Old 03-05-2010, 10:32 PM   #1
dmoney10
My Ride: Hates Crustangs
Send a message via AIM to dmoney10
330xi Shake underacceleration(NOT AXELS)
My 330xi shakes heavily under acceleration. I just replaced axles, control arms, ball joints, tired, and got an alignment and it still shakes. any help?
I spelt axles wrong in title please dont make fun of me
Yoga Pants and Stance
Eurosport Performance
dmoney10 is offline   Reply With Quote
Old 03-05-2010, 10:36 PM   #2
seggerty
My Ride: 325xi
Check ignition coils. Had the same problem in 04 325xi, thought axels but it was ignition coils starting to fail but not throwing codes. Checked at dealer while fixing coolant issue, ordered coils and problem went away. Dealer showed coil readouts to me so I then replaced them myself.
Ryan
seggerty is offline   Reply With Quote
Old 03-05-2010, 10:54 PM   #3
dmoney10
did coils and sparks last month thanks for the advice though man
Old 03-06-2010, 12:08 AM   #4
LivesNearCostco
My Ride: 2003 ZHP 6MT
This may be a long shot, but did you try turning off the DSC (traction/stability control) partly or fully? If it's mostly in the rain, just wondering if it could be the DSC kicking in. But then I guess you'd see the light flicker on and off.
Or since you have an xi, did you replace all four axles or just two? Wondering if it could be a CV joint.
Does it feel like the shaking is in the suspension/wheels or in the engine (like a misfire)? If in engine, could it be some sensor wire is shorting intermittently when wet? Cam sensor(s), knock sensor, wheelspeed sensor, etc. No codes?
LivesNearCostco is offline   Reply With Quote
Old 03-06-2010, 12:09 AM   #5
Acarder
My Ride: 69' M3
It's always possible they were installed incorrectly
Acarder is offline   Reply With Quote
Old 03-06-2010, 12:17 AM   #6
dmoney10
feels like a drivetrain shake i feel it threw the gas pedel shifter and the whole car too. I replaced both front axles . drove home today in the sun and it still shook im starting to get pissed
Old 03-06-2010, 12:29 AM   #7
mujjuman
My Ride: not an E46
Any check engine light?
Check steering guibo?
mujjuman
2003 325xi 5MT
Jet Black, ZSP, ZPP, ZCW, OEM Xenon ^^RIP
sig by Solidjake
mujjuman is offline   Reply With Quote
Old 03-06-2010, 12:30 AM   #8
mujjuman
My Ride: not an E46
mujjuman
2003 325xi 5MT
sig by Solidjake
Old 03-06-2010, 12:32 AM   #9
Kubica
My Ride: 2003 325xi
Motor mounts, wheel bearings, sticky caliper, guibo., etc.
Try and be more specific about the vibration.
Old 03-06-2010, 12:35 AM   #10
dmoney10
no codes man and its like a full car shake that can be felt manly through the pedels and shifter
Old 03-06-2010, 01:21 AM   #11
pilot_alex
My Ride: 2014 435I Msport
Send a message via MSN to pilot_alex
Try your engine mounts/transmission mounts. Also could be tires.
pilot_alex is offline   Reply With Quote
Old 03-06-2010, 02:24 AM   #12
pcdsl
My Ride: 2002 330xi (SOLD)
front transfer case fluid
pcdsl is offline   Reply With Quote
Old 03-06-2010, 07:57 AM   #13
botaman
My Ride: 330xi/530 Blown
Although you have replaced the front axles doesn't mean you can eliminate it completely.
Who did your axle? And how good of a job did they do? Did they forget to torque the axle nuts to specs?
What brand of axle did you use? Did you replace them with OEM? Most Chinese made axles are garbage.
botaman is offline   Reply With Quote
Old 03-06-2010, 08:01 AM   #14
ChasCan
My Ride: 2001 330xi
Did you also replace front lower control arm bushings??
ChasCan is offline   Reply With Quote
Old 03-06-2010, 08:10 AM   #15
Nachos23
My Ride: 2009 335Xi Sedan
Send a message via MSN to Nachos23
Vibtration under load in an Xi is normally due to inner CV boots (just went through this issue). If you've just replaced the fromt half shafts (you never mentioned manufacturer), hopefully it's not them. Heard of numerous guys that have replaced OE BMW half shafts with Chinese (think FCP Groton) and had almost the same issue as before replacing, however, assuming your half shafts are from a reputable supplier and are not the issue, I would look @ engine and tranny mounts. Also check conidition of driveshaft hanger bearing and guibo (@ front of driveshaft that runs from tranny to transfer case). You can check hanger bearing and general driveshaft condition by doing a brake stand. That's where u apply the brakes and with the brakes on and the car in drive, start to apply gas (press brake hard).... as you begin to apply gas, if there is an issue with hanger bearing or driveshaft, then you will fell vibrations under the car as the drivesshaft "bangs around". No vibrations, you can eliminate that. A good visual check of th ewhole system should allow you to see the fault.
My Rides:
2009 335i Xdrive
2000 Z3M Roadster
Nachos23 is offline   Reply With Quote
Old 03-06-2010, 09:26 AM   #16
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Nachos,
I'm trying to figure out how I'd do a brake stand in my manual. Seems like I'd stall...but more important, I'm thinking whether I could do this with only two feet...or do I need to chock the front wheels as my brake and then just play with gas and clutch.
Thoughts?
Thanks.
Doug
See me in June!
dmax on Facebook
Mangofy your E46!
Old 03-06-2010, 11:09 AM   #17
dmoney10
i had my oem axles rebuilt at a local shop
Old 03-06-2010, 11:21 AM   #18
mekaneck
My Ride: 2003 325xi
@ Nachos23 - You can't do a brake stand in an AWD car, and in a RWD or FWD manual you need a throttle lock, 3 feet, or you have to be good at heel-toe. If you're talking about just putting torque through the driveshafts without actually making the driveshafts rotate, you could just put on the ebrake and try to drive forward (gently). However I don't think this will identify any problems.
@ OP - check out your guibo as others have said. And also let us know what brand of axles you purchased.
2003 325xi Black
mekaneck is offline   Reply With Quote
Old 03-06-2010, 07:06 PM   #19
dmoney10
any other suggestion.... moisture is not an issue anymore it does it all the time
Old 03-07-2010, 01:33 PM   #20
Kubica
My Ride: 2003 325xi
What shop was this?
I'm still guessing motor mounts.
