Pre-cat Oxygen Sensor DIY (lots o pix) version 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-03-2010, 12:35 PM   #1
nhbmwguy
My Ride: 2002 325xi C/P/S
Thank you to the author r0x of the thread Pre-cat Oxygen Sensor DIY (lots o pix). Please use that as a reference.
This post has more pictures to give you a better view of the O2 pre-cat sensor locations.
I have a 2002 BMW 325xi with 248k+ on it. It failed emissions and the state of NH gave me 60 days to fix the issue.
There were 3 error codes:
1. P0491 Secondary Air Injection System (Bank 2)
2. P0492 Secondary Air Injection System (Bank 1)(6)
3. P0135 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
Here are some photos of my adventure replacing my O2 sensors and spark plugs. I had not replaced the plugs since ~120k. The plugs and the O2 sensor were completely fried.
Parts list:
Bosch Platinum +4 Spark Plugs $49.99
2 Bosch Premium Upstream O2 Sensors $79.99 each (Part# 13477)
Purolator Air Filter $14.99
O2 sensor removal tool $5.99
My gas mileage went from 18.1 to 24.5 instantly. (Please note I took out my spare tire and tools... given the price of gas, and the fact I have AAA, who needs the additional weight.)
Back 2 years ago I was getting 26-27 mpg on occasion with highway driving 50-60 minutes one way.
Please note, I did not take apart the cabin filter section. You will see some photos with the O2 sensor tool fitting in for removal/replacement. Same goes for the rear 2 spark plugs.
I also replaced still need to replace the Front/Bank 1 (Cylinders #1,2,3) O2 sensor this week. (No one had it in stock)
I also noticed the hoses going into the vacuum pump are brittle and broken. I am replacing them next...
ID:	350678   Click image for larger version
ID:	350679   Click image for larger version
ID:	350680   Click image for larger version
ID:	350682   Click image for larger version
ID:	350683   Click image for larger version
ID:	350684   Click image for larger version
ID:	350686   Click image for larger version
nhbmwguy is offline   Reply With Quote
Old 03-20-2010, 10:58 AM   #2
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Thanks for the post.
phamine is offline   Reply With Quote
Old 05-03-2010, 05:39 PM   #3
BillyJoelR
My Ride: Velvy B.
OP...
I'm curious if the error regarding the PreCat Oxygen Sensor Heater Circuit disappeared after replacing the Oxygen sensor?
| There is no replacement for Displacement | Go Big or Go Home |
BillyJoelR is offline   Reply With Quote
Old 05-03-2010, 09:52 PM   #4
Intense
My Ride: 330 Ci Cabrio
Originally Posted by BillyJoelR View Post
OP...
I had the same error and it dissappeared when changing sensors.
Intense is offline   Reply With Quote
Old 01-31-2011, 12:51 AM   #5
blinkerfluid
My Ride: 2002 325xi
Thanks rOx and hnbmwguy for all the good info. I wanted to ask if you had any drivability symptoms from the bad O2 sensors. Specifically, was your throttle response normal? The main symptom I have: when I am at full throttle and quickly lift my foot off the acc pedal, the engine continues at full power for more than a second. Did you have any issues like this? Thanks.
blinkerfluid is offline   Reply With Quote
