi, I have changed the loading IGO screen to the picture I want(silver M# with the Igo logo next to it). Does anyone know how to change the Pictures on the Startup screen(the one with the funky old green convertible,the music icon and the setup icon) and where they are located in the igo8.3 software?
thanks
Old 03-04-2010, 11:49 AM   #136
jeffb325
My Ride: 325ci
Im not saying it wont work and I havent ever tried it BUT digital tv requires a fairly stable signal and a moving vehicle does not provide a stable environment for that, I would think that it would work well stationary but moving is a whole other story.....somebody prove me wrong.
Old 03-04-2010, 04:37 PM   #137
jeffb325
My Ride: 325ci
One question that I dont think has come up yet, for you guys who have successfully installed this thing and are using an ipod.....does the dynavin allow for control of the ipod from the ipod or does the ipod display the dreaded accessory connected screen. Perhaps it is selectable as many aftermarket stereos are? I posted this in the other thread as well but....well you know how the other thread is going.....
Old 03-04-2010, 05:51 PM   #138
steveje
My Ride: 04 330ci Convertible
Normally, you get the accessory connected screen. But I have messed around a few times trying to load video where it gave me back control to use the iPhone to select music. I haven't TRIED to do it on purpose, but I have done it a few times.
steveje is offline   Reply With Quote
Old 03-04-2010, 11:39 PM   #139
damills
Modded ///Member
Do you think in theory using aftermarket amp with the RCA outputs, do you think we will still have the bleed problem, know anyone who has done it? I thought about it but worked so much this week, have car apart, I cant seem to find time just to put it in and connect it up.
Do you know anywhere we can buy caps for the RCA plugs, anywhere on-line?
damills
Old 03-05-2010, 01:00 AM   #140
jeffb325
My Ride: 325ci
No, i dont think the problem will be present on the rca line outs (unless you turn the gain up to high). Everyone so far is all stock so no word on how it works with an amp. When i get my dynavin in a few weeks it will be going into an all aftermarket system so the question will be answered then but i hope somebody will so it sooner...
Just tape off the rcas, no need for caps, you just dont want them touching stuff they shouldnt be.
Rate This Thread
