E46 Convertible
Old 11-02-2011, 08:52 AM   #21
dkuchta
My Ride: 325cic
Originally Posted by Rigrig View Post
Where would those seals be? I bought my car with troubles to open, very weak. I checked the fluid and it had almost a quarter of a cup too much. I took the fluid out but a little too late, the damage is done. Is there a solution?
I personally don't have much experience with this on our bmw's, however any connection could leak, only way to check is follow each line and look for oil build up at the connections.
To me the top while in movement seems a little slow and seems under powered, but that is normal.
Good Luck
dkuchta is offline   Reply With Quote
Old 11-02-2011, 08:35 PM   #22
Rigrig
My Ride: 330cic
Well, mine no longer opens if I don't help it along. It just keeps making the attemp but comes back down. I wonder if new gas shocks would help it any
Rigrig is offline   Reply With Quote
Old 01-16-2012, 01:47 PM   #23
fast2fresh
My Ride: E46 convertible
convertible top fuild
Originally Posted by wtm2w View Post
send me your email and ill send you the procedure in jpgs
Hello can you please send me pic on the procedure on how to add fuild? my email is fast2fresh@yahoo.com, thank you for your help.
fast2fresh is offline   Reply With Quote
Old 01-16-2012, 01:51 PM   #24
fast2fresh
adding fuild to E46 top
Originally Posted by handson View Post
Thanks wtm2w. Awesome pictures
can you forward me the picture i need to know how to add fuild to my convertible top? my email is fast2fresh@yahoo.com
Old 01-16-2012, 06:53 PM   #25
gbakerkingston
My Ride: '05 M3 vert, '13 X5D
Refer to my thread http://forum.e46fanatics.com/showthr...988&highlight=
I posted several PDF files which present information per your question.
Go to a pharmacy and buy a large syringe. I found topping up with a syringe very effective.
gbakerkingston is offline   Reply With Quote
Old 09-30-2012, 11:07 PM   #26
klixtokw
My Ride: bmw 325 ci
Originally Posted by E46-Cabrio View Post
Here's the E46 Convertible Top pdf file.
Read page 6.
and online repair manual LINK
E46 PAGE 6 DOES NOT SHOW YOU HOW TO FILL IT DIRECTSYOU TO A REPAIR MANUAL. iS IT POSSIBLE TO BE ON THE LOW MARK EVEN THOUGH YOU HAVE NO LEAKS? iS THERE A WAY TO MEASURE THE PRESSURE GENERATED BY THE PUMP TO SEE IF IT MEETS THE MINIMUM? mY TOP GOES UP AND DOWN COMPLETELY AS LONG AS I HELP IT ON THE START OF LOWERING AND RAISING THEN IT WILL COMPLETE THE CYCLE COMPLETELY BUT IT SEEMS SLOW. iTS LIKE THE LOWERING OR RAISING MOTOR DO NOT DEVELOP ENOUGH FORCE TO DE THE JOB.
klixtokw is offline   Reply With Quote
Old 09-30-2012, 11:13 PM   #27
klixtokw
My Ride: bmw 325 ci
Originally Posted by gbakerkingston View Post
refer to my thread http://forum.e46fanatics.com/showthr...988&highlight=
i posted several pdf files which present information per your question.
gbaker, there is no info on how to fill the hydraulic reservoir on your link its all about a leak you have on the cylinder. Where is the info you posted on how to fill the hydraulic system??? Pics would be helpful.
Thanks!
Old 09-30-2012, 11:17 PM   #28
klixtokw
My Ride: bmw 325 ci
Good Luck
DKUC,
WERE YOU TOLD BY A MECHANIC THAT THIS SLOW OPERATION IS NORMAL. I HAVE YOUR SAME PROBLEM EXCEPT I HAVE TO HELP THE LOWERING OR RAISING AT THE START. IT SEEMS I DON'T HAVE ENOUGH POWER ON THE MOTOR OR HYDRAULIC PRESSURE BECAUSE WNEN IT WAS WORKING IT NOT ONLY DID IT ALONE BUT MUCH FASTER. iTS SOMEWHERE AROUND 20 SECONDS LOWERING OR RAISING FOR A COMPLETE CYCLE.
Old 09-30-2012, 11:21 PM   #29
klixtokw
My Ride: bmw 325 ci
WTM,
can you please send me the same pics i seem to have the same problem! I will send you my E-Mail.
Old 06-01-2013, 11:47 AM   #30
smellvetica
My Ride: BMW 330ci Sport
Have you got the pics there chaps? Having the same problem. Thanks
smellvetica is offline   Reply With Quote
Old 06-01-2013, 12:34 PM   #31
taylor192
My Ride: 2003.5 M3
Re: Anyone know how to fill up the convertible pump with hydraulic oil?
If the operation is slow it's because the fluid is low.
If the fluid is low you have a leak somewhere.
You can fill the pump yet you're going to have to keep filling it unless you find and fix the leak.
Search for a DIY to change the pump, it also explains how to fill the pump. It's very easy once you have access to the pump. There is just one hex screw to remove to add or drain fluid. It looks like an oil drain plug.
Sent from my Nexus 7 using BimmerApp mobile app
Old 06-01-2013, 01:47 PM   #32
TopHydraulicsInc.com
Supporting Vendor
TopHydraulicsInc.com's Avatar
My Ride: German verts
Thumbs Up Refilling the hydro unit, fluid, pump rebuild, finding the leak
smellvetica,
indeed, the reason for the top moving slowly is usually a low fluid level. As taylor192 correctly states, you need to find the source of the leak if the fluid level is low. The fluid doesn't evaporate...
Here is the fluid management DIY that gbakerkingston posted a while ago:
http://forum.e46fanatics.com/attachm...1&d=1317591109.
Acceptable fluids outside of the overpriced BMW fluid are:
FeBi 02615 (same as BMW fluid, but much cheaper, for example at http://www.rmeuropean.com/Part-Numbe..._D18BD03A.aspx)
Mercedes fluid A0009899103 (same as FeBi and BMW fluid, also sometimes referenced as p/n 000989910310)
Pentosin CHF-11S (available in some parts stores)
Aral Vitamol ZH-M (in Europe)
There is also a good DIY on pump removal on the web. I cannot find it right now - hope somebody can place a link here.
If it were the bow tension cylinders that are leaking, then you would have already found the fluid dripping onto the tonneau cover. You could also have a main lift cylinder or a tonneau cover lift cylinder leaking, or one of the lines going to the cylinders. The lines we find to be damaged most frequently, are #23 going from the valve block near the left main lift cylinder to the right main lift cylinder (taylor192 wrote an awesome DIY for its replacement http://www.tophydraulicsinc.com/e46line23guide.pdf) and line 34 going to the left bow tension cylinder. The good news is, all of these parts can be replaced in DIY, and cylinder upgrades from Top Hydraulics are much cheaper and better than new parts from the dealer.
Top Hydraulics now manufactures all the small lines going to the cylinders, and we can even replace lines that are crimped onto the cylinders.
Lastly, the pump can burn out if it operates on low fluid for too long. Top Hydraulics also rebuilds convertible top hydraulic pumps (http://www.tophydraulicsinc.com/en/b...ulic-pump.html), but you want to avoid that expense...
Klaus
http://www.tophydraulicsinc.com/en/56-bmw-e46
Some BMW E46 hydraulic cylinders, pumps, and valves that we rebuild and upgrade at Top Hydraulics:
54347025593
54347025600
54347025599
54348236956
54348243269
543454347025595 (hydro-unit, sticker p/n is 8234530)
54347025592 (control unit)
54347025598 (improved hoses manufactured at Top Hydraulics)
TopHydraulicsInc.com is offline   Reply With Quote
Old 08-22-2013, 08:21 AM   #33
Lydric
My Ride: E46
How to install the hydraulic pump? How refill the oil?
Hi
Does any one know how to install the hydraulic pump?
And also how to refill the oil for the pump? Please show with pictures if you can.
Thanks in advance
Lydric
Lydric is offline   Reply With Quote
Old 08-22-2013, 10:22 AM   #34
taylor192
My Ride: 2003.5 M3
Originally Posted by Lydric View Post
Hi
Thanks in advance
Lydric
Read the sticky about hydraulics. There is not a step by step guide specifically for the pump, yet all the info is there including detailed photos.
That and search, it's been covered many times.
Old 08-22-2013, 10:33 AM   #35
Lydric
My Ride: E46
Thanks Taylor
I only found that in attachments.
There is not explanation how to change the pump.
Have a nice day
File Type: pdf bmw_e46_hydraulic_fluid_management[1][1].pdf (52.6 KB, 207 views)
Old 08-22-2013, 12:59 PM   #36
taylor192
My Ride: 2003.5 M3
Thanks Taylor
Have a nice day
NP.
Not to be rude, yet if you cannot figure it out from the pics in this post you should have a shop do it. I cover how to get access to the pump, free the pump, disconnect some hydraulic lines and the electrical connector. The only thing I didn't cover was how to drain and fill the pump since its just one plug that has to be removed.
http://www.e46fanatics.com/forum/sho...d.php?t=976708
Old 08-23-2013, 02:23 AM   #37
Lydric
My Ride: E46
Taylor192 , thank you , thank you very much.
I think with the pics it will help me a lot.
I wish you a very nice sunny day
Old 07-05-2015, 07:04 PM   #38
klixtokw
My Ride: bmw 325 ci
Do you have pics of how to remove the trim to access the unit?
No one mentions this and they all seem to have found the unit. I have almost ripped the trim and still is not off.
Old 07-05-2015, 07:07 PM   #39
klixtokw
My Ride: bmw 325 ci
Any pictures would be great if anyone has done this before. Mine is running low on my 325Ci convertible and I have to add some. I know the pump is in the trunk area on the drivers side but I don't know where to fill.
Thanks for helping out.
_______________
Have you been able to access the pump? If so can you tell me how to remove the trim? Pics would be helpful.
