Old 02-23-2010, 05:53 PM   #1
shaunbradley
My Ride: 2003 325i
short shifter
i've heard that a short shifter makes a huge difference in how the car feels. I'm wondering if anyone has experience with it and can tell me if its worth it. thanks!
shaunbradley is offline   Reply With Quote
Old 02-23-2010, 06:12 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Yes, It's worth it.
My 90K mile shifter felt very sloppy, half the time on a hard shift I'd go from 2nd to 5th,
even though i was trying for 3rd. I realized finding 3rd gear was getting harder, luckily i
never made a "money" shift. I bought mine from Bimmerworld.....
"Rogue Engineering OCTANE Short Shift Kits $364.99
The best short shift kits in the industry!"
Also buy this...."10/94+ Shifter Selector Rod Joint
For most manual transmission BMW cars, 10/94 production and newer" $14.99
Good luck with your decision.
SUMMIT POINT WV 1:24:229 SCCA
Old 02-23-2010, 06:21 PM   #3
mvrk10256
My Ride: E30 325i
a cheaper alternative is understeer.com
however if you want togo all out. UUC ultimate is like 500$ but it is the best.
Old 02-23-2010, 06:31 PM   #4
frankymofe
My Ride: 2000 323i
short shifters are definitely worth it..on any car that has a manual transmission. ive installed plenty of them in alot of my friends vehicles from civics the jettas to S2000...im actually goin to be purchasing one for my 323i here soon.
doing your research is the key tho. alot of kits are pretty much the same, its just what u wanna get out of them. some say different things but all products are pretty much doing the same thing.
im looking at the UUC EVO3 short shift kit..with the DSSR. heres a link for you to look.
http://www.uucmotorwerks.com/html_pr...hifter_nav.htm
its all up to you which one u want. but yes. they do make a difference, especially in our BMWs...with their sloppyness haha
frankymofe is offline   Reply With Quote
Old 02-23-2010, 06:51 PM   #5
shaunbradley
My Ride: 2003 325i
Originally Posted by Rob43 View Post
Yes, It's worth it.
yeah im friends with the owner of rogue engineering and just had them install a ecis intake and im getting a ikon exhaust. after seeing this i think im gonna add a short shifter to the list. thanks guys!
Old 02-24-2010, 03:44 AM   #6
anival755
My Ride: 323i M-Sport
btw, whats the installation look like for a short shifter?? i did one on my 240sx last year but that was easier because we did a clutch at the same time..
anival755 is offline   Reply With Quote
Old 02-24-2010, 12:16 PM   #7
SilverBullet99
My Ride: 323ci
Can anyone tell me if BMW makes a SSK for a 1999 323ci? I checked on REALOEM and they list the kit as being for later models only, is this true?
"Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, your body thoroughly used up, totally worn out and screaming, "Woo hoo! What a ride!"
SilverBullet99 is offline   Reply With Quote
Old 02-24-2010, 12:32 PM   #8
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
Go understeer.com and replace all your bushings. Feels like new.
Old 02-24-2010, 12:34 PM   #9
mvrk10256
My Ride: E30 325i
yup at understeer.com
