Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > Great Plains & Rocky Mountains
CO IA KS MO MT ND NE SD WY
Thread Tools Search this Thread Rating: Thread Rating: 35 votes, 4.54 average.
Old 02-19-2013, 03:43 PM   #17001
Rubenk
My Ride: M35A2
Originally Posted by PerkM3 View Post
It's funny you said this because my buddy I work with just mentioned that the easiest way is to have a wire fed on gas which I'm gathering is MIG welding.
There is a local harbor frieght here. I normally try and stay away from HF for most things but I may run by and check them out.
Please do, ask what he has.
Thanks man.
My terminology might be a bit off, but you have 2 types of wire-fed. Gas shield(argon/co2) or flux-core. The flux core burns the core of the wire off to make its shield, and therefore no gas tank needed.
Rubenk is offline   Reply With Quote
Old 02-19-2013, 04:33 PM   #17002
PerkM3
Account Under Review
My Ride: 2004 SG M3 ESS-550
I hear that with gas it's a bit easier, is this correct?
PerkM3 is offline   Reply With Quote
Old 02-19-2013, 06:32 PM   #17003
Rubenk
My Ride: M35A2
Yes, thats what I said previously. But that assumes a non-windy environment, such as a garage or shop with no fan blowing.
Old 02-19-2013, 06:34 PM   #17004
Rubenk
My Ride: M35A2
1:30 into this one and it looks to be a pretty good example.
BAM, got it to work.
Got the embed to work finally. Dont include "https" on your youtube links.
Old 02-19-2013, 11:46 PM   #17005
Andy2108
My Ride: SpecE46 & E46 M3
You can also press the button for "share" and it gives you a link that works. I couldn't figure it out for the longest time either.
De gustibus non est disputandum.
Old 02-20-2013, 09:49 AM   #17006
Forcfed93
My Ride: 2002 M3
My family runs a welding a machine shop and has for 90 years. Welding classes are a waste of money IMO. It's not difficult until you start getting into different alloys, aluminum and TIG. Read up on it, watch videos and practice. It can even be fun to get some material and build garage furniture, art or decorations.
Best thing you can do is invest your money into a better welder and pick up some scrap metal and start playing it with.
DO NOT buy a cheap welder from Harbor Freight. 99% of what you want to do can be done with a MIG. You can even MIG aluminum by changing a few components like the spool, wire and voltages assuming you have a decent welder. I never recommend a flux core unless it's all you have to work with. The gas shielding provides much cleaner welds and is easier to do. The flux core will leave you with a splattered mess that will need to be ground smooth.
What I would really recommend, is a Millermatic 140. I've fabbed roll cages, exhaust, turbo kits, bracing, etc. with one of these.
http://www.millerwelds.com/products/...p?model=M00234
If that's a bit too expensive, I would start with no less than this:
http://www.northerntool.com/shop/too...1413_200471413
You can do pretty much anything you want with one of the machines above. Once you get into the 1/2" thickness range, then you'd need to look into a 220v machine.
2002 BMW M3 - Stock
Forcfed93 is offline   Reply With Quote
Old 02-20-2013, 10:05 AM   #17007
Rubenk
My Ride: M35A2
Rock solid advice right there.
You can learn the basics and theory of it real quickly, its all about practice after that. The majority of a welding class will be practice, but on their time and dime(partially), so that helps.
Old 02-20-2013, 11:09 AM   #17008
PerkM3
Great adive, that's pretty much the conclusion I came to yesterday after doing some research.
I think the most I would spend on a welder at this point is 500 bucks, hoping to find something used. Then get some scrap and practice, practice, practice.
I appreciate all the help guys.
Old 02-20-2013, 11:11 AM   #17009
Forcfed93
My Ride: 2002 M3
Good idea. Not sure if you're still looking for a low mileage SMG M3, but if you are, take a look at this:
http://kansascity.craigslist.org/cto/3608402702.html
5400 actual miles, $24k. That's a good deal right there, if you can get over the PY that is. No sunroof even.
2002 BMW M3 - Stock
Old 02-20-2013, 11:17 AM   #17010
PerkM3
Fuuuuuuuck that's a pretty good deal on a car with insanely low miles. But man that color is ugly.
How bout something like this.
http://www.ebay.com/itm/Craftsman-Wi...item35c4983945
Old 02-20-2013, 11:39 AM   #17011
Forcfed93
My Ride: 2002 M3
If you're planning on sticking to tiny thin stuff, maybe.
But for all around versatility, I wouldn't get anything less than 140amp output.
Both the Hobart and Miller I linked have a 30-140amp welding output. The Craftsman welder (used to be rebranded, cheaper made Lincolns) has a max output of I believe 85amps. Couldn't really find detailed specs on it.
If you have ready access to 220v, this is a pretty good deal:
http://www.amazon.com/Clarke-180EN-2.../dp/B004WF3PLU
You'd still have to get the gas, but it does come with the regulator.
Clarke is a budget brand, but I know a few people with them with no complaints.
2002 BMW M3 - Stock
Old 02-20-2013, 11:55 AM   #17012
Rubenk
My Ride: M35A2
You really do get what you pay for in MIG welders.
My buddy uses his Harbor Freight TIG and loves it, but you're manually controlling alot of things there that you dont in a MIG.
Old 02-20-2013, 01:53 PM   #17013
PerkM3
I hate this electrical stuff. I need to check what my garage has before I get ahead of myself. I believe it has a 20amp breaker so I doubt there is any way I would run 220v. I assume I'd be limited to 110? Correct?
Old 02-20-2013, 02:02 PM   #17014
Andy2108
No instead you just run two breakers to the same location. boom 220 service. I think.
Old 02-20-2013, 02:03 PM   #17015
Andy2108
just unplug your dryer and run a massive extension cord to your garage
Old 02-20-2013, 02:05 PM   #17016
Forcfed93
My Ride: 2002 M3
Yup. You'd need a double breaker for 220v.
Honestly, I'd wait until a used Millermatic 140 pops up. Make sure it has auto-set too.
It's your top of line 110v MIG and it's great for beginners because the auto-set does all of the parameter settings until you get to the point where you're comfortable enough to set them yourself.
2002 BMW M3 - Stock
Old 02-20-2013, 02:13 PM   #17017
PerkM3
I rent this place so I can't be doing stuff like that.
I could do that I guess, I just can't figure out why the garage doesn't have 220v.
I will keep an eye out. I really like that Hobart unit as well. At this point I only plan to do light welding such as stitch welding the chasis, roll cage tubing, and plate steel for reinforcements (probably 3/8").
Old 02-20-2013, 02:22 PM   #17018
Forcfed93
My Ride: 2002 M3
The Hobart would do that just fine.
2002 BMW M3 - Stock
Old 02-20-2013, 02:23 PM   #17019
PerkM3
I found some of the Miller 140's on ebay new for $700, think I may end up getting one of those.
I just wish craftsman made better stuff because although I know they aren't the best I'm a craftsman whore and I'm sorta OCD about having things match. Oh well.
Old 02-20-2013, 02:45 PM   #17020
Rubenk
My Ride: M35A2
I wouldnt buy craftsman stuff anymore. Growing up my family was loyal to them, but now they're mainly chinese junk.
gameboy86, i'll supra, kansas, lllsupra sucks, miz-zou, ohaimgremillion09, rockchalkjayhawkgoku
Rate This Thread
