Old 03-07-2010, 03:00 PM   #1
rsk289
My Ride: e46 330i Touring
Evans coolant
Anybody tried this in their E46?
I have it in my classic Mustang and was thinking about trying it in the 330. Long life, no corrosion, low pressure etc....
rsk289 is offline   Reply With Quote
Old 03-07-2010, 05:03 PM   #2
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
It's impressive stuff...and used in a ton of motorsports applications that people won't admit to. However, it can't be mixed with water based anything...and it's tricky to flush out the M54 block and cooling system properly to make it work right.
I wouldn't use it on an already installed engine, but I'd use it on a "dry" block after a rebuild.
Old 03-07-2010, 05:11 PM   #3
rsk289
Thanks for that - on other cars that are difficult to drain, I've made it work by draining as best as possible and running for a bit, then doing it all again. Expensive to do it twice, but seems to work - what do you reckon for the M54?
