Thread Tools Search this Thread Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 12-10-2011, 03:49 PM   #381
Ramzi@AutomotiveSpecialtyTool
Past Site Sponsor
My Ride: 1994 Acura Integra
OK.. So i go to remove the current crank position sensor on the car and, using a male T-30 torx bit, manage to strip the bolt!
I think I am going to need like a 3/8" drive screw extractor... As an aside, is there a way to test a crank position sensor other than trying to run it on the motor? Like are there some electrical tests I can do before I put this spare used one in to confirm it hasn't degraded since I pulled the old motor?
Ramzi@AutomotiveSpecialtyTool is offline   Reply With Quote
Old 12-10-2011, 03:55 PM   #382
Past Site Sponsor
So yeah... None of my screw extractors are angled sharp enough to grab the inside of the screw. Any ideas?
Old 12-10-2011, 04:02 PM   #383
Past Site Sponsor
After doing some reading, some folks recommend using a similarly sized allen key. Does anyone know the closest size? The next idea was to hammer in the next largest sized Torx bit, but there's no room to even begin to swing a hammer.
Old 12-11-2011, 01:05 PM   #384
Past Site Sponsor
After further inspection, it appears that I was able to loosen the screw a bit before it stripped. I think I should be able to get a pair of vice grips on it and take it out. Luckily, I have a spare screw from the other motor too.
Old 12-11-2011, 03:07 PM   #385
spencers
My Ride: 2006 330i
spencers is offline   Reply With Quote
Old 12-20-2011, 01:44 AM   #386
tommytoyz
My Ride: 1999 e46 323i
My EX had a VW Beetle and it developed a faulty Crank position sensor. The engine would not only would not crank anymore, it would just stop while running. And it did not throw a check engine code either. I am not sure if BMW will throw a code or not. I am sure someone on this forum has the answer. Sounds like a critical sensor is at fault as everything else checked out.
Maybe the cam position sensor? These are easy to get to, right next to the vanos high pressure oil line.
tommytoyz is offline   Reply With Quote
Old 12-20-2011, 10:25 AM   #387
Past Site Sponsor
I finally got the sensor swapped. I tried to crank the car, but i think the battery was low on juice. So its sitting on the trickle charger again until i get another chance to try.
Things left to check:
Both cam position sensors
Check that each sensor is generating signal and that signal is getting to the ECU
check that each injector is firing
What other checks can you guys think of?
Old 12-20-2011, 06:26 PM   #388
Sweetness
My Ride: '01 325i
Holy sh!t...is this thread gonna FINALLY end?
2001 325i ZCW, ZPP
Titansilber Metallic, Black Interior
The 160,000 mile, clean daily driver
Sweetness is offline   Reply With Quote
Old 12-20-2011, 07:13 PM   #389
Past Site Sponsor
Good lord, i hope so. I mean what els could there be?
Old 12-20-2011, 07:31 PM   #390
EmFiftyFour
My Ride: 03' 330xi auto
I think you need to start a new thread big guy.. Get more peoples attention on what the specific issue is.
EmFiftyFour is offline   Reply With Quote
Old 12-20-2011, 08:07 PM   #391
Sweetness
My Ride: '01 325i
Originally Posted by emfiftyfour View Post
i think you need to start a new thread big guy.. Get more peoples attention on what the specific issue is.
+69
2001 325i ZCW, ZPP
Old 12-21-2011, 11:30 AM   #392
Past Site Sponsor
Agreed. New thread started here: http://forum.e46fanatics.com/showthr...3#post13910543
Old 12-21-2011, 06:49 PM   #393
EmFiftyFour
+69
lol gewd won
Old 09-10-2012, 01:03 AM   #394
xcar360
Past Site Sponsor
My Ride: BMW 318i
Oil change a good idea
xcar360 is offline   Reply With Quote
