Thread Tools Search this Thread Rating: Thread Rating: 40 votes, 4.83 average. Display Modes
Old 10-11-2010, 11:17 PM   #121
BeMyWhip
My Ride: 01 BMW 330ci
going to do the cooling system soon... so this is a good time to remove the clutch fan and toss it. sounds way too simple not to do. Ken, I have a normal "non noob" question (sure you can appreciate that lol) When you installed the fan as a puller behind the radiator... did you utilize the stock fan shroud? and did it have to be modified in anyway(the fan shroud)?
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 10-12-2010, 06:33 AM   #122
kpeng
Banned User
My Ride: E46 330 and E30 325
Stock fan shroud is gone. The electric fan is one whole unit.
kpeng is offline   Reply With Quote
Old 10-12-2010, 10:00 AM   #123
theinfamousdrew
My Ride: 911 Turbo / E70
Do these fans die at all? Are they dif between the 323,325,330?
theinfamousdrew is offline   Reply With Quote
Old 10-12-2010, 10:12 AM   #124
mvrk10256
My Ride: E30 325i
sometimes the control module on the fan will fry. happened to my buddy. it stays on and constantly drains the battery. but its rare.
Old 10-12-2010, 08:40 PM   #125
BeMyWhip
cool. does that fan you suggest in post#1 include any mounting items? or did you simply zip tie it?
Always Mod!!!
Old 10-20-2010, 02:56 AM   #126
msuka
My Ride: 2013 335i M sport
Great job Ken, I will be doing this mod once I do my cooling system overhaul with a stewart pump as well, I wonder what a dyno would show heck I would be happy would even 3 rwhp because every bit counts.
msuka is offline   Reply With Quote
Old 11-04-2010, 10:33 AM   #127
kpeng
Banned User
Mounts up to factory mounting points.
Old 11-04-2010, 12:41 PM   #128
28firefighter
My Ride: 2004 330xi
Am I misunderstanding what is being done here, or would this also make working on the car easier? It seems that on auto tranny cars, taking out the mechanical fan is a real pain but the electric one is pretty easy. I'd be inclined to do it for that purpose alone.
28firefighter is offline   Reply With Quote
Old 11-04-2010, 01:29 PM   #129
kpeng
Banned User
Yes sir, you are correct.
Old 11-11-2010, 06:55 PM   #130
gary442
My Ride: 2004 M3 Vert
Question: do you swap the AUC module from the mechanical shroud to the electrical shroud ? And what is the AUC module for anyway ?
Cancel this....did another search. This switches the AC to recirculation mode as needed. I will simply move this over to the electric shroud. thanks
gary442 is offline   Reply With Quote
Old 11-28-2010, 03:25 PM   #131
El Polo
My Ride: 99 black 328i
Does this apply to M52TUs as well? because I've been reading a lot about the swap and am almost ready to do it, but I'm just held back by this:
Everyone that I've read about had M54s, and everybody still think manuals ALWAYS come with an electric. THIS IS WRONG!
Early manual E46 models have, like mine, a mechanical puller + an electric pusher.
My questions are: when did BMW throw away the dual fan system on manual cars? Is the swap really safe for manual M52TUs? Will a M54 electric fan work?
El Polo is offline   Reply With Quote
Old 11-28-2010, 06:32 PM   #132
SweTurbo
Big Pimpin'
My Ride: 323i -98
I've done it on my SC'ed M52TUB25
The pusher fan was removed to make room for the intercooler , and the mechanical blew to bits a couple thousand miles ago.
Had the car overheat during rush hour and finaly got an electric one , the one i got though was either improperly wired or was supposed to push air from the engine through the radiator(wtf?)
So i switched the fan's positive/negative and now it works like a charm , can leave the car idling for 20min or drive through 10mph traffic the needle won't move
Old 11-28-2010, 10:55 PM   #133
joez323i
My Ride: 323i
Just want to clarify, so if I put the electric fan, there will be no bus sound coming from my car when the weather is really hot?
Also, in order to take off the AUX fan, I'm gonna need to remove the radiator?
joez323i is offline   Reply With Quote
Old 11-28-2010, 11:03 PM   #134
Sansho
My Ride: 2001 325i
That's an interesting question ... do you have to remove the pusher fan from in front of the radiator? Replacing the mechanical fan with an electric fan, should be moving the AUC module from mech. shroud to elec. shroud, and plugging the large multiwire plug into the plug that powers the fan. Can both electric fans remain in place and both be functional?
Sansho is offline   Reply With Quote
Old 11-29-2010, 04:47 PM   #135
El Polo
Ok, so I guess I'll try this out...
also, good question from sansho, how do you remove the aux fan?
Old 12-07-2010, 12:25 AM   #136
kpeng
Banned User
No, both cannot be there at the same time. You are correct otherwise.
Old 12-07-2010, 09:31 AM   #137
huskerick
My Ride: 325i/C6/928/951
I like the idea of one single fan - makes sense to me. Also, I am thinking of upgrading to a better aluminum radiator and running a separate trans cooler.
Then, I get the best of all worlds, while providing more protection to the auto trans. In Vegas, anything to keep the motor cool is a plus.
huskerick is offline   Reply With Quote
Old 12-07-2010, 10:11 AM   #138
kpeng
Banned User
Those things definitely would not hurt.
Old 12-08-2010, 07:29 AM   #139
omhl
My Ride: E46 M3 6MT
Send a message via AIM to omhl
damn . people can't read.
lol
this is on my to do list.
omhl is offline   Reply With Quote
Old 12-08-2010, 08:58 PM   #140
Sansho
My Ride: 2001 325i
So, I'm sure I'm over-thinking this, but found it interesting. Using the diagram below which shows the auto transmission cooling setup... Note that the coolant which is routed to the auto transmission heat exchanger includes the the heated coolant from the engine along with the coolant exiting the heater. That means the transmission fluid has to be hotter than the mixture coming from the engine in order to cool the transmission. So, with hot coolant cooling the transmission fluid, I wonder why BMW continued to use a fan/clutch on automatics?
Name:	ATF Cooling.jpg
