What is the benifit of a Staggered Tire set up? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 02-22-2010, 10:32 AM   #1
sigep
My Ride: 2004 330i ZHP
I have a 2004 BMW 330i ZHP and has a staggered tire set up. I dont care for this due to you cannot rotate your tires. Is the staggered set-up mainly for appearance reasons? or does it for handling purposes?
sigep is offline   Reply With Quote
Old 02-22-2010, 11:27 AM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Larger rear tires will provide more traction to the rear wheels however there is not a drastic difference in acceleration times between staggered and non staggered due to traction issues. The main reason is for aesthetics, a non staggered setup will run inset from the fender on the rear and look less aggressive. If you are set on non staggered, you can run spacers on the rear setup to make it flush with the fenders.
Old 02-22-2010, 11:54 AM   #3
tiloulou330i
My Ride: 02 330i zsp
Send a message via AIM to tiloulou330i Send a message via MSN to tiloulou330i Send a message via Yahoo to tiloulou330i
BmW does not recommend rotating tires!
Filbert
Originally Posted by nawmean?
I know I sound naive, but some of the advice I've taken from this board has helped my life quite a bit
tiloulou330i is offline   Reply With Quote
Old 02-22-2010, 11:55 AM   #4
TR_MS3
Banned
My Ride: 2002 M3 Convertible
Most don't anymore. Also, most people run directional tires, so there's no X pattern possible anyways.
TR_MS3 is offline   Reply With Quote
Old 02-22-2010, 11:58 AM   #5
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Majority of members on this board will buy a staggered setup for a more aggressive rear fitment. This could include a wider wheel, tire, stance, and appearance.
The wider rear will performance wise, will offer a wider contact patch and additional grip since the car is RWD.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 02-22-2010, 12:03 PM   #6
ChiMaster
My Ride: 01 330ci, 11 Audi
Staggered has more of tendency to understeer, a square set up will give you more neutral handling.
2001 BMW 330ci
2011 Audi A4 Avant
ChiMaster is offline   Reply With Quote
Old 02-22-2010, 12:11 PM   #7
330I6SPD
My Ride: 2005 330I 6Spd.
Continental tire allows for side to side rotation of asymetrical tires (ContiSportContacts). I run ContiSportContact 3s in 235 and 255 widths on Style 68 Ms and rotate every 5 K miles for even wear.
330I6SPD is offline   Reply With Quote
Old 02-22-2010, 02:45 PM   #8
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Most would argue the benefits are mostly cosmetic appearance and possible better straight line acceleration. "handling" is generally considered more neutral with a non staggered setup.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 02-22-2010, 02:56 PM   #9
sigep
Thanks every body for your input
Old 02-22-2010, 07:08 PM   #10
Nicad
My Ride: e36 M3/4 e46 325it
I also have an E36 M3 sedan. It came with a staggered setup., 245-40-17 in back and 225-45-17 in front. The rear rims are 8.5 and the fronts 7.5. My most recent set of tires is a square setup. 235-40-17's all around. There is a big difference in handling. the car feels much livelier and steering is better. I rotated the tires once off the rims. Tire wear on the E36 M3 is in the ratio of two rears per front tire. There are cost benefits to running a square setup. I am going to keep my E46 square when I buy new wheels and tires this summer.
Nicad is offline   Reply With Quote
Old 02-22-2010, 07:18 PM   #11
BMWespresso
My Ride: 2005 325CI
None no benefits, if possible go with a square setup, better handling and braking, if both front and rear rims are the same size then you can do the rotate thing
BMWespresso is offline   Reply With Quote
Old 02-25-2010, 11:21 AM   #12
mattcarle21
My Ride: is Breakin My Wallet
Just looks without power
Autozone is for wannabee's, carefull cuz most of them want to be BMW owners - but can't.- Freeflow
mattcarle21 is offline   Reply With Quote
Old 04-18-2010, 06:59 PM   #13
raybiff
My Ride: 330i
Just curious, should you rotate your staggered wheels?
raybiff is offline   Reply With Quote
Old 04-18-2010, 07:16 PM   #14
HighPod
My Ride: '00 white 323ci
i like this thread, i had the same questions about staggered because i am planning on some new wheels
HighPod is offline   Reply With Quote
Old 04-19-2010, 11:50 PM   #15
BMWfever
My Ride: '06 330 Ci
I am new to E46 and have read several threads about "staggered" vs "square".
The consensus seems to be that square is better for handling, (unless mods are made to swaybars etc.)
My question is --> unless we drive to the limits, do we ever feel the understeer in a staggered setup?
I could imagine that the owners who take cars to the track can feel the difference, but unless we drive to the point the tires start losing traction, is there any real difference between staggered and square?
Personally, I have not felt understeer in my car, but practically everyday LOVE walking up to it in a parking lot and seeing those wide tires in rear.
BMWfever is offline   Reply With Quote
Old 04-20-2010, 11:53 AM   #16
Rudy@Tirerack
Moderator
You are correct that most do not drive their cars close enough to the limit to feel understeer (unless they have really bad tires...).
Old 04-29-2010, 05:25 PM   #17
dvd64
My Ride: bmw e46 CI
Bigger tires less performance? staggered affect MAX SPEED ?
dvd64 is offline   Reply With Quote
Old 04-29-2010, 05:33 PM   #18
IntegGeezer2Bimmer
My Ride: M3
Originally Posted by Born Again View Post
you have to understand the people that jump from car to car often have NO MONEY
they are usually making poor financial decisions and rolling over debt.
No offense to some members on the group but there are dudes making less than $35K driving in fairly new cars - lol like leasing a $40k car - wtf - the car is worth more than what you make in a year!
OP just be sensible - good luck!
IntegGeezer2Bimmer is offline   Reply With Quote
Old 04-29-2010, 05:46 PM   #19
habbyguy
My Ride: 2003 330i ZHP
Originally Posted by IntegGeezer2Bimmer View Post
why use larger tire diameter in the front than the rear? example 245-(40?-17 in back and 225-(45?-17 in front.
The diameter of the tires will be the same (or close enough to not matter). The first number (245 or 225) is the width of the tire in mm's... the second number (40 or 45) is the ratio of height of the sidewall to width. So (theoretically, anyway) the 245-40 tire will be only about 3mm shorter than the 225-45 (1/8").
'03 ZHP - Silver Gray Metallic - 6MT - Alcantara/Aluminum Cube - Heated Seats - Winter Package - Xenon - Dice Silverline - Clear Corners - Permanent Grin
habbyguy is offline   Reply With Quote
Old 04-29-2010, 05:56 PM   #20
IntegGeezer2Bimmer
My Ride: M3
my question is (why use a larger number ratio of height und the front than the rear tire??) any effect
