Old 02-23-2010, 02:19 AM   #1
STORMER
My Ride: AA SC 98 M3
Dreaded Rear Diff Bushing DIY
Hey guys wasup? Have been looking and searching on this adventure and I am about to embark on the dreaded rear diff diy and need a lil input from you guys on these tools??? 1.http://cgi.ebay.ca/BMW-E46-E85-Rear-...item519086c024
2.http://cgi.ebay.ca/BMW-E46-E85-Rear-...item5190b72258
So whats the deal here are these not the same tool? or am i missing something ?? has anyone used one of these tools? work good or no??
Any feedback on this situation would be appreciated thanks
STORMER is offline   Reply With Quote
Old 02-23-2010, 02:34 AM   #2
STORMER
come on guys looking for some insight .... i know u got it
Old 02-23-2010, 03:31 AM   #3
Alex323Ci
My Ride: M3 & 323Ci (sold)
first one seems to be for the rear diff bushing.
while the second one is for the two front bushings for the diff.
Old 02-23-2010, 05:31 AM   #4
viceversa
My Ride: 2004 325i
see my sig
Originally Posted by i_ween View Post
OP: I am sure your English Writing teacher told you this every year, regardless of who s/he was: writing is important. Others will either respect you or ignore you or piss on you if you type like a moron. This isn't an instant message site; it's a forum. We aren't texting each other right now. We are typing messages. Type regular English and people are more likely to respond.
viceversa is offline   Reply With Quote
Old 02-23-2010, 07:54 AM   #5
Many330i
My Ride: e90 M3
tell us how it goes.
Many330i is offline   Reply With Quote
Old 02-24-2010, 11:05 PM   #6
STORMER
u know what my friend i do believe you are correct haha i am going to be purchasing these puppies and putting them to good use i would like anyone who is interested in perhaps doing the same job let me know i will be putting them up for sale when i am done HALF PRICE so let me know guys will keep updated i know there is already a DIY here on it but i may add one of my own at least maybe some pics
Old 02-24-2010, 11:07 PM   #7
STORMER
Originally Posted by fibonacci00782 View Post
see my sig
So let me get this straight. In order for you to make an educated comment you have to use the intelligence of somebody else to speak for you is that it? There is a time and a place for everything my friend.
Old 03-11-2010, 12:02 AM   #8
STORMER
This Weekend!!!
Ok so I am about to attempt the job this weekend; may or may not document but none the less i have recieved the needed tools. I ordered them through Baum Tools and believe me they are extremely high quality!!! Will be putting them up for sale immediately after the job is completed if anyone is interested just let me know
Old 03-11-2010, 06:58 AM   #9
slickware
My Ride: 323i
I'm interested in both your thoughts on the process difficulty, as well as possibly purchasing the tools when you're done. Keep us posted and let us know how it goes.
I just finished reading a DIY here about a guy who took almost 3 weeks to get his bushings OUT let alone back in the car
~A
slickware is offline   Reply With Quote
Old 03-11-2010, 07:17 AM   #10
Silver325
My Ride: 2002 325i
I'm very interested to see how this goes with the proper tools. Keep us posted!
Meyle control arms, M3 RTAB's, Bridgstone Potenza RE760
Silver325 is offline   Reply With Quote
Old 03-11-2010, 08:07 AM   #11
wat3rbug
My Ride: 2002 BMW 325 xi
There is a DIY on this site but it rates it 9.5 out of 10 in difficulty. I read it a while back, however I didn't see anything about it using the tool.
wat3rbug is offline   Reply With Quote
Old 03-11-2010, 09:29 AM   #12
viceversa
My Ride: 2004 325i
All of my comments are educated, but my requests that OPs keep their threads readable... yes I do refer to someone else's post. Your point?
Old 03-11-2010, 11:37 AM   #13
TxZHP04
My Ride: ESS TS2+ ZHP
Dropping the diff is tedious and time consuming but not at all difficult. With the Baum tool, once the diff is out of the way, you can swap the bushing out within a matter of minutes with almost no effort. People rate this job as difficult because they attempt it without the proper tool which tremendously increases the difficulty of the task.
Old 03-11-2010, 11:43 AM   #14
slickware
My Ride: 323i
Link to the Baum tool?
Also - from what I have read, the front and side bushings require different size cylinders to pull - does the Baum tool come with both sizes?
Old 03-11-2010, 12:27 PM   #15
David F
My Ride: 323i, 740iL, 633CSi
I did it without any special tools and yes, special tools will make it easier. It is rare for the two front bushing to fail, so leave those alone. I Basically did the following:
1. Remove differential.
2. Using a twist bit and drill motor, I drilled a series of holes around the perimeter of the bushing (between inner and outer sections). This allowed me to remove the center section of the bushing.
3. Using a reciprocating saw (with metal blade), I cut through the outer shell of the bushing while taking care to avoid cutting into the bushing carrier.
4. Using a cold chisel, I easily knocked the cut bushing out of the carrier.
5. Using a 1/4 metal plate, 1/2" bolt (several different overall lenghts), washers and nut, short lengths of metal pipe (just larger diameter than bushing, I pulled the new bushing in place.
6. Reinstalled differential.
All together, it probably took me a good 4-6 hours.
David F is offline   Reply With Quote
Old 03-11-2010, 12:31 PM   #16
HellRaiser1
My Ride: 2004 M3
About to do this on my car, which has 200k+ miles...so I should only change the rear diff bushing and not the two fronts because they don't fail?
HellRaiser1 is offline   Reply With Quote
Old 03-11-2010, 12:34 PM   #17
David F
Yes, however, you should check the front bushings, but more than likely they are ok...the fronts just don't see the forces the rear bushings gets.
Old 03-11-2010, 01:47 PM   #18
STORMER
~A
So just to clarify the tools i decided to purchase are not the ebay tools( I read of someone using them and they become deformed in the process-cheap) but they are rather professional grade mechanics tools from Baum Tools.http://www.baumtools.com/pdf/bmw_rear_axle.pdf. B333360 and B333370.
Yes due to interest I will be in fact documenting this project. Although not as in depth as other DIY's already posted on this as it would be just repeat information.
I also have read that one a couple of times but where he went wrong was in fact not having the proper tools Thats what led me to my recent purchase. My buddy and I are actually looking forward to this project if not just for the excitement of using my nice fancy new tools
Old 03-11-2010, 01:55 PM   #19
SweTurbo
Big Pimpin'
My Ride: 323i -98
How i did it too, i did however have a shop cut the metal part with acetyne and then the stealer put the bushing in for me.
I replaced the two smaller ones myself.
Replacing all of these bushings are a ***** to do yourself without special tools.
However special tools can be made yourself by following David's comment.. wish i had known that before i went -20$ to have the dealer do it.(delaer was kind enough not to charge me the real $100 cuz i dint want an expensive receipt)
Old 03-12-2010, 01:41 AM   #20
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
I wish Vorshlad would offer some poly diff bushings to match their engine and tranny mounts.
Good luck to the OP...I look forward to your DIY!
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
