Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Great Plains & Rocky Mountains
CO IA KS MO MT ND NE SD WY
Thread Tools Search this Thread Rating: Thread Rating: 35 votes, 4.54 average.
Old 04-03-2012, 02:13 PM   #14641
PerkM3
Account Under Review
My Ride: 2004 SG M3 ESS-550
Originally Posted by Rubenk View Post
I'm down! I wanna drop a bolt in somebody elses engine and try to fish it out for 3 hours...
As long as it is his, we are doing mine Saturday morning and for that no one is allowed to interupt.
PerkM3 is offline   Reply With Quote
Old 04-03-2012, 02:16 PM   #14642
Rubenk
My Ride: M35A2
Any chance we could do my end links sometime this week? Should just be 30 mins on the ramps I think.
Rubenk is offline   Reply With Quote
Old 04-03-2012, 02:23 PM   #14643
Andy2108
My Ride: SpecE46 & E46 M3
front endlinks? you need to take the weight off both wheels. I could bring my jack, and use brads jack too
Old 04-03-2012, 02:24 PM   #14644
Rubenk
My Ride: M35A2
I thought it was a loaded job? or is that lcabs....
Old 04-03-2012, 02:24 PM   #14645
Andy2108
Originally Posted by PerkM3 View Post
Valve adjustment party at my place after FF's. We will be doing Jacobs car so I'm gonna be drinking beer and helping as little as possible.
so were going to your place and not jacob's?
Old 04-03-2012, 02:28 PM   #14646
Andy2108
I promise. I just moved mine yesterday.
Old 04-03-2012, 02:29 PM   #14647
Rubenk
My Ride: M35A2
I cant see the pics, but it sounds like you can do it on ramps in this DIY.
http://forum.e46fanatics.com/showthr...light=end+link
Old 04-03-2012, 02:48 PM   #14648
Andy2108
Maybe cars with oem links and sways are different. Without both wheels of my car off the ground, I couldn't get the bolt to line up. Too much load dialed in (adjustable links).
FCAB's DEFINITELY need to have the car up in the air.
Endlinks are probably the easiest suspension part to do otherwise though.
Old 04-03-2012, 03:07 PM   #14649
PerkM3
Dude, I hate to say it but with this new job, family in town for Easter, and a new nephew and niece I'm super swamped this week.
I have two jacks.
It depends, if you have non adjustable end links then it can be done with both wheels in the air. If you have adjustable endlinks then you do one in the air and the other while the suspension loaded. Search "dial out pre-load". This must be done or it will put added stress/load on the suspension.
Old 04-03-2012, 03:24 PM   #14650
PerkM3
Jacobs is Saturday night, we are doing his valves Friday night after Fast Friday's.
Old 04-03-2012, 03:28 PM   #14651
Andy2108
Ohhh. gotcha.
brb
Old 04-03-2012, 03:30 PM   #14652
Rubenk
My Ride: M35A2
I have two jacks.
No worries! I'm heading to Arkansas next week so I had planned on doing them while there. I figured both tires in the air was the better way to do it, I just got stock replacements(actually got em like 6 months ago), so it should be quick and easy.
Old 04-03-2012, 03:31 PM   #14653
PerkM3
Ohhh. gotcha.
brb
This:
The angle is irrelevant.
They are only needed to if you have "preload" in the bar. Having one side adjustable allows you to eliminate the preload.
What is preload? If your car is on prefectly level ground (or an alignment rack), and you unbolt one end of the bar, does the bolt slide in and out without friction? If you have to bend the bar a bit to get the bolt out then the bar is preloaded. i.e. it is exerting a force side-to-side when the car is otherwise static.
If your car is new from the factory it should not be an issue. If you have adjustable ride height then your car is probably not perfectly symetrical and there could be some preload.
Quoted from here:
http://forums.bimmerforums.com/forum....php?t=1400302
Old 04-03-2012, 03:34 PM   #14654
Andy2108
Originally Posted by Hit_Apex View Post
Originally Posted by e36x2 View Post
What is the benefit or recommendation of this?
None on a road car. Properly adjusted end links create no pre-load with the car level and at rest. Swaybar preload may be desirable in an oval racer but not in a road car. Preload is created when the endlinks are set to different lengths left to right. Under perfect conditions end links adjusted to the same length will induce no preload. In practice, the end links should be adjusted such that there is no torque on the bar when the car is sitting on the ground.
Ah. I have nothing to worry about. probably.
Old 04-03-2012, 04:49 PM   #14655
Rubenk
My Ride: M35A2
Seems streetable to me...
Old 04-04-2012, 01:10 AM   #14656
20ducks
My Ride: E46 M3 Cabrio
Brad...I need room in my garage, when are you going to pick up the compressor etc? Pay me later.
20ducks is offline   Reply With Quote
Old 04-04-2012, 07:24 AM   #14657
PerkM3
Done, I'll call you later.
Old 04-05-2012, 09:30 AM   #14658
cosmos///m3
My Ride: 2005 JB/IR ZCP ///M3
So... whats going on this weekend? I believe ill be in town and finally bringing the ///M up to see her new home
2005 ZCP Schwarz II/Imolarot 6spd ///M3 ||| 1999 Estoril Blau/Estoril Blau ///M Coupe "Clownshoe"
2014 Alpinweiss Uni/Mokka X5 ///M Package (wifey)
cosmos///m3 is offline   Reply With Quote
Old 04-05-2012, 09:31 AM   #14659
Andy2108
Friday night is the first FastFriday at KC Trends.
Old 04-05-2012, 09:48 AM   #14660
PerkM3
Correct!!!!
gameboy86, i'll supra, kansas, lllsupra sucks, miz-zou, ohaimgremillion09, rockchalkjayhawkgoku
Rate This Thread
