Sponsored by BimmerWorld
Old 02-23-2010, 07:20 PM   #1
clinique
clinique's Avatar
My Ride: 06 M3 Vert
What setting for Koni yellow
I searched, but only came up with instructions on how to adjust them.
I just got my set of koni yellows for front and rear.
For the fronts, I can adjust the dampening after installation, but the rears are internally adjustable. I dont want to find out its too bouncy and have to remove the shock to adjust.
Just wanted to know what's a common setting for a DD. No tracking or autoXing. Just want sporty handling with a good amount of ride comfort.
FYI, I'm also running eibach prokit springs and new upgraded shock/strut mounts at all corners.
Any advice is appreciated.
clinique is offline   Reply With Quote
Old 02-23-2010, 08:13 PM   #2
TerraPhantm
My Ride: M3 & ZHP
I have mine set at full soft, and it seems to be pretty good for DDing. A 1/2 turn up would probably be good too. (mine are top adjustable tho since ground control has top adjustable rears made for them)
Old 02-23-2010, 10:54 PM   #3
clinique
clinique's Avatar
My Ride: 06 M3 Vert
Guess I'll start at 1/2 turn up.
I was fully compressing the shocks (both at full soft) and one rebounds noticeably faster than the other. Should I adjust the faster one to get it to match the slower one?
Old 02-24-2010, 02:18 AM   #4
BMW_Matt
My Ride: 135
They used? You might need a rebuilt; the rears are also easy to get to. Just cut a little hole in the carpeting in the trunk, and it's really easy to adjust.
BMW_Matt is offline   Reply With Quote
Old 02-24-2010, 02:27 AM   #5
k3nmasters
My Ride: Is A Unicorn!
Send a message via AIM to k3nmasters
I had my rears set at 50% and fronts at 75% starting from softest on my 330Ci. Worked perfect on my 19" CHs and 20" DPEs!
::05' S54 iR 6MT::
Ichishima-San, "Ferraris and Lamborghinis are like women that are great in bed, but not so great at cleaning the house or cooking."
k3nmasters is offline   Reply With Quote
Old 02-24-2010, 05:43 PM   #6
clinique
clinique's Avatar
My Ride: 06 M3 Vert
nope, they're new
Old 02-26-2010, 01:55 AM   #7
tonydinh3
My Ride: e46 m3
do you need to fully decompress the strut if you adjust the dampening? because i put it on my car and have not touched the dampening yet.
tonydinh3 is offline   Reply With Quote
Old 02-26-2010, 01:57 AM   #8
BMW_Matt
My Ride: 135
Nope.
Originally Posted by clinique View Post
nope, they're new
I think I just read it wrong. If they're compressing at different speeds then they're currently set at different rebound settings.
Old 02-26-2010, 01:20 PM   #9
ZeroSum
My Ride: 05 325
You can not adust the Koni yellow rear shocks without first removing them from the car and compressing them.
ZeroSum is offline   Reply With Quote
Old 02-26-2010, 03:05 PM   #10
BMW_Matt
My Ride: 135
? I must have different shocks from Koni then.
Old 02-26-2010, 03:36 PM   #11
tonydinh3
My Ride: e46 m3
lol so can i or can i not adjust with out compressing the shock? lol i would think you can with them on the car because thats why they have that knob and that would be suck a hassle to take them on and off the car to compress them.... just to adjust them
Old 02-26-2010, 03:54 PM   #12
jvr826
My Ride: '05 330ci 6MT
that makes no sense to me. You adjust them to tune your suspension and if you take the suspension apart every time you tune... well...
I have top adjustable Koni's from TCKline. The process I use is to put them to full stiff, then back them off from there. You can do the same thing from full soft if you rather go that way.
Start with a known setting and work from there.
Jeff
jvr826 is offline   Reply With Quote
Old 02-26-2010, 04:27 PM   #13
ZeroSum
My Ride: 05 325
It does not make sense to me which is why I have now got a set of AST's waiting to be fitted. Looking further into it, the adjustment prodedure varies depending on what shock model you have see here: http://www.koni.com/193.html
To adjust my rear konis I have to take them out, fully compress them until it locks in the adjuster. No other way of doing it.
Old 02-26-2010, 05:00 PM   #14
k3nmasters
My Koni rears were the same as yours Zero.
You have to remove, fully compress, and then rotate the body. 0 to 720 degrees for Max. I set it once and left it.
::05' S54 iR 6MT::
Old 02-26-2010, 06:31 PM   #15
BMW_Matt
My Ride: 135
Yep. And if you keep them at max stiff/max soft, make sure to crack them open.
Do you have the rebound adjustment on top of the shock in the rears?
Ah, well that makes more sense now.
Old 02-26-2010, 08:54 PM   #16
tonydinh3
My Ride: e46 m3
that takes care of the rears how about the fronts? do i ahve to have them taken out to adjust? because if so then GOOD GAME ima going to leave my fronts the way they are! lol but rears were easy to take out and put in so i wouldnt mind taking those out to adjust
Old 02-26-2010, 09:17 PM   #17
roastbeef
My Ride: 325ci
good thread, mine just came in the mail today and i was wondering the same thing.
roastbeef is offline   Reply With Quote
Old 02-26-2010, 10:00 PM   #18
cheech320
My Ride: Is TiAg
No you do not need to take the fronts out to adjust them. Just use the knob supplied and do the same thing to both sides. I used to have the set to full stiff rear and 75% front. I then went to full stiff all the way around. Found alot of understeer at full stiff but I am changing my tire and swaybar setup this year so I'm going to experiment a little more.
Edit: just noticed its a dd with no autox/ track. Just set them to full soft and you should be fine since it will keep the same balance your car had from the factory and get rid of some of the bounce from the stock shocks/struts.
-Anthony
Photobucket
cheech320 is offline   Reply With Quote
Old 02-28-2010, 02:48 PM   #19
clinique
clinique's Avatar
My Ride: 06 M3 Vert
Thanks for the input everyone
I contacted koni and with my eibach prokit springs, they suggested 25% from full soft (180 degree out of 720 max) for the rear shocks
For my fronts, I'll probably do the same 25% setting and adjust as needed.
Old 07-12-2010, 02:21 AM   #20
CokMinusTheS54
My Ride: '01 TiAg 325Ci 5mt
^ Did you get these put in yet? What settings and how do they feel? I'm putting only rears on mine
thanks
CokMinusTheS54 is offline   Reply With Quote
