Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 5.00 average. Display Modes
Old 05-11-2010, 08:50 PM   #21
Iceman00
Banned User
My Ride: E90 6MT
Only the intake cam is different on a B30 vs M5x. It has 240 degrees duration and 9.7mm of lift, vs 224 degrees of duration and 9 mm of lift. But I don't think it's worth the upgrade on its own (unless its a GOOD price)
Old 05-22-2010, 12:12 AM   #22
E46 S54B32
My Ride: 323ci
the real qustion is how much would a m52(my 323) gain if i switch the manifold to the b30 one? (i already have the manifold i just want to do a before and after dyno to more or less know what i gained and tho share with everyone...i just want to know now so i more or less know what ill be gaining...
great thread
-oem m3 front -oem m3 hood -oem m3 sideskirts-conforti intake -h&r race springs -TR Motorsport C2's -smoked corners/sidemarkers -smoked LED tails-CF CSL trunk-Black roof vinyl
E46 S54B32 is offline   Reply With Quote
Old 05-22-2010, 12:13 AM   #23
Iceman00
Banned User
My Ride: E90 6MT
Let me know when you want to dyno, and where, we can meet up and do it. I have Header and Intake manifold, (stock intake) so we can at least compare powerbands.
Old 05-22-2010, 12:31 AM   #24
E46 S54B32
My Ride: 323ci
alright..where in FLA u located..victor (bmw streets) is helping me with the swap since hes down here in miami...the guy knows his stuff about alottt of stuff.. just need to change my diff bushings 1st but that ok bc when i switch my bushings im throwing a 3.46 in her
ill let u know buddy
Old 06-02-2010, 01:32 AM   #25
Iceman00
Banned User
My Ride: E90 6MT
I'm moving to Brandon (near Tampa) but if you set something up, let me know.
Old 06-15-2010, 06:08 AM   #26
02gtstang
My Ride: 2005 zhp coupe
so i can switch over from my 325i intake manifold for one from a 330i for more power is what your saying? without having to have it retuned and what not? i have the m54b25 engine i believe, its not the cali emission one
2001 325i sport 5spd topaz blue R.I.P.
2005 330ci zhp 6spd black on black
02gtstang is offline   Reply With Quote
Old 06-15-2010, 06:27 AM   #27
Snik
Snik's Avatar
My Ride: IR M3 Vert.
Couple questions for OP and other who may know.
1. the M54B30 is drive by wire correct? will that be an issue with swapping the B30 manifold to a cable driven TB on the M52TUB28?
2. whats this following DIN70200, is it just a correction for the dyno?
3. is the manifold swap a straight FWD thing.. TB will interchange fine, as well as intakes, etc?
Do you ride a sportbike?
Snik is online now   Reply With Quote
Old 06-15-2010, 10:30 AM   #28
Iceman00
Banned User
My Ride: E90 6MT
You can make the change, but the gains are minimal. They could be more with supporting mods.
1. Yes, but it's not a major issue. You'll need a TB adapter from Turner Motorsports, and depending on the year of your B30 manifold, you might have to modify the adapter to fit. Otherwise, I go over the procedure in my install (as Does b/\/\Wstreets, and his is more detailed) that the throttle body will be grounded down a bit to fit on the manifold properly. Very little work.
2. Probably
3. Yes, everything will match up perfectly, though you'll want to takes some time and adjust the throttle cable.
Old 06-15-2010, 12:47 PM   #29
Snik
Snik's Avatar
oh, that adapter, i saw it on TMS yesterday... ok... i think i is gonna do this. let the parts gathering begin.
This will be very nice with my intake and already shark injected setup.
+ headers in the future if my cats take a crap.
win win win.
Thnaks man.
Old 06-29-2010, 02:31 PM   #30
SHK&BAK3
My Ride: rustles jimmies
I don't know if its just me but I found this hard to follow. Would I be correct to say that if I took a intake manifold from a 330ci and put it in my 325ci I could gain about 4 whp?
If this is true where could I pick one up and is there a DIY. Thanks
SHK&BAK3 is offline   Reply With Quote
Old 06-30-2010, 01:45 AM   #31
TiAgTouring
My Ride: has a D-Pillar
There is a fair amount of info about this swap, and its certainly not easy. For sure the hardest DIY I've ever done.
There are some good write ups, but no written DIY. Unless you know what your doing, or have 3 days free, I wouldn't do this swap.
Gains are decent, but headers are better and way easier. I'd only do this swap if you've already done headers/ exhaust/ and a tune
I also had to customize the adapter plate because it align exactly. I've got an M52TUB25 and the intake manifold was from an M54B30- but I don't know the year. Appearently there are two different M54B30 intake manifolds- because other peoples have aligned exactly with the same Tuner Motorspot adpater plate. All the part numbers I've seen from RealOEM show the M54B30 intake manifold as they same from 01-06, so I really have no idea.
You keep your throttle body and MAF (at least I did, and thats the easiest). Thus, if you have an M54B25, you'll use your electronic TB, where M52TU people will use their stock mechanical/ wire TB.
TiAgTouring is offline   Reply With Quote
Old 06-30-2010, 06:22 PM   #32
Jblack4083
My Ride: E46 ///M3 Vert JB/CB
Send a message via AIM to Jblack4083
So if I already have a 2001 325i, and I upgrade to a Intake Manifold from a 330, I should notice power gains?
For Sale:
  • Automatic Climate Control - $40
  • Turn Signal Indicator and Wiper Lever w/ center circular piece - $35
Jblack4083 is offline   Reply With Quote
Old 06-30-2010, 06:27 PM   #33
Iceman00
Banned User
My Ride: E90 6MT
You obviously didn't read the very first post in this thread. Yes there will be a power gain, though it's hard to determine if you will "notice" it.
Old 10-24-2010, 01:38 PM   #34
HiFiGuy1
My Ride: 2003 330i ZHP 6MT
IceMan,
My wife's car is a 2003 330i ZHP sedan. Does this mean she already has the M54B30 part that you describe? In this case, would the BMW Performance intake that others have posted make any difference in her car?
HiFiGuy1 is offline   Reply With Quote
Old 10-24-2010, 05:57 PM   #35
Iceman00
Banned User
My Ride: E90 6MT
Originally Posted by HiFiGuy1 View Post
IceMan,
Being that you're wife has a ZHP, she would indeed already have the M54B30 intake manifold. The intake tubing (which leads up to the manifold) can still be altered to provide some gains in power. In conjunction with a Shark Injector, I made around 15whp with an intake, of course your results may very.
The BMW intake has been tested to provide some hp gains, though it's debatable if it would be the best(which can be subjective as well) choice.
If you want an OEM styled intake with decent gains, I would go with the BMW performance one, as well as a Shark Injector.
Old 10-31-2010, 10:28 PM   #36
zac328
My Ride: is awesome
I've recently installed a 330ci intake manifold on my 328ci and dyno'd before and after.
it was around a 10kw atw gain. although i already had a bit of work done to my car which will contribute to the gains.
There was a very slight loss in power around the middle of the rev range... I assume its because of the bigger manifold.
Very happy with the result. The higher end pulls a lot harder
I will make a new thread soon with dyno graphs etc
zac328 is offline   Reply With Quote
Old 10-31-2010, 10:55 PM   #37
TrickTizzle
My Ride: 325i
whats DIN70200??
Old 10-31-2010, 10:55 PM   #38
TrickTizzle
My Ride: 325i
and how did u dyno a b25 at 193 hp? is that at crank or whp?
Old 11-10-2010, 08:32 AM   #39
omarmarji
Banned User
My Ride: E36 332i
is it possible to get a s54 intake manifold or or the new 2010 328i N54 intake manifold and swap that into my 2002 330ci?
omarmarji is offline   Reply With Quote
Old 11-10-2010, 08:36 PM   #40
TiAgTouring
Doubt it. Im pretty sure S54 uses individual throttle bodies.
Not sure about a new E90/1/2/3 328
