Old 03-02-2010, 09:52 AM   #1
xixixi
Banned User
My Ride: 01 330x-xi
stock exhaust with headers
no way my stock exhaust is going to fit these headers... so do i drive this loud beast to the muffler shop or what lol anyone know a decent place in st louis?
Old 03-02-2010, 10:20 AM   #2
xixixi
Banned User
My Ride: 01 330x-xi
no exhaust shop is willing to do a system without cats wtf?? anyone know a place in st louis that will weld up whatever i want?
Old 03-02-2010, 10:22 AM   #3
rkneeshaw
My Ride: 330i ZHP
Sounds like you got the wrong headers. Mine bolted right up. Since you've already installed the headers, sounds like some custom exhaust work is the only option that makes sense.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Magnaflow - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 03-02-2010, 10:33 AM   #4
///Orient3
My Ride: can't be defined
Post in the regional forums! It seems like you have next to no chance to find a shop recommendation in here, but you should get a few in the regional forums. If the flanges are pointed the wrong way, or they seem too short, you got the wrong headers, which is typical. Other than fitting it to the exhaust, it shouldn't be a problem.
[url=http://photos.e46fanatics.com/showphoto.php/photo/90077]
///Orient3 is offline   Reply With Quote
Old 03-02-2010, 11:18 AM   #5
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by rkneeshaw View Post
.......Sounds like you got the wrong headers. Mine bolted right up.
Originally Posted by ///Orient3 View Post
........ If the flanges are pointed the wrong way, or they seem too short, you got the wrong headers, which is typical. Other than fitting it to the exhaust, it shouldn't be a problem.
Yep,.........wrong headers. My Ebay headers bolted right up.
Good luck,
SUMMIT POINT WV 1:24:229 SCCA
Old 03-02-2010, 11:24 AM   #6
xixixi
Banned User
My Ride: 01 330x-xi
i'm looking at everything now that the headers are in i go the right ones it's just the XI has an axle in the way of my motor mount so now i need to go get the grinder and start grinding the mount out it's just a total PITA the exhaust looks like it's gonna fit...
Old 03-02-2010, 11:27 AM   #7
xixixi
Banned User
My Ride: 01 330x-xi
can anyone comment on where their mount is? so i don't think i'm going crazy
Old 03-02-2010, 11:42 AM   #8
xixixi
Banned User
My Ride: 01 330x-xi
ouch seems these headers don't fit xi models.. it's gonna fit
Old 03-02-2010, 11:45 AM   #9
AdamBath
My Ride: E30
You don't need to grind the motor mount. There is a plate on the motor mount held on by pop rivets, it's basically just a dust shield. Drill the heads of the rivets out, then pop it off, your should be able to fit your motor mount back in then.
AdamBath is offline   Reply With Quote
Old 03-03-2010, 01:33 PM   #10
xixixi
Banned User
My Ride: 01 330x-xi
indeed had to get that sucker off was no biggy. all went together all is together had stock exhaust fitted today for 50 bucks, till i get more cash. thanks for the help everyone
