Old 03-06-2010, 11:32 PM   #1
JP-330Ci
My Ride: 2001 330Ci
Mobil ATF D/M... Is it good for PS?
Ok, so i recently chnaged out the power steering hoses and flushed the ATF/Power Steering Resv.. My buddy said that this will work ok for the power steering(ATF)
I got the Mobil ATF D/M at the gas station. Wasn't sure if this stuff is ok or not here is a link to it http://www.mobiloil.com/USA-English/...il_ATF_DM.aspx
Just want to make sure its not gonna mess anything up. Or if any of you have used this... THanks
JP-330Ci is offline   Reply With Quote
Old 03-07-2010, 01:51 PM   #2
JP-330Ci
My Ride: 2001 330Ci
Old 03-07-2010, 05:19 PM   #3
mrshelley
My Ride: 2004 330i
I've been using the Mobil 1 ATF in my PS for a few years. This was because I had a case of the stuff and decided that since I had no other use for it, I might as well use it in the 330 power steering. So far, no leaks or any problems. Regular old ATF still works too.
Old 03-07-2010, 06:14 PM   #4
JP-330Ci
My Ride: 2001 330Ci
Thanks, i noticed its not the synthetic ATF is that a problem?
Old 03-07-2010, 06:39 PM   #5
mrshelley
My Ride: 2004 330i
As long as it's ATF, then you are fine.
Old 03-07-2010, 06:51 PM   #6
JP-330Ci
My Ride: 2001 330Ci
ok cus i noticed the steering is unusually harder...
Old 03-07-2010, 07:04 PM   #7
andrewboi
My Ride: PY M3
I used the mobil 1 dexron VI with no problems. I did some research and a couple other members used the new dexron VI as well with no probs
andrewboi is offline   Reply With Quote
Old 03-18-2010, 09:27 AM   #8
e46bonestock
My Ride: 325
I use regular dexIII for power steering in my 325. perfectly fine.
I use the mobil 1 dex vi ATF in my steptronic, it's been 6 months, runs great.
e46bonestock is offline   Reply With Quote
