Old 03-12-2010, 12:34 PM   #1
xixixi
Banned User
My Ride: 01 330x-xi
Shift Lever Lube?
Anyone know what the "Lubricant" is that is used for the shift lever? it's kinda a yellow color? could be some sort of grease? anyone? mine is a little dry and squeaking a bit, thanks!
Old 03-12-2010, 12:46 PM   #2
JJR4884
My Ride: BMW
get a girl to ride it.... her salty alkaline-like dripping will do the job
JJR4884 is offline   Reply With Quote
Old 03-12-2010, 12:46 PM   #3
Anub!s
My Ride: e46 330ci, e92 M
Send a message via AIM to Anub!s Send a message via MSN to Anub!s Send a message via Yahoo to Anub!s
Anub!s is offline   Reply With Quote
Old 03-12-2010, 12:50 PM   #4
330I6SPD
My Ride: 2005 330I 6Spd.
I've never gotten litmus test strips in my condom boxes. What brand provides these???
330I6SPD is offline   Reply With Quote
Old 03-12-2010, 12:51 PM   #5
xixixi
Banned User
My Ride: 01 330x-xi
real info thanks
Old 03-12-2010, 12:56 PM   #6
jott5555
My Ride: 01 330ci
i use regular high temp Axel grease, it sticks around and if its good enough for a wheel bearing im sure its good enough for the shifter assembly, i lubed the plastic ball and all the joints and fittings..
jott5555 is offline   Reply With Quote
Old 03-12-2010, 12:57 PM   #7
xixixi
Banned User
My Ride: 01 330x-xi
thank you, this works for me
Old 10-22-2010, 04:01 PM   #8
McSpeed
My Ride: 2005 ZHP TT Stg 1
BMW TIS from 2006 specifies Kluber Polylub GLY 801:
Kluber sells it direct for $272/kg(!)
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
