Rating:
#12221 |
Somone needs to hurry up and mass produce a S54 swapped 986 chassis
![]() ![]() De gustibus non est disputandum. |
#12222 | |
#12223 | ||
I don't disagree with you on the driver making the big differnce but I'm not talkin about guys with little race experience (like myself), I'm talking about guys with NASA, BMW CR, and Grand AM experience/championships. Even if it is a confidence inspiring thing like you mentioned I would take anything that could potentially give me 3+ seconds.
![]() BimmerWorld : MOTON : VAC : Super Sprint : Rogue Engineering : Sparco : Vorsteiner : Schroth 341 whp / 262 wtq - NA S54 2,710 lbs Thanks to my sponsors: GF-Performance.com Wealth Management Advisors, Inc. Auto Tech Service Center |
#12224 |
looks i still need more spring too.
Travis Nordwald
2003.5 BMW M3 2010 Mazda 3 1996 SCCA ITA Mazda Miata |
#12225 |
with all due respect, i put a lot more weight on the findings of the guys at the front of the SCCA Spec Miata / ITA field, than the guys from the series you mentioned. the high levels of competitiveness necessitates development and understanding.
unless it's James Clay, his opinion carries some heft.
Travis Nordwald
#12226 | |
Miata has independent double wishbone suspension front and rear. ![]() M3 has Independent front strut suspension and Independent rear multi-link suspension. ![]() Here is the suspension diagram for the rear suspension of a miata ![]() I've got 2 guesses. Maybe you were right, true coils so therefore lower springrates needed, but I've got another idea that might just negate that fact. Compared to an M3, the spings are much closer to the wheels in a miata. The M3's springs (on a non-true coil setup) are wayy back in there, where the leverage is different. I think spring placement might have alot to do with it.
![]() ![]() De gustibus non est disputandum. Last edited by Andy2108; 10-06-2011 at 04:53 PM. |
#12227 |
it all has to do with wheel rates/motion.
if the springs on the M3 are much farther inboard of the wheel, the control arms or "links" in this case act like a lever. i don't know what the ratio is, but to make it simple an inch of travel at the pickup point on the subframe might equal 2'' of travel at the wheel. so the spring would have a little more heft to control that motion. i'm sure i'm getting this wrong, but if the miata "wheel ratio" was 1:1, whereas the BMW was 1:2, a 900lb spring on the BMW might be like the 450lb spring on the miata. ....just speculating here though.
Travis Nordwald
#12228 | |
#12229 |
Finally met some skip skaps in chicago. I was starting to doubt myself at the two week mark. Got a job interview today and am loving school. Feel like I'm adjusted after 2 weeks!
#12230 |
Good to hear, keep you nose in those books.
#12231 |
Spent an hour last night studying engines after a 6 hour class... Plus already reading stuff we haven't gone over. Taking care of business.
#12232 |
I wish I could actually lean about engines.... and not john quincy adams
![]() In due time...
#12233 |
Just saw a round tail BMW 2002. Makes me want one quite bad.
#12234 |
Had an s14 under the hood.
#12235 |
noice. there are a few I've seen running around various towns
#12236 |
He had SSR reverse mesh wheels, it was inca orange, I wish I would've gotten a pic, the car was perfect. The s14 sounds awesome, he had cf velocity stacks, the intake sound was so loud. I wish I had got some pics of it. The owner was in Topeka for some scca thing.
#12237 |
Sounded like this
#12238 |
Anyone need a valve adjustment?
#12239 |
#12240 |
Im gonna do one this winter along with checking the cam gear hub and bolts. I may replace the rod bearings as well. I never thought is say this but I'm gonna need your help.
![]() Troof.
| Tags |
| gameboy86, i'll supra, kansas, lllsupra sucks, miz-zou, ohaimgremillion09, rockchalkjayhawkgoku |
| Rate This Thread | |
