Go Back   E46Fanatics > E46 BMW > Regional Forums > Great Plains & Rocky Mountains
CO IA KS MO MT ND NE SD WY
Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 3.77 average.
Old 01-16-2013, 11:42 AM   #16761
NoMoreIdeas
My Ride: 01 M3
Wow... Ok I guess 'cpv valve' is kinda redundant. And using a regular flat blade bit was not working for me.
NoMoreIdeas is offline   Reply With Quote
Old 01-16-2013, 12:11 PM   #16762
Rubenk
My Ride: M35A2
Well, I wasnt being sarcastic.
Learn me what a CPV is.
Rubenk is offline   Reply With Quote
Old 01-16-2013, 12:14 PM   #16763
NoMoreIdeas
My Ride: 01 M3
Oh.... Lol
Constant pressure valve. It's a valve on the exhaust side of the block behind the header. The o ring gets very hard and leaks oil over time. The valve is a few hundred $$ but the oring is like $4.
Old 01-16-2013, 12:29 PM   #16764
Rubenk
My Ride: M35A2
Is it part of the CCV system? Or is it in the exhaust? Or am I totally lost here?
Old 01-16-2013, 12:31 PM   #16765
PerkM3
My Ride: 2005 AW M3 Coupe
Oh.... Lol
Mine was leaking a bit so I bought a new one. I tried to get the old one out with no luck so I just let it leak.
BimmerWorld : MOTON : VAC : Super Sprint : Rogue Engineering : Sparco : Vorsteiner : Schroth
341 whp / 262 wtq - NA S54
2,710 lbs
Thanks to my sponsors:
GF-Performance.com
Wealth Management Advisors, Inc.
Auto Tech Service Center
PerkM3 is offline   Reply With Quote
Old 01-16-2013, 12:32 PM   #16766
Rubenk
My Ride: M35A2
Found it. Still not sure what system its part of, the oil system maybe?
Part 10 below, right?
No. Description Supplement Qty From Up To Part Number Price Notes Photo
01 Set of covers 1 11142247867 $94.60
02 Gasket Steel 1 11141432240 $3.10
03 Hex bolt with washer M6X25-Z1-ZNS 4 07119900249 ENDED
03 Hex bolt with washer M6X25-ZNNIV SI 4 07119905400 $0.65
04 Hex bolt with washer M8X28-Z1-ZNS 2 07119902105 ENDED
04 Hex bolt with washer M8X28-ZNNIV SI 2 07119905530 $0.71
05 Shaft seal 90X110X12 1 11142249533 $58.96
06 Dowel D=10,5MM 2 11121726238 $1.62
07 Covering plate 1 07/2007 11141734019 $11.15
07 Covering plate 1 11147838044 $11.15
08 Oil Spraying Nozzle 6 11427830770 $19.90
09 Fillister-head screw M6X16-ZNS 6 07119901438 ENDED
09 Fillister-head screw M6X16 6 07129905536 $0.64
10 CONSTANT PRESSURE VALVE 1 BAR 1 11111318185 $41.25
11 Ping Sensor 3 03/2007 12147830788 ENDED
11 Ping Sensor 3 12147839167 $25.18
12 Hex bolt M8X30-ZNS 3 10/2006 07119901170 ENDED
12 Hex bolt M8X30-ZNNIV SI 3 06/2004 07119905531 ENDED
12 Hex bolt M8X30-8.8-ZNS3 3 07119902901 $0.25
13 Speed sensor 1 12147830789 $83.23
14 O-ring 18X1,2 1 12141402705 $1.07
15 Fillister-head screw M6X14 1 11427831375 ENDED
16 Gasket Set Engine Block Asbesto Free 1 05/2003 11117831919 ENDED
16 Gasket Set Engine Block Asbesto Free 1 11110302722 $267.70
Old 01-16-2013, 12:33 PM   #16767
NoMoreIdeas
My Ride: 01 M3
That's why I made a tool
Once I made it, it was really easy to get out and was pretty quick to change.
Old 01-16-2013, 12:34 PM   #16768
NoMoreIdeas
My Ride: 01 M3
Oh weird, when I had the new buyer inspection done they said it needed replaced and were going to charge me $600!
Old 01-16-2013, 01:14 PM   #16769
Andy2108
My Ride: E46M3E92M3'67Cobra
oh I know that. its that espencive? wow. yeah I'm pretty sure its oil related. does it go to the vanos maybe?
Andy2108 is online now   Reply With Quote
Old 01-16-2013, 01:19 PM   #16770
Andy2108
ruben did you see her post about the tiffany and co wedding gift thing?
Old 01-16-2013, 01:20 PM   #16771
Andy2108
nvm idk how this stuff works. registry.
Old 01-16-2013, 01:57 PM   #16772
Rubenk
My Ride: M35A2
Andy yea, you see the rest of it?
Old 01-16-2013, 02:30 PM   #16773
NoMoreIdeas
My Ride: 01 M3
From what I remember, it keeps a constant static pressure of oil supplied to the VANOS oil pump. I could be wrong though.
Either way, its a very common problem. My O-ring was so dried out, it snapped in half when i tried to flex it.
Old 01-16-2013, 02:34 PM   #16774
PerkM3
The CPV is not part of the oil system. It's purpose is to keep the internal block pressure constant. Thus the name Constant Pressure Valve. It's just a ball valve and a spring.
Edit: Very Very common problem. Hell I replaced by rear main seal and oil pan gasket when the oil was really leaking from the CPV.
2,710 lbs
GF-Performance.com
Old 01-16-2013, 02:38 PM   #16775
Andy2108
Oh damn. Maybe I should check mine...
Old 01-16-2013, 02:41 PM   #16776
PerkM3
It's really not that big of a deal from a safety/life of the car standpoint. Most of the time it's just a leaky O-ring and it's not like it leaks a ton. My SS headers were in the way of changing mine. I tried all kinds of tools.
2,710 lbs
GF-Performance.com
Old 01-16-2013, 02:48 PM   #16777
Rubenk
My Ride: M35A2
Internal block pressure? Pressure of what? Oil system, coolant system, crankcase?
Old 01-16-2013, 03:17 PM   #16778
PerkM3
It's also known as the oil pressure relief valve so I guess I was wrong by saying it's not part of the oil system but it's really not in my opinion. I guess I meant it doesn't assist in oil circulation, it's just a valve that opens as pressure increases to maintain a constant pressure which was determined desireable by the BMW engineers.
2,710 lbs
GF-Performance.com
Old 01-16-2013, 05:14 PM   #16779
Rubenk
My Ride: M35A2
Gotcha, so it bypasses excess pressure.
Old 01-16-2013, 05:32 PM   #16780
PerkM3
Exactly.
2,710 lbs
GF-Performance.com
gameboy86, i'll supra, kansas, lllsupra sucks, miz-zou, ohaimgremillion09, rockchalkjayhawkgoku
Rate This Thread
