Sponsored by BimmerWorld
Old 03-09-2010, 02:26 AM   #1
infantrytroop22
My Ride: M3
Can RTAB limiters cause creaking?
I just had new OEM RTABs and limiters (not sure what brand) installed on my '05 M3 and the rear end of my car now creaks when I pull in and out of driveways. Could this be from the Limiters? FYI, I'm on coilovers.
infantrytroop22 is offline   Reply With Quote
Old 03-09-2010, 02:27 AM   #2
SpeedDemon
My Ride: E92M3 E46ZHP Golf7R
Probably not... what make limiters are they?
It's probably something else. Strut seals that aren't lubed properly, RTABs, RSMs, etc...
SpeedDemon is offline   Reply With Quote
Old 03-09-2010, 03:04 AM   #3
infantrytroop22
My Ride: M3
I forget what make the limiters are. The RTABs are new and OEM, so I can't imagine they would be causing the issue, unless they need to be broken in or something. My mechanic claims the creaking is caused by the limiters and that it is normal. I trust his opinion, but I kind of want some verification and other thoughts.
Old 03-09-2010, 08:32 AM   #4
TxZHP04
My Ride: ESS TS2+ ZHP
I've never experienced any creaking with my Vorshlag limiters and have never heard any reports of creaking but I suppose it's possible depending on the material your limiters are made of.
Old 03-09-2010, 07:28 PM   #5
Whammy
My Ride: ZHP
When was the last time you had an alignment? Have you checked your suspension? Is anything cracked (subframe, swaybar) or loose (endlinks)?
Whammy is offline   Reply With Quote
Old 03-09-2010, 08:13 PM   #6
infantrytroop22
My Ride: M3
I just had an alignment when the RTABs and limiters were installed. Everything was checked over, and nothing is damaged. The sound is coming from both sides, meaning I can hear each side creaking independently. That is why I figured it was related to the limiters.
Old 03-09-2010, 08:19 PM   #7
infantrytroop22
My Ride: M3
I guess the material is a urethane rubber, and the brand is ireland, or something like that.
Old 03-09-2010, 09:55 PM   #8
Whammy
My Ride: ZHP
I have the Vorshlag limiters and I do not have the same issue you are describing. I did notice a little creaking over winter, but I think the alignment and lowering of my suspension (PSS System) helped.
Old 03-09-2010, 10:05 PM   #9
infantrytroop22
My Ride: M3
It only creaks when there is torque on the chassis, like when I pull in or out of a driveway. There really isn't much noise when going over speed bumps, etc. I think I am going to drive it for another week or so, and then if it is still really loud I am going to take it back to my mechanic and have him check it out.
Old 08-14-2012, 02:05 PM   #10
mpower3330
My Ride: E46 M3
Back from the dead.. Did you ever find out what was causing this? I had my RTABs replaced with OEM ones and OEM limiters and have had the exact same creaking problem since they were put on.
mpower3330 is offline   Reply With Quote
Old 03-21-2013, 01:59 AM   #11
thecarguy
My Ride: ZHP Sedan
Yet back again from the dead. Same here!
thecarguy is offline   Reply With Quote
Old 03-21-2013, 12:46 PM   #12
thecarguy
My Ride: ZHP Sedan
Here is what I posted in my own post yesterday which has had no response yet. So just in case this is the one that gets traction, here is my story...
So, this past weekend I installed Meyle HD rtabs and poly limiters...
http://store.bimmerworld.com/e36e46z...px?Thread=True
I researched a lot, printed DIYs and spent the better part of the day doing it. Won't get into that. Anyways, I did the following to a T....
Pressed in bushings with exact equal distance out on both sides (even).
Put poly limiters in the correct way (only way) with beveled sides out.
Pre-aligned bracket "pre loaded" with axel...by the book.
Torqued down to 87ft/lb
Matched up bracket in body to spray marks and torqued down the 3 bolts on each side. Forgot spec but to spec.
On movement of suspension -especially when cold, I get noise from what has to be the poly bushings rotating against the smooth clean metal rtab bracket.
It blew me away that no lithium lube was called out for that mating surface.
Anyways, it turns out I am the only one on the planet that has had this problem according to them. It just does not make sense.
So, I don't think I did anything wrong so should I just spray a bit of lithium lube in between the bracket and limiters?
Anyone else have this issue???
Old 03-21-2013, 08:07 PM   #13
thecarguy
My Ride: ZHP Sedan
Has to be someone to chime in?
Old 03-22-2013, 10:30 AM   #14
thecarguy
My Ride: ZHP Sedan
It's exciting to know I'm not the only one, now I can't believe it's been 36 hours with no reply.
Old 03-23-2013, 01:08 PM   #15
thecarguy
My Ride: ZHP Sedan
Just need to know the best spray lubricant for in between the limiters and metal bracket that is friendly to the rubber Meyle HD rtabs. I would really like to take care of this today.
Feeling desperate....please help.
Old 03-25-2013, 12:47 AM   #16
thecarguy
My Ride: ZHP Sedan
Checking in.
Old 10-28-2013, 02:40 PM   #17
muscal48
My Ride: BMW 1999 328i
I too am getting terrible creaking problems. I installed Turner Motorsports limiters and it was tolerable at first, but has been getting increasingly worse (and a lot louder). My 328i sounds like a pirate ship. Has anyone had any luck resolving this issue yet? Thanks!
muscal48 is offline   Reply With Quote
Old 10-28-2013, 08:55 PM   #18
SoloII///M
My Ride: Many
They creak. Lube will make it go away for a bit but not forever.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
