Thread Tools Search this Thread Rating: Thread Rating: 40 votes, 4.83 average. Display Modes
Old 08-14-2011, 12:08 AM   #221
new//M3fan
My Ride: 77' 924 87' E30
Originally Posted by Solidjake View Post
Behr unit is plug and play as well. I don't see how it can't be if it's the same part.
Both Bosch and Behr are OEM units. Make sure to get one of these two, not other companies like Hamburg-Tecnik, etc.
i bought a Hamburg-Tecnik unit. So far so good.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 08-14-2011, 10:38 AM   #222
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Originally Posted by WOLFN8TR View Post
Hey Ken nice info, Thanks! You should make a DIY thread with step by step info with photos and have it locked.
I did it already with the help of Nervous....
http://e46fanatics.com/forum/showthr...735&highlight=
Refresh Your Lights Here - Projector Retrofit - Angel Eye Install Guide
Youtube DIY Videos/Guides - Electric Fan Swap - NY to LA cross country
Orion V2 - Osram CBI Low - ZKW Clear Lenses - Osram Rallye H7 - Morimoto XB Fog
Old 08-14-2011, 11:43 AM   #223
WOLFN8TR
My Ride: 05 SMG M3
Sweet! Nice write up, Thanks!
Build Thread <:> S54 Vanos Thread
-TTFS Engine/SMG Tune- SGT Headers/Sect 1/SCZA- Evolve Eventuri- Sprint Booster V2-
-UltraGauge- Orion V4's- CF Lip/Console/Diffuser- VIS XTS CF Hood- LED Fogs- Valentine One- Turner 15F/12R Spacers-
WOLFN8TR is offline   Reply With Quote
Old 08-14-2011, 12:14 PM   #224
Solidjake
Zero. Leaks.
Solidjake's Avatar
You're welcome. It's rather easy to do. Good time to clean up anything behind the bumper, etc.
Old 08-26-2011, 11:49 PM   #225
jhyan
My Ride: 1999 BMW 323i Sedan
Thanks so much for this... Happy to be rid of the sucking city bus sound!
jhyan is offline   Reply With Quote
Old 08-29-2011, 10:13 AM   #226
kpeng
Banned User
My Ride: E46 330 and E30 325
kpeng is offline   Reply With Quote
Old 08-29-2011, 10:23 AM   #227
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
I literally had a long dream that I did this mod on my car. SolidJake was in the dream helping me DIY it but it was one of those epic dreams where you a trying to do something but never can seem to get it done.
It was weird!
delmarco is offline   Reply With Quote
Old 08-29-2011, 12:32 PM   #228
Shmo
My Ride: 2000 323i
Send a message via AIM to Shmo Send a message via MSN to Shmo Send a message via Yahoo to Shmo
It was weird!
Maybe you couldn't finish because it was really a vision to the future. Since you hadn't actually done this swap before you couldn't perceive the outcome of the install. Maybe Jake had the same dream
You did pray to your BMW shrine first, asking the Great Roundel for guidance on parts' choices first, right?
Shmo is offline   Reply With Quote
Old 08-29-2011, 02:49 PM   #229
warrior2005
My Ride: 05 325Ci
Ok, I gotta ask...what is this bus sound you guys are talking about? I'm not hearing it
warrior2005 is offline   Reply With Quote
Old 08-30-2011, 04:54 PM   #230
ribri02
My Ride: 01 325ci
The sound a mechanical clutch fan makes when fully engaged. It sounds like a freakin semi-truck at a green light.
ribri02 is offline   Reply With Quote
Old 08-30-2011, 05:03 PM   #231
polychrome
My Ride: 2002 325i
Did this mod over the weekend. Definitely not going back to the stock setup. Thanks kpeng!
polychrome is offline   Reply With Quote
Old 08-31-2011, 10:28 AM   #232
kpeng
Banned User
Old 09-29-2011, 12:24 AM   #233
delmarco
I'm next Kpeng! Doing this next month after my coolant maintenance service this Friday. When I do the fan I will upgrade to a Stewart Water Pump for good measure.
Old 09-29-2011, 12:38 AM   #234
HyeWarrior
My Ride: '03 325i --> '13 GTI
I also want to do this mod. I'm tired of my fan sounding like a jet engine. I'm gonna use it as time to also do my belt tensioner. Not sure if the problem is just the belt needing to be replaced or if its the entire hydraulic mechanism, but it squeals every now and then on a cold start, but its always random. I've never done any kind of mechanical work on my car before, but the fan doesn't seem that difficult.
Wow
So Amaze
Much Torque Steer
Such FWDoge
HyeWarrior is offline   Reply With Quote
Old 10-20-2011, 08:52 PM   #235
steve.325i
My Ride: 2003 325i
Ok, just a couple of thoughts here. I was chatting with Olaf today & told him that my weird noise/vibration @ 2k to 3k rpm has been solved. I had to submit & take it to an x-bmw tech to help me on this one. It was the exhaust manifold heat shield blowing in the wind from the mechanical fan!
On the flip side of that, when a mechanical clutch is fully engaged, that's when it should be silent.
So, putting these two thoughts together, are you really sure the sounds are coming from you fan clutch, or could something be blowing / rattleing around you engine compartment?
Just wondering.
steve.325i is offline   Reply With Quote
Old 10-20-2011, 10:57 PM   #236
ribri02
My Ride: 01 325ci
How do you figure? When the clutch fan is fully engaged, it is moving at roughly the same speed as the crank and pulling a massive amount of air through the radiator. This is the bus noise everyone refers to...
Old 10-23-2011, 12:07 AM   #237
steve.325i
My Ride: 2003 325i
Hi, I was refering to teh comment in post #230 "The sound a mechanical clutch fan makes when fully engaged."
The clutch should be silent. I agree that the fan / air turbulence will be loud.
I think the electric fan is quieter due to the improved fan blade design, not because it's electric.
Old 10-23-2011, 02:32 PM   #238
delmarco
This is the secondary air pump you are hearing. It sounds exactly like a jet engine and it can get really loud when it is about to fail. It also sits on rubber mounts that could go bad and break over time (like it has done in my car) and cause the pump to shake and vibrate thus making the sound louder.
It could be an issue that your pump is staying on longer than it should if you are hearing it all the time. The pump on/off function, I believe, is regulated by the engine temperature, O2 sensors, and current emission output.
That said the pulleys will rattle and squeak (like a very dry sound) when old.
Belts as far as I can tell don't make much noise when they are old.
Fan clutches I cant say but I think the little Aux fan does get annoyingly loud and heavy sounding (like a UPS truck) when it needs to be replaced.
Old 10-23-2011, 02:35 PM   #239
Solidjake
Zero. Leaks.
Solidjake's Avatar
Steve, just do the swap already. Take my word for it....
Old 10-23-2011, 02:36 PM   #240
delmarco
Just wondering.
Steve,
Do you still consider the fan swap after reading thru all these pages? Let me know because I may be road tripping it out to Ontario soon and would bring one up for you.
