Old 02-24-2010, 07:26 AM   #1
m-teknik
My Ride: '04 330i
rev limiting
I have 2004 330i and I miss E30 325i rev limiter. As you know some BMW's have smooth rev limit and some have vibrated. I hope that I described well. So I desire that kind of vibrated rev limiter on my E46. Is it possible to do this with any chip etc?
a few examples for vibrated rev limiter:
m-teknik is offline   Reply With Quote
Old 02-24-2010, 11:14 AM   #2
AdamBath
My Ride: E30
Seems like a waste of time and money to me.
AdamBath is offline   Reply With Quote
Old 02-24-2010, 11:15 AM   #3
xi325xi02
My Ride: 325xi
You shouldnt be hitting your rev limiter.
Originally Posted by onebad328i View Post
you want ladys damm, get a punchin hard ass sound system
I HATE CVT'S
xi325xi02 is offline   Reply With Quote
Old 02-24-2010, 01:40 PM   #4
McSpeed
My Ride: 2005 ZHP TT Stg 1
Originally Posted by m-teknik View Post
I have 2004 330i and I miss E30 325i rev limiter. As you know some BMW's have smooth rev limit and some have vibrated. I hope that I described well. So I desire that kind of vibrated rev limiter on my E46. Is it possible to do this with and chip etc?
I can see how it's cool and I'm not sure how it would be implemented (DME tweaking maybe?) but keep in mind the stock M54 oil pump doesn't like to hang out at red line for too long due to harmonic issues.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 02-24-2010, 02:45 PM   #5
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by mcspeed View Post
................. But keep in mind the stock m54 oil pump doesn't like to hang out at red line for too long due to harmonic issues.
yes.
SUMMIT POINT WV 1:24:229 SCCA
Old 02-24-2010, 03:50 PM   #6
m-teknik
My Ride: '04 330i
thanks for your helpfull respond. I drive in high revs for only street acceleration. Not too long. I am looking for reasonable cheap solution. Didn't anybody else need this ? I only wanted to get (my previous car) E30 325i's acceleration behaviour with E46 safety and comfort.
Old 03-01-2010, 03:47 PM   #7
Nixit
My Ride: 2001 330i
The vibrated type simply cuts spark at Xrpm the. I think this is harder on everything in your engine considering its full bore to nothing and back in .05 sec... but it dos sound cool.
Most newer car i have been in are smooth, I THINK they cut fuel. actually I'm sure i read that somewhere but cant remember where
If you want that sound without killing your engine you should get a studder box. Summit or Jegs will have them.
you can set what rpm you want it "studder" at say 2500. I don't think it will do any good on an a/t but they are made to help you launch with a m/t.
Also your computer might not appreciated being undermined.
Nixit is offline   Reply With Quote
