Old 03-02-2010, 02:54 PM   #1
shauny2times
My Ride: 200 323 ci sedan
Exclamation please help! p0420
k so i did a search but everyone seems to have different opinions on this issue. some say change the cats which is $$$ some say change the post o2s, not so bad and some say just search for vacum leaks, easy enough..
so im gonna use some carberator cleaner to do a vacum check, unless thats not the way with bmw's?? this is my first bmer =)..
then what will tell me to change the o2s vs changing the cats? i have access to an obd2 scan tool..? is there any readouts i should be looking for when using it? or doi have to gain access to a different type of diagnostic tool?
any help is much appreciated!! thanks and ttys
shauny2times is offline   Reply With Quote
Old 03-03-2010, 10:46 AM   #2
shauny2times
bump...please give me some insight my freinds
Old 03-03-2010, 11:49 AM   #3
shauny2times
so from doing more reasearch im pretty sure its not the cats, ive read a few posts from people with alot more miles saying they still pass ca smog and have good cats, this would lead me to belive its the o2's so how do i know which ones to change? alot are saying wiht this code to do the post but since $ is tight i would like to know if theres a way to test them individually or to know which ones could more likely be bad.. thanks
Old 03-03-2010, 01:30 PM   #4
xixixi
Banned User
My Ride: 01 330x-xi
man you live in cali your gonna have to shell out the bucks to keep the car on the road. i just put headers on running no cats straight pipes. cats are gonna be WAY CHEAPER then o2 sensors man lol exhaust manifold alone is like 800 bucks i got one for a 330 if you want to buy it.. gonna be least 8 hrs of labor to do the cats.. easy 2k when your all said and done at a dealer. how many miles you got on this car? you can move the 02 sensors from bank 1 to 2 swap em see if the code changes to a different bank if so thats the bad sensor GL
Old 03-03-2010, 08:00 PM   #5
shauny2times
"cats are gonna be WAY CHEAPER then o2 sensors man lol" dont you mean o2 sensors will be cheaper? hmm switch the sensors huh, can i do this by just swaping the plugs or will they not reach? im gonna try this tommorow. good thinking though. i like it!!
Old 03-04-2010, 12:26 AM   #6
xixixi
Banned User
My Ride: 01 330x-xi
yes that is what i was trying to say
Old 03-08-2010, 09:48 PM   #7
shauny2times
will i be able to swap the o2s to check this at the plugs on top or do i have to go austrailian(down unda)??
Old 03-09-2010, 09:13 AM   #8
xixixi
Banned User
My Ride: 01 330x-xi
your precat 02's are the ones up top not on the bottom. should be able to see em from the top
Old 03-09-2010, 11:55 AM   #9
shauny2times
i know which o2s r which but arent the plugs for the post cat o2s on top so i could essentially just switch he plugs to check if the code changes? or di i have to actually switch the sensors in the banks?
Old 03-09-2010, 01:00 PM   #10
xixixi
Banned User
My Ride: 01 330x-xi
either should work
Old 03-10-2010, 11:09 PM   #11
shauny2times
hopefully i can just switch em up top to save a lil hastle in identifying the problem
Old 03-14-2010, 07:49 PM   #12
shauny2times
So I switched the two sensors and cleared the code and it hasn't came back....awsome!!!
