Sponsored by The Tire Rack
Old 03-07-2010, 01:07 PM   #1
bmwdw8212
My Ride: e46 330ci
Lightbulb will fit?
2002 330ci ,M package.
Will a 235/40/18 tire on 18x8.5 et35 the front? droped (H&R cup kit) & Brembo BKK 330 disc 4 po on front.
255/35/18 tire on 18x9.5 et40 rear.
Don't want to do any fender work.
Don't know work or not yet, any suggestions? THX!
http://forum.e46fanatics.com/signaturepics/sigpic155362_3.gif
..../==========\........present
(]/______________\[) ..02 E46 330ci M-package
./(O8o]=()()=[o8O)\ .....97 R170 SLK230K
.|\====-----====/| .....past
[__|=========|__] .....92 & 93 E36 325i
bmwdw8212 is offline   Reply With Quote
Old 03-08-2010, 01:13 PM   #2
VMRWheels
VMRWheels's Avatar
My Ride: Anything with VMRs!
Fronts should be fine but as far as the rears, 9.5 +40 with a 255 is a hair on the aggressive side. Depending on the tire you go with and your alignment, rubbing issues may occur. You can prevent that by adding some camber if you do not want to roll your fenders. Just be sure your toe is within spec so that tire wear is not abnormal.
-Charles@VMRWheels
Tracy @ VMR | Wheels
Winter Wheel/Tire Sale!
Old 03-18-2010, 01:17 AM   #3
bmwdw8212
My Ride: e46 330ci
so if rear use 9.5j and et+45 is OK for me?
