Old 02-23-2010, 10:29 PM   #1
///Orient3
My Ride: can't be defined
FAQ for Bolt On and Internal Modifications.
There have been a lot of unnecessary posts in here lately with questions that have been answered many times over. Because of this, and the fact that this forum doesn't have a sticky, I thought I would do an FAQ that will come in two parts. The first part addresses bolt on modifications. The second part, which will come soon, will address more invasive and harder to install modifications such as camshafts, pistons, clutches, flywheels, etc.
Headers
What are my options?
- You have several options as far as brands go. I will go over options in rough order of price. The cheapest will be Ebay headers. Stett Performance headers are a better quality header, with similar design to the Ebay headers, although they are made of thicker steel and are ceramic coated. Schmiedmann headers seem to be of closer, if not equal quality to Active and Technik, but, by all accounts, have been extremely hard to source in the States. Active Autowerke and Technik headers are similarly priced, although the Technik headers aren’t currently in production, so you will likely have to find them second hand. Kromer Kraft headers are extremely high quality, but are also very pricey and have to be assembled (welded). For info on these headers search for PEI330ci and his build thread.
Will I get a check engine light?
- YES, you absolutely will.
What are my options to get rid of the warning light?
- 1) Spark plug non foulers .
http://forum.e46fanatics.com/showthr...lug+non-fouler
- 2) Software. If you elect to get upgraded software (AKA a tune), you can have a company such as ESS Tuning, Active Autowerke, etc. can turn off the check engine light, but your car will still not pass emissions.
- 3) O2 Simulator. http://forum.e46fanatics.com/showthr...t=o2+simulator
Where can I find out all the information I need about Ebay headers?
- http://forum.e46fanatics.com/showthr...+header+thread
Intakes
Will I gain a lot of horsepower from the installation of a cold air intake?
- No, you will not. Our stock airboxes are a pretty good design. The gains, if even measurable, will be negligible. Your engine, however, will sound different.
What are some of the better brands?
- As far as some of the better quality brands go, your options are ECIS, Conforti, K&N, AFE, and Gruppe M. There are also Gruppe M replicas, such as Simota.
Is there a difference between a 323, 325, 328, and 330 intake?
- Yes, actually, there is. 323s, 325s, and 328s use a 3” diameter MAF, while 330s use a 3.5” diameter MAF.
Exhaust
Will I see significant increases in power?
- In general, no. Because the catalytic converters are located in our exhaust manifolds, or headers, there is no major bottleneck in the exhaust. There will be some increase in power, but mainly you are getting a better exhaust note.
- These days, there are numerous exhaust options for our cars. Bolt on options include offerings from Magnaflow, Rogue Engineering, Borla, Active Autowerke, Eisenmann, UUC, Highline Tuning, and Remus. In addition to these, there are numerous custom options, all these require are your choice of universal muffler and a trip to the muffler shop.
Underdrive Pulleys
Will I see an increase in power?
- Sorry, but by all accounts, the increase in power isn’t very noticeable.
Why would I want them then?
- Cumulatively, these bolt on modifications that don’t have a significantly noticeable effect, are increasingly effective when paired together. Mainly, though, steering feel is increased.
- Quality options for underdrive pulleys are offerings from Rogue Engineering, UUC, and Evosport.
Coming in Part II…
- Clutches, Flywheels, Camshafts, Pistons, Rods, Valves, and Valve springs.
///Orient3 is offline   Reply With Quote
Old 02-24-2010, 02:33 AM   #2
anival755
My Ride: 323i M-Sport
btw, sorry for being a frustration for my posts.. this, is a very good post i must say..
anival755 is offline   Reply With Quote
Old 02-26-2010, 12:50 PM   #3
///Orient3
Old 02-26-2010, 02:00 PM   #4
bmwAlex
My Ride: '00 323i
Very nice, thanks for the quick FAQ's.
bmwAlex is offline   Reply With Quote
Old 03-01-2010, 09:58 PM   #5
///Orient3
Old 03-01-2010, 10:39 PM   #6
DSpencer18
My Ride: 2005 BMW 330ci (ZHP)
Send a message via AIM to DSpencer18 Send a message via Skype™ to DSpencer18
nice free bump
  • Has: - BSW d210 Subs/Amp - iSimple Ipod Integration - Smoked Side Markers - Smoked Reflectors - LED White Interior Lights - Hoen Xenonmatch Fogs - Hardwired Valentine V1 Radar Detector - AVT Ram Air Scoop - BMW Performance Intake - BMW Performance Short Shifter Kit -
    - Lambda Chi Alpha Zeta Phi 1067 and E46Fanatics.com stickers. -
  • DSpencer18 is offline   Reply With Quote
    Old 03-09-2010, 02:26 AM   #7
    ///Orient3
    Bump...
    Old 03-09-2010, 06:57 AM   #8
    mrshelley
    My Ride: 2004 330i
    Should I use fuel line magnets on the pressure or return line for maximum performance?
    Old 03-09-2010, 01:48 PM   #9
    ///Orient3
    Absolutely you should, but only if you use them in conjunction with the tornado fuel saver.
    Old 03-09-2010, 01:54 PM   #10
    jott5555
    My Ride: 01 330ci
    I picked up 14 whp with the use of that there tornado doohickey myself..
    jott5555 is offline   Reply With Quote
    Old 03-18-2010, 08:42 AM   #11
    SexyDev
    My Ride: 2002 330i
    Send a message via MSN to SexyDev Send a message via Skype™ to SexyDev
    More please! I really like the way you present the info even if already know it I like reading it hahah!
    " Work like a Slave, Live like a King "
    SexyDev is offline   Reply With Quote
    Old 03-21-2010, 09:48 PM   #12
    ///Orient3
    Thanks, I tried to make it as easy to follow as possible. I think it is pretty straightforward.
    Old 04-28-2010, 10:56 PM   #13
    TitaniumSedan
    My Ride: is my portfolio
    So are headers the only useful bolt on modification in your opinion?
    TiAg, Grey/Black Interior, HK, ZSP/ZPP/ZCW, 5MT
    Carbon Fiber Trim (DIY), M68 Wheels, LED AE's, Interior LED's
    Smoked Depo's all around w/ stealth bulbs, Black Grill,
    35% Tint, BMW Perf CF Strut Bar
    My 3D Design Portfolio: briansteere.carbonmade.com
    My YouTube channel - Cars and Guns
    TitaniumSedan is offline   Reply With Quote
    Old 04-28-2010, 11:16 PM   #14
    E46 S54B32
    My Ride: 323ci
    nope...light rims is a big +, SSK, 3.38 or 3.46 diff
    some consider a b30 manifold a bolt on..im doing it next
    -oem m3 front -oem m3 hood -oem m3 sideskirts-conforti intake -h&r race springs -TR Motorsport C2's -smoked corners/sidemarkers -smoked LED tails-CF CSL trunk-Black roof vinyl
    E46 S54B32 is offline   Reply With Quote
    Old 04-28-2010, 11:33 PM   #15
    330i ZHP
    330i ZHP's Avatar
    My Ride: have 5 doors and FI
    you should save all the money you are spending to make your car look like an M3 and buy an M3
    /_________\
    OO=[][]=OO
    330i ZHP is online now   Reply With Quote
    Old 04-29-2010, 12:32 AM   #16
    E46 S54B32
    My Ride: 323ci
    pointless post
    M3 is the easy way out..some people actually like modding there cars
    Old 04-29-2010, 12:52 AM   #17
    330i ZHP
    330i ZHP's Avatar
    pointless post
    no way, really
    /_________\
    OO=[][]=OO
    Old 04-29-2010, 07:09 AM   #18
    aggieE46
    Keep it clean
    aggieE46's Avatar
    My Ride: Evo, 330Ci, Xterra
    Yeah, like you know anything about modding....
    no way, really
    ^No longer looks like this
    Buy my::
    3.46 Differential
    Coolant hard line
    European Head Unit
    Old 04-29-2010, 07:34 AM   #19
    330i ZHP
    330i ZHP's Avatar
    who me, I dont know anything about modding
    /_________\
    OO=[][]=OO
    Old 04-29-2010, 02:27 PM   #20
    murph1379
    My Ride: 2003 330i ZHP
    hmm, I definitely noticed an increase in power with underdrive pulleys. A person off the street probably wouldn't be able to notice it, and it won't win you any races by itself, but there is definite power gain across the whole RPM range.
    murph1379 is offline   Reply With Quote
