Thread Tools Search this Thread Rating: Thread Rating: 40 votes, 4.83 average. Display Modes
Old 06-24-2011, 12:23 AM   #201
kpeng
Banned User
My Ride: E46 330 and E30 325
Originally Posted by TerraPhantm View Post
If I had to guess, I'd say that the risk of excessive temperatures would be greater when stopped/stuck in traffic then when the car is moving. At least in the M3, my temperatures are a good 40 degrees higher when stuck in traffic compared to moving at a decent pace. Even if I beat the **** out of the car, my temperatures are still lower than when I'm sitting in traffic. I suspect I'd be able to delete the fan altogether if I never had to worry about traffic.
Agreed. I've been stuck in traffic (stop and go) in 98-100 degree temps with no issues either.
kpeng is offline   Reply With Quote
Old 06-24-2011, 12:24 AM   #202
Nervous
My Ride: 01 330CI 6MT ZSP EU3
So, after two weeks driving with swapped fan my avg mpg is 26 vs 23 before the swap! Woohooo!
Nervous is offline   Reply With Quote
Old 06-24-2011, 12:29 AM   #203
TerraPhantm
My Ride: M3 & ZHP
Holy crap. I need to figure out a way to do this on the M3...
Old 06-24-2011, 02:14 AM   #204
southpaw
My Ride: E36 M3 and E36 318ti
Do you run water wetter?
-Brandon
239whp/227wtq @2700lbs
southpaw is offline   Reply With Quote
Old 06-24-2011, 08:01 AM   #205
Drewfus2101
My Ride: N/A
Wow! I didn't get any noticable MPG gain.
BUT, it was more than worth it to get rid of the noise the mech fan made.
Drewfus2101 is offline   Reply With Quote
Old 06-24-2011, 08:03 AM   #206
nk_zhp
My Ride: ZHP / E30 M3
Something else must have changed, 3MPG just from that swap is hard to imagine. Unless your entire commute consists of stop and go.
'04 330i ZHP - OEM Clears - ///M Strut bar - CoolantSnitch
nk_zhp is offline   Reply With Quote
Old 06-24-2011, 08:15 AM   #207
kpeng
Banned User
I do.
Old 06-24-2011, 10:11 AM   #208
Nervous
Nothing else was changed. Absolutely.
My commute is 90% hwy (otherwise my mpg wouldn't be even 23).
Old 06-24-2011, 12:43 PM   #209
southpaw
idk if you mentioned, but LOSE THE MECHANICAL FAN ASAP.
The fan and fan clutch have reputations of grenading and destroying radiators, pulleys, belts, and more.
-Brandon
Old 06-27-2011, 08:43 AM   #210
kpeng
Banned User
+1
Nothing like a broken fan blade to ruin your day.
Old 07-29-2011, 02:07 PM   #211
AUSS1E
My Ride: a Gulfstream
Any insight as to why my 04 zhp sedan 6speed has a mechanical fan and tranny cooler?
Was that standard for the zhp?
2004 330i ZHP
AUSS1E is offline   Reply With Quote
Old 07-29-2011, 02:09 PM   #212
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
The transmission cooler is probably due to the car being a dumbed down M3 in terms of performance so I assume BMW put the cooler there for performance aspects.
Old 08-02-2011, 08:50 PM   #213
Nervous
Well, its been about two months I swapped clutch fan by the Behr electrical one and today I found out that:
1) A/C doesn't work
2) Electrical fan doesn't work
3) Thank god I didn't overheat the engine, but once I stopped and idled for 2 min the temp gauge started to climb. Func 7.0 showed temp 117C at that moment.
Looking for the reason of electrical fan malfunction now.
Old 08-02-2011, 09:50 PM   #214
TerraPhantm
My Ride: M3 & ZHP
My 03 ZHP had an electrical fan and no tranny cooler. Maybe it began its life as an auto and went through a tranny swap? Or perhaps it was involved in a front-end collision and they rebuilt it using auto parts
Old 08-02-2011, 10:50 PM   #215
Nervous
Update. Connected PAsoft, it said error code 7D: Electric fan. No surprise here. Connected INPA, went to Aktivate, E-blower - no effect whatsoever. At this moment I already started to think "what's about warranty on that brand new Behr fan I got from ebay".... Decided to check 50A fuse in the glove box - it is not blown. I am sad. But.... Wait a sec, contacts of the fuse are kinda dark.... 600 grit sand paper and Electric Cleaner, fuse back into its place, INPA test again and, oh, miracle: fan works, it is back! Whew! A/C is also back, of course.
Old 08-03-2011, 12:21 AM   #216
Marinerd
My Ride: 04 xiT, 09 328i
Whew! I was about to get sad, cause I'm about to do this with the same fan. I thought I bought a piece for a second. I'll be sure to put a fresh Fuse in as well.
Marinerd is offline   Reply With Quote
Old 08-10-2011, 02:35 PM   #217
kpeng
Banned User
Nonsense...kpeng wouldn't steer you wrong.
Old 08-10-2011, 04:41 PM   #218
323iINt.o
My Ride: 328i
Did this a long time ago even before this thread.
Zero issues for years. Do the swap, you'll be fine.
NEED SMOKED CORNERS AND MARKERS, PM ME IF YOU GOT SOME!
323iINt.o is offline   Reply With Quote
Old 08-10-2011, 05:15 PM   #219
Andy2108
My Ride: SpecE46 & E46 M3
Is this swap compatible with M3's?
Maybe then I could get better than 13.5 mpg city
De gustibus non est disputandum.
Old 08-13-2011, 11:35 PM   #220
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
Hey Ken nice info, Thanks! You should make a DIY thread with step by step info with photos and have it locked. Although it was very entertaining reading all the dumb questions. Did anyone ever find out what the CFM difference is between the stock mechanical fan vs the Behr electric fan? I noticed the stocker is 11 blades and the Behr is 7 and they look similar in overall diameter.
I had a 97 Chevy K1500 I did this mod to. The truck would constantly over heat at idle with the AC on out here in Vegas during the summer. I installed the dual Flex A Lite 15" electric fans and I could let the truck idle all day long with the AC on afterward.
Build Thread - S54 Vanos Thread
TTFS Engine/SMG Tune - SGT Headers/Sect 1/SCZA - Evolve Eventuri - Sprint Booster V2
UltraGauge - Orion V4's - CF Lip/Console/Diffuser - VIS XTS CF Hood - CSL Trunk - Valentine One - Turner 15F/12R Spacers
WOLFN8TR is offline   Reply With Quote
