Driveline, Engine & DME Tuning
Talk about driveline improvements, NA tuning and DME tuning your E46 BMW here. This includes diffs, intakes, exhausts, chips, software and OBD tuning. |
Rating:
Display Modes |
#41 |
Keep it clean
Yes, but it's very expensive to do and you probably won't be happy with the results.
#42 |
My friend makes an adaptor to perfectly fit the m30 manifold and use all four bolts to hold the tb on. Pm me if you are interested. 75 plus shipping and here is a crappy pic of it on the manifold. All you have to do is dremel the plastic opening on the top a little.
#43 | |
Banned User
#44 |
Yea? Are you supposed to dremel the opening to match?
#45 |
Yeah you would half to dremel the top part a little but. It is a skinny lip and would take a few minutes to do. We could move the hole down a bit to match for the next ones. I am in Philly and my buddy is in Rochester ny so he had to go with verbal communication. I don't know if you can move the hole down because the tb will hit the plenum. Here is the pic of the throttle body bolted to the plate. It can't be moved lower.
#46 | |
Banned User
#47 |
U have to put silicone I think. Even the TMS swap plate instructions say to put silicone.
#48 | |
Well did some research here to answer my own question. Don"t think its going to work on an m56 since the lower injector o-rings are a completely different part # from the m54 Last edited by Qik-BMW; 12-07-2011 at 08:17 PM. |
#49 |
^^ Whats the point of the M30 swap??? deletes Disa, and how would that work with our cars DME... Im cofuzzled PLZ explain?
#50 |
better flow characteristics
s54door
#51 |
Like enough to get rid of adjustable runners??
#52 |
Why would you want to do that?
#53 |
does the m30 manifold have them?
#54 |
#55 |
Thanks for the 2.5L vs 3.0L comparo !
#56 |
Maximal perfomance difference compared to the standard intake is 6,5ps at 4300 RPM.
Here are some comparisons between the two dyno charts: performance difference in hp at Rev: 4.5ps at 3300 RPM 2.0 3640 4.2 3980 6.5 4320 4.2 4660 3.7 5000 3.3 5340 3.5 5680 4.2 6020" Thats a big drop at 4.5ps at 3300 RPM 2.0 3640
![]() Functional justification... true. But girls dropping their panties counts for something BBK on non-supercharged-non-m..... because chasecar |
#57 |
Hey guys what degree have intake cam in M54B25? I search and found 224 or 228. I'm going to install full M54 b30 intake with cam to b25 and tune.
#58 | |
