Rating:
#16881 | |
#16882 |
Someone else signed papers on the house yesterday...bummer
#16883 |
That sucks man, good luck finding another one.
Just come over to my place and use my lift....................when I buy a house and get one.
![]() BimmerWorld : MOTON : VAC : Super Sprint : Rogue Engineering : Sparco : Vorsteiner : Schroth 341 whp / 262 wtq - NA S54 2,710 lbs Thanks to my sponsors: GF-Performance.com Wealth Management Advisors, Inc. Auto Tech Service Center |
#16884 | |
A truck and some cars...
#16885 |
I'd rather have the best suspension known to man paired with the best bbk then boost. I changed my mind.
#16886 | |
Definitely think you have the right idea with doing suspension, brakes and power. That way you'll have a capable track car without sacrificing the comfort of driving it whenever you want.
2002 BMW M3 - Stock
#16887 | |
#16888 | |
So it seems that my diff likes to lock hard when its really cool. Its not really a huge problem, but it doesn't feel good. UNTILL it decides to do it at the beginning of the turn, not the end. Then its like... oh that's the diff trying to lock OH WAIT THE DIFF LOCKED NOW WE'RE DRIFTING HOLYSHIT.
Also. I accidentally lost traction in 3rd gear at 2500 rpm this morning accelerating with traffic. RE-11's don't work well when its 9 degrees. Quote:
You should also contact Kyle's friend, p0lar something on M3 forum, about brakes in general. Specifically ABS thresholds. He seems to be some magic genius wizard who can program a whole lot about the car. What shocks were you going to get? Last edited by Andy2108; 02-01-2013 at 03:02 PM. |
#16889 | |
Now will I need one yes. The old car with aero and slicks for sure needed a bbk. Fade was apparent at the end of a 20-30 minute session after pushing hard lap after lap. Will this car have aero, not anytime soon but a bbk also last longer, gets more even pad wear, and is easier for pad chagnes. Did I mention it looks cool as hell. HAHAHAHA, Polar. Dude murders the bias. Do you not read those threads? I wouldn't disagree that what he is doing with Porche calipers isn't better than stock but it is no way near as good as a specifically designed stoptech kit and not even close to as good as the PFC or AP racing kits. Would you put porche suspension on your e46? I will be getting a PFC kit. Specifally designed by the same engineers that design kits for ALMS, Rolex, WTCC, Champ Car, so on and so forth. It comes down to wanting the best, you know that. Think of one part I had on the other car that wasn't held in high regard. Do it once and do it right. As for shocks I will be getting MCS 2-Way remote dampers. Similar to my Motons but with bigger valve bodies and just a bit more tech than the older Motons. Not sure on spring rates yet, will need something that isn't terrible on the street but will still be slick tire worthy on the track.
#16890 |
Ive been buying up tools left and right, now i just need a car to use them on.
#16891 |
I'm going to learn alot from this website
http://www.racecartuner.com/03/302.html |
#16892 |
So basically brad is going full retard again, got it. lololol
#16893 | |
No no no. Just semi retarded. The new car will still have rubber engine/trans/diff mounts and full interior...........for the time being.
#16894 | |
as others have mentioned, put a little pressure on the old ring trying to get it off and it just shattered into pieces. Herman the German could've done a better job with this little system.
Travis Nordwald
2003.5 BMW M3 2010 Mazda 3 1996 SCCA ITA Mazda Miata |
#16895 |
Anyone know where Ryan has been? I sent him a message to see if he would be able to get some AKG bushings for me, but I havent heard anything yet... :|
2005 ZCP JB/IR 6spd ///M3
#16896 |
on fb or e46? I texted him
#16897 |
Must. Have. Fast. Car. Again.
#16898 |
#16899 |
looking for oem sect 1 to put an ar20/25 in. if anyone has an extra for cheap laying around email me.
tnord42@hotmail.com thanks
Travis Nordwald
#16900 |
I have no idea what that means.
| Tags |
| gameboy86, i'll supra, kansas, lllsupra sucks, miz-zou, ohaimgremillion09, rockchalkjayhawkgoku |
| Rate This Thread | |
