E46 Convertible
Old 02-22-2010, 02:02 AM   #1
handson
My Ride: 330
Anyone know how to fill up the convertible pump with hydraulic oil?
Any pictures would be great if anyone has done this before. Mine is running low on my 325Ci convertible and I have to add some. I know the pump is in the trunk area on the drivers side but I don't know where to fill.
Thanks for helping out.
_______________
handson is offline   Reply With Quote
Old 02-22-2010, 12:05 PM   #2
wtm2w
My Ride: '04 330ci ZHP
send me your email and ill send you the procedure in jpgs
wtm2w is offline   Reply With Quote
Old 02-22-2010, 11:07 PM   #3
handson
My Ride: 330
pm sent
Old 03-02-2010, 11:37 PM   #4
handson
My Ride: 330
Thanks wtm2w. Awesome pictures
Old 04-17-2011, 10:20 AM   #5
egruber
My Ride: 2001 325 CiC
I never heard of this one. How do you know it needs fluid? Where is it checked? Thanks!
egruber is offline   Reply With Quote
Old 05-06-2011, 12:03 AM   #6
tooredhots
My Ride: '01 325ci vert
+1,
Where is this container? What fluid does it take?
Bone stock, style 68s FTW!
tooredhots is offline   Reply With Quote
Old 05-06-2011, 02:38 AM   #7
sakumaxp
My Ride: 02 M3 convertible
i think you should post the pictures, and the mods can make it a sticky
Carbon Black Metallic
SMG II
Verttttt
VCSL Front Bumper
VCSL 1 Piece Splitter
VIS GTR Hood
6K Angel Eyes
VMR VB3 19's
KW V2 coilovers
sakumaxp is offline   Reply With Quote
Old 05-06-2011, 10:08 AM   #8
alibusoul
My Ride: TiAg e46 Vert
post the pics!
alibusoul is offline   Reply With Quote
Old 05-06-2011, 12:39 PM   #9
E46-Cabrio
My Ride: E46 330CI Cabrio
Here's the E46 Convertible Top pdf file.
Read page 6.
and online repair manual LINK
E46-Cabrio is offline   Reply With Quote
Old 05-06-2011, 04:46 PM   #10
Manza
My Ride: E46 330Ci SMG
Thanks!
Manza is offline   Reply With Quote
Old 05-06-2011, 06:59 PM   #11
Bookedup
My Ride: 06 M3 Imola Red
E-46 Cabrio, Do you know if they ever changed anything through the production year ending 2006, with regard to the manual? It appears it was produced in 2000. Thank you for posting it.
Rob
Bookedup is offline   Reply With Quote
Old 05-06-2011, 09:04 PM   #12
tooredhots
anyone know how full the clear container should be? My container is more than 3/4 full I am not sure how to fill it.
Old 05-06-2011, 11:51 PM   #13
E46-Cabrio
Rob
I don't think so, all the hydraulic pumps are the same 318CI-M3, 2000-2006.
Old 05-06-2011, 11:58 PM   #14
E46-Cabrio
Only fill the container when the top is open.
Old 05-07-2011, 10:04 AM   #15
egruber
_______________
My mechanic told me that unlike other fluids in the car, this system should never 'run low'. If you need fluid there is probably a leak somewhere...which will be very expensive to repair.
Old 05-07-2011, 04:47 PM   #16
BillyJoelR
My Ride: Velvy B.
This is exactly what I heard too.
| There is no replacement for Displacement | Go Big or Go Home |
BillyJoelR is offline   Reply With Quote
Old 10-21-2011, 03:09 PM   #17
gbakerkingston
My Ride: 2004 330ci Vert
How about the hydraulic oil type? Does it need to be OEM from dealership, or can regular hdyraulic oil be used?
gbakerkingston is offline   Reply With Quote
Old 10-31-2011, 10:24 PM   #18
zimdba
My Ride: 2003 M3 Convertible
I paid $40 USD from the dealer. I thought it was reasonable. YMMV.
zimdba is offline   Reply With Quote
Old 11-01-2011, 08:03 PM   #19
dkuchta
My Ride: 325cic
You two are correct, you should not need to add fluid, UNLESS there is a leak, doing so could over pressurize the system and cause a seal to blow- thus causing a leak. This is for any hydraulic system.
dkuchta is offline   Reply With Quote
Old 11-01-2011, 11:41 PM   #20
Rigrig
My Ride: 330cic
Where would those seals be? I bought my car with troubles to open, very weak. I checked the fluid and it had almost a quarter of a cup too much. I took the fluid out but a little too late, the damage is done. Is there a solution?
Rigrig is offline   Reply With Quote
