Kansas E46 Fanatics listen up! - Page 362 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Great Plains & Rocky Mountains
CO IA KS MO MT ND NE SD WY
Thread Tools Search this Thread Rating: Thread Rating: 35 votes, 4.54 average.
Old 03-24-2011, 12:52 PM   #7221
PerkM3
Account Under Review
My Ride: 2004 SG M3 ESS-550
Originally Posted by xixixi View Post
i know nothing of track talk. i run metal masters with tms slotted.. with no abs... when you wanna stop you stop!!! if you got a heavy foot you hit ****
For street driving brakes are brakes but when you're are talking about 20 minutes of repeated highspeed braking from anywhere up to 120 to 20 that's when you can tell the difference. Heat is the problem, on the street you don't brake often enough for your brakes to heat up because in between stop lights your brakes have plenty of time to cool down before you have to apply them again.
PerkM3 is offline   Reply With Quote
Old 03-24-2011, 12:57 PM   #7222
xixixi
Banned User
My Ride: 01 330x-xi
Originally Posted by ///Mspired View Post
I would be getting a CF one
Alright Brad, what should I get then?
I haven't looked into brakes as far as tracking really at all, give me a list of brake parts with brand name and I will buy it.
Oh and thanks for the purchase Jay
NP, I big time fvcked up not getting the rest from you guys!
Old 03-24-2011, 12:59 PM   #7223
xixixi
Banned User
My Ride: 01 330x-xi
When we were doing some runs on that back road my pad wear sensors started melting I know ryan/jacob/bigjake remember that ****... uhhh dude your wheel is smoking... wtf wtf! at any rate take those out before ya track it cause they gonna melt!
Old 03-24-2011, 01:02 PM   #7224
PerkM3
I don't want to tell you what to buy, I was just saying that there are plenty of places to look and gather info on what works and what doesn't. I started off with ss lines, motul 600 fluid, oem pads, and rotors.
I didn't really get any brake fad until my second session.
Then I changed to axxis street/light track pads. They blew and overheated after the first 10 minutes.
Then I went to CSL 2-piece rotors and Hawk HT-10 pads. These were great, never overheated and performend perfectly. The only reason I switched from Hawks to PFC's is becaues everywhere I read people were raving about them and my Hawks were all used up.
I then added brass guide pins and PFC-01's. These were far superior to the Hawks in every way but pad life.
Now I'm running ss lines, motul 660, brass guide pins, oem csl 2-piece rotors, pfc-06 pads, and custom brake ducting to direct fresh air to the back of the rotor.
What I'm trying to get at is its a system, and you may not be able to do everything at once. If that's the case and you can afford the best stuff right from the get go then go get a bbk. New rotors wont really do crap. Race pads will help but once you boil the stock fluid you will be out of luck. Race fluid and pads is good, but the oem lines are soft and mushy which will do the same to your pedal.
It's a system..........................ss lines and fluid should most definitly be done first, then add pads, then add rotors. Honestly rotors are rotors, they are just a piece of steel. The only benefit from a rotor is if you get 2-piece floating rotors which allow the rotor to float which will allow the pad to get a better contact patch. 2-piece rotors also ussually have alluminum hats instead of steel which cuts down on rotational mass.
If you have the money then I say do it all, but you will never need a bbk. Not unless you are doing enduro racing. I would get ss lines, fluid, and pads for sure. If your rotors are shot then you will have to get those to.
Old 03-24-2011, 01:04 PM   #7225
PerkM3
I took those out so long ago, they are great for a person who knows nothing about their car and doesn't worry about maintenance. If you don't know that you brakes are worn then geeze.
Old 03-24-2011, 01:07 PM   #7226
///Mspired
My Ride: BMW
Fluid, lines, pads it is. I just don't know if I need rotors or not. There is an apparent lip on the outside of the rotor an the rotors in front seem to have a brown line in the middle of the rotor.
^ oh sh1t!
///Mspired is offline   Reply With Quote
Old 03-24-2011, 01:19 PM   #7227
xixixi
Banned User
My Ride: 01 330x-xi
^ oh sh1t!
Have someone Mic it for ya. I doubt they are out of spec. Another you might try at the track is pulling your abs and give that a go. I will never use ABS, none of my cars have had it. It will also disable your DSC as that works with the ABS system to apply the brakes to the slipping wheels. On the same note a lot of people will agree with that on your first time out. If you practice with abs/dsc then go without it. It will be like your first day all over again. This isn't a very popular answer and most will disagree. I works for me. ABS only allows you to steer the front of that car into w/e your going to hit. Without ABS you just lock up and hope for the best no steering needed
Old 03-24-2011, 01:23 PM   #7228
Andy2108
My Ride: SpecE46 & E46 M3
no way I would do an auto x or track time with the asc / dsc enabled. abs I'm not sure... but it does like to cut in early sometimes
De gustibus non est disputandum.
Old 03-24-2011, 01:24 PM   #7229
PerkM3
This is why it is not recomeneded for first time or DE drivers. That's the reason you see this on pretty much only race cars. Last thing you want to do is flat spot a new set of tires.
Old 03-24-2011, 01:25 PM   #7230
PerkM3
^ oh sh1t!
Jay is right, the only way for sure is to use a micrometer to check the thikness against spec.
Old 03-24-2011, 01:30 PM   #7231
xixixi
Banned User
My Ride: 01 330x-xi
I forget about the details. Yep def don't want to waste a couple hundred in tires! some hybrid pulls out in front of me i lock up slid a good 60 feet smoke engulfs this z4 vert behind me. guy pulls up gives me the finger and flys off i about died!
Old 03-24-2011, 01:34 PM   #7232
PerkM3
For some more
http://www.m3forum.net/m3forum/showthread.php?t=358357
Old 03-24-2011, 01:34 PM   #7233
///Mspired
My Ride: BMW
What pads and what fluid should I run brad?
I must have that roundel
Old 03-24-2011, 01:34 PM   #7234
akmholdings
My Ride: Mercedes
I'm from Kansas City....
Originally Posted by lllSupra View Post
Hello folks! I'm just looking for all the "e46ers" in Kansas.... I feel so left out . I cant find anyone else that does these cars around Johnson County! Met a really cool guy awile back and will be meeting him next weekend you can find his thread here: http://forum.e46fanatics.com/showthr...664&highlight= . Other than him the only other person I know Has a 325xi with cheap ass wheels and hes a total douche! HE EVEN KEYED MY CAR AND IS TELLING EVERYONE I COPIED HIS "CAR IDEAS" AND MODDED MY CAR WITH HIS IDEAS BEFORE HE DID! . So anyway calling all Kansas E46 Fanatics!
But i live in San Diego now. If you ever head west, look me up!
akmholdings is offline   Reply With Quote
Old 03-24-2011, 01:40 PM   #7235
///Mspired
My Ride: BMW
Lul
Old 03-24-2011, 01:40 PM   #7236
Andy2108
motol 600 or howwever its spelled. its in brad's sig
Old 03-24-2011, 01:41 PM   #7237
Andy2108
7200 posts later, welcome to the kansas fanatics thread
Old 03-24-2011, 01:43 PM   #7238
PerkM3
I like motul RBF which comes in 600 or 660 which stands for it's dry boiling point. The 600 is obivously cheaper.
LOL, that sig is so old.
Old 03-24-2011, 01:48 PM   #7239
///Mspired
My Ride: BMW
ss lines, motul rbf 660, pfc pads. Which pfc pads?
Old 03-24-2011, 01:49 PM   #7240
xixixi
Banned User
My Ride: 01 330x-xi
i use super blue. brand ATE... it's 536. www.ate-brakes.com
gameboy86, i'll supra, kansas, lllsupra sucks, miz-zou, ohaimgremillion09, rockchalkjayhawkgoku
Rate This Thread
