Old 02-24-2010, 07:08 PM   #1
andys320dcoupe
My Ride: 320d Msport Coupe
LED rear tail lamps faulty blown LEDs
Wondered if anyone had managed to repair a factory fitted LED rear lamp cluster .. mine has 4 leds in a row out, and I think there might be a crack in the circuit board they're attached to, on my 2005 320d Coupe.
Seems to be a sealed unit, just wondered if anyone had managed to open one up and fix the LEDS... they might have blown, not sure.
Any suggestions gratefully received!
andys320dcoupe is offline   Reply With Quote
Old 02-24-2010, 07:21 PM   #2
Hartman
My Ride: 2000 323i
Another set bites the dust. I think we can officially mark these tail lights as garbage.
Hartman is offline   Reply With Quote
Old 02-24-2010, 07:29 PM   #3
danwilz
My Ride: E46 M3 Vert 2012 X5
Find a set used on ebay. as above post trash em.
danwilz is offline   Reply With Quote
Old 02-24-2010, 09:20 PM   #4
46bmw
My Ride: 328i
I have a set of eagle eye tails that had a few LED's burn out. I pulled the board out and used a meter set to diode check and found three bad LED's. Went to radio shack, picked up replacements for 2 bucks each, soldered them in and everything works fine.
46bmw is offline   Reply With Quote
Old 02-24-2010, 09:26 PM   #5
MysticBlau330Ci
My Ride: 330Ci '04 & M4 2016
did you get a rear lamp out warning on the dash?
MysticBlau330Ci is offline   Reply With Quote
Old 02-24-2010, 09:27 PM   #6
Hartman
My Ride: 2000 323i
I meant overall, these Eagle Eye tails have become quite problematic. One of these threads about blown LEDs pops up about every day now.
Old 02-24-2010, 10:21 PM   #7
nadeemp8
My Ride: 05 325i
I think the OP is referring to the factory LED taillamps that come on the 04+ 330ci's and not the aftermarket ones...
nadeemp8 is offline   Reply With Quote
Old 02-25-2010, 09:17 AM   #8
Hartman
My Ride: 2000 323i
Ah yes I guess I should pay more attention.
Old 03-27-2010, 09:18 AM   #9
andys320dcoupe
Yes they are the standard ones, interestingly there's no failed lamp warning on the dash and it has just passed its MOT with four leds out, it just doesnt look perfect!
Old 03-27-2010, 09:45 AM   #10
canaryM
My Ride: is strong like bull
I was thinking that those who want to go back to bulb or will buy a new set of LED tails can sell the side that still works properly (if they have one that does). For example, on mine, almost all of the indicator LEDs on the passenger side are blown but all of the LEDs on the driver's side are in perfect shape. If someone out there was willing to sell me their passenger side, that would be awesome. So on and so on.....
///Sport Package | Nav | Park Distance Control | LED tails
///M3 Lip spoiler | Adaptive Xenons | 62 LED Angel Eyes
canaryM is offline   Reply With Quote
Old 04-02-2010, 07:29 PM   #11
res036
My Ride: LSB M3
Dude that would be a great idea let me knw if u really wanna do that cuz I'll buy ur drive side tail lamp cuz iv got like 4 blown led on that side
res036 is offline   Reply With Quote
Old 04-02-2010, 07:41 PM   #12
E46 Coupe
E46 Coupe's Avatar
My Ride: Rules1 & 2: S T F U!
*off T* How did you go about opening up the EEs without damaging them? Did they go back together without causing leaks?
E46 Coupe is offline   Reply With Quote
Old 12-07-2012, 07:27 PM   #13
BeeamW
My Ride: 04' BMW 330Ci (vert)
Is the answer no then on repairing the LEDs? I got a few burnt since I've had water inside the taillight housing for a month which turned into ice as the weather changed.
BeeamW is offline   Reply With Quote
Old 12-07-2012, 09:49 PM   #14
Zell
Zell's Avatar
My Ride: so turbo wow
I have a fully working LED tail light motherboard I will be glad to sell you. PM me. It is for the passenger side.
I've separated the tail light before. It's fairly easy.
Get a heat gun (or hair dryer) and warm up the edges. Get an exacto knife (or a razor, just something insanely sharp), and work your way around the edge between the plastic housing and the clear plastic tail lamp part.
Eventually you will find a place in which it will separate cleanly. Once you find it, very slowly work the sharp edge around the tail light to separate the housing.
Once separated, the inside can be removed easily. It's just held in by clips. The motherboard can be unscrewed from the back side, held in by a few Torx screws.
To get it back together, get some very strong clear RTV sealant, line up the tail light, and clamp it together.
320, 320d, coupe, led, light cluster
