Old 02-26-2010, 07:12 PM   #1
xixixi
Banned User
My Ride: 01 330x-xi
Dsc light
well i heard you could turn off the traction control completely.. so i held my dsc button down till the yellow light turned off and now i can't get the dsc light to come back on lol wtf! help! car running in drive way
Old 02-26-2010, 07:21 PM   #2
Rob43
My Ride: 2003 BMW 331Ci, 5spd
First turn car OFF, everything will reset.
When you hold down the DSC button for 10 seconds, both the DSC & BRAKE light will
turn on. (YELLOW) Then your traction control is off. It will always reset when you turn your
car off.
SUMMIT POINT WV 1:24:229 S.C.C.A.
http://www.vimeo.com/8486878 (Dyno Video)
........add a sh!tload of cowbell.
Old 02-26-2010, 07:54 PM   #3
xixixi
Banned User
My Ride: 01 330x-xi
nah turned car off several times on a 330xi i don;t have two settings but now i can't get the dsc off lol like the button is broke it briefly lights up before starting then turns off so i doubt it's a fuse? grr wtf i hold that button down for anyway lol! sob!
Old 02-26-2010, 08:08 PM   #4
xixixi
Banned User
My Ride: 01 330x-xi
well... seems you have to take the key out to reset everything? i was just turning it on and off..
Old 02-26-2010, 08:54 PM   #5
///Orient3
My Ride: can't be defined
The light on the dash doesn't activate unless the dsc does (no light=good). It will pop on when the car is trying to maintain traction. The light only stays lit when you have turned it off.
///Orient3 is offline   Reply With Quote
Old 02-26-2010, 09:06 PM   #6
Rob43
Originally Posted by ///orient3 View Post
the light on the dash doesn't activate unless the dsc does (no light=good). It will pop on when the car is trying to maintain traction. The light only stays lit when you have turned it off.
^ yes.
Old 02-27-2010, 01:30 PM   #7
xixixi
Banned User
My Ride: 01 330x-xi
yes the problem i was having was i don't want to drive with it on and i couldn't turn it off i'm aware how the system works and what it does i was just aware to reset the computer the key must come out of the ignition.. thanks for the help
