Old 02-23-2010, 06:27 PM   #1
johnnyalbs5
My Ride: 02 330ci
Will simota intake for 325 fit on a 330??
I'm thinkning about buying a simota intake from a guy that had it on his 325ci. I have a 330ci and i'm wondering if i can get it to fit. Thanks
2002 Black 330ci
5 Speed
Mods: UUC TSE2 Catback Exhaust, Simota CF Intake, Eibach Sportline Springs, UUC swaybarbarian, Front Strut Bar, CCFL Angel Eyes, Smoked Eagle Eyes, Smoked Corners, Smoked Reflectors, Smoked Sidemarkers, HID Headlights,HID Fogs
johnnyalbs5 is offline   Reply With Quote
Old 02-23-2010, 09:49 PM   #2
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
They will work but you may need to modify the intake inlet as the 330 has a larger inlet than the 325.
Old 02-24-2010, 03:27 PM   #3
johnnyalbs5
My Ride: 02 330ci
Is the only thing that is smaller the inlet or is the entire intake in general smaller than the one that is made for the 330?
2002 Black 330ci
5 Speed
Old 02-24-2010, 10:34 PM   #4
xi_ter
My Ride: 2003 325xi
Because the intake was made for a 325, the hose will be narrower and won't let in as much air as the 330 model, even with an adapter at the end. Stick with the factory intake for now.
Old 02-25-2010, 11:45 AM   #5
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
The difference is in the outlet from the back of the intake, otherwise it is the same.
Old 02-28-2010, 08:12 PM   #6
johnnyalbs5
My Ride: 02 330ci
I'm goin to buy a silicone reducer and install it tomorrow. There won't be a huge difference in the amount of power i get from the 325 model compared to the 330 model right?
2002 Black 330ci
5 Speed
Old 02-28-2010, 08:53 PM   #7
///Orient3
My Ride: can't be defined
http://forum.E46Fanatics.com/showthread.php?t=743706
///Orient3 is offline   Reply With Quote
