Old 03-12-2010, 02:06 PM   #1
Focal E46
My Ride: is a DIYer
DIY: One way to check if your DISA valve is going bad
I was reading a couple threads in which members were asking how to check to see if the DISA valve was the cause of the tapping noise heard in the engine bay. I shot this quick video on how I tested mine.
Update: Below you will find two more videos on how I inspected and rebuilt the DISA.
Focal E46 is offline   Reply With Quote
Old 03-12-2010, 02:10 PM   #2
Focal E46
My Ride: is a DIYer
Here are the updated part numbers:
M54 2.5: 11 61 7 544 806
M54 3.0: 11 61 7 544 805
The cheapest place I found it so far is Tischer (www.getbmwparts.com) for $179.
Hope this helps.
Old 03-12-2010, 02:51 PM   #3
xFalleNx330Ci
My Ride: '01 330Ci
nice post man
Originally Posted by beingdevious View Post
OT is like a bunch of rabid horny monkeys that run around and rape other forums, any new monkeys, and then throw **** at eachother, take pics, and demand nudes.
xFalleNx330Ci is offline   Reply With Quote
Old 03-12-2010, 02:57 PM   #4
Raine
My Ride: e39
I just leave mine unplugged
Raine is offline   Reply With Quote
Old 03-12-2010, 03:01 PM   #5
AlphaVortex
My Ride: jalopy!
Oh man that sounds EXACTLY like mine!!! Thats the first thing I'm doing when I get home tonight. Stupid valve. Thanks for the info!
Wouldn't unplugging it cause you to lose a bit of performance? I thought the DISA was there to modify the intake flow for better performance?
AlphaVortex is offline   Reply With Quote
Old 03-12-2010, 06:05 PM   #6
Focal E46
My Ride: is a DIYer
I think that would cause it to remain in the open position which could affect your low end torque and cause a rough idle. Some have ended up with a loss of performance but I wouldn't want it coming apart on me
I'm gonna take mine out tomorrow and see what cleaning it will do until I get a replacement in. I'll snap some pictures.
Old 03-12-2010, 08:27 PM   #7
rares
My Ride: 02 S54
Send a message via AIM to rares Send a message via Yahoo to rares Send a message via Skype™ to rares
awesome test bro' i am going out right to check... thx
rares is offline   Reply With Quote
Old 03-13-2010, 12:31 PM   #8
Focal E46
My Ride: is a DIYer
Update:
Here's the DISA (Adjuster) valve removed. It shows the slippage and how to determine failure.
Old 03-13-2010, 12:35 PM   #9
Focal E46
My Ride: is a DIYer
Coming soon! How to rebuild a broken DISA
Old 03-13-2010, 10:38 PM   #10
bmwdw8212
My Ride: e46 330ci
Change the new
http://forum.e46fanatics.com/signaturepics/sigpic155362_3.gif
..../==========\........present
(]/______________\[) ..02 E46 330ci M-package
./(O8o]=()()=[o8O)\ .....97 R170 SLK230K
.|\====-----====/| .....past
[__|=========|__] .....92 & 93 E36 325i
bmwdw8212 is offline   Reply With Quote
Old 03-13-2010, 11:46 PM   #11
rollover360
My Ride: 01 325i
My DISA was sticking, so I went and removed the DISA and actually removed the flap that rotates back and forth with the help of my dremel. The only issue that I have now is on cold starts it idles kind of rough but just blimpin the throttle a couple times solves that then it idles perfect. No notice in low end power loss and no CEL.
later
rollover360 is offline   Reply With Quote
Old 03-14-2010, 06:19 PM   #12
Focal E46
My Ride: is a DIYer
How to rebuild:
Old 03-14-2010, 06:22 PM   #13
Focal E46
My Ride: is a DIYer
I've been driving around all weekend with it rebuilt and the car is running great. Low end feels GREAT, the car revs quicker and sounds livelier. While I was in there I also cleaned the Mass Air Flow sensor (MAF), Idle Control Valve (ICV) and the throttle body. I'm going to check tomorrow to see if the two codes I erased are back or not ( 0174 & 0171 ). These are suppose to be associated with a bad DISA.
Old 03-14-2010, 07:07 PM   #14
nevets
My Ride: 2002 325Ci
great stuff man!
checked my DISA valve today and its not making any noise but im glad to see that its an easy fix. gonna save a lot of people money here.
nevets is offline   Reply With Quote
Old 03-14-2010, 07:28 PM   #15
acpstunts
My Ride: E46 330ci / E53 X5
Wow great fix, keep us updated. Did you need a new gasket or anything?
acpstunts is online now   Reply With Quote
Old 03-14-2010, 07:45 PM   #16
Kris.R
My Ride: 2012 Dodge Charger
Great job!
- Kris -
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-Abraham Lincoln-
Kris.R is offline   Reply With Quote
Old 03-15-2010, 06:36 AM   #17
Focal E46
My Ride: is a DIYer
Thanks guys!
Nope. Luckily my gasket was intact after a thorough cleaning. The gasket is not replaceable so if it's shot, the whole DISA is useless.
The only thing I needed to buy was a $4 tube of Loctite Epoxy Putty found at Walmart. I mixed it until it turned an "off-white" color, droped a pea sized ball into the bottom of the flap and reassembled. I also put a teenie bit on the bottom of the top pin. Be careful if you do this because the top pin is suppose to pivot with the flap. Once it was all together it was solid. No rattling.
I also highly recommend you buy a can of Mass Air Flow cleaner for another $7 (found at your local parts store). This worked great for cleaning the DISA, MAF, IAC, throttle body, intake tubes, and everything I couldn't scrub with a rag.
Old 03-15-2010, 09:19 AM   #18
trizzuth
My Ride: gobbles oil like a B
I swear to god I should just pay you money. I just noticed a nasty ticking noise coming EXACTLY from that side of my engine, from listening real close, it sounded like valve lifter tick or something horrendous. I even went so far as to remove the DISA valve and check it out, whereupon i noticed that when I moved the flap all the way closed, that there was a strange popping suction noise. So not wanting to mess with it, I re-installed it, and carefully looked to see if it was moving at all, since no parts were moving, I didn't think that would be the issue, but for some reason never even though of disconnecting it to see if the sound went away, you are GOD!!!!! this just made my entire feeling about my car so much better, thanks for posting!
trizzuth is offline   Reply With Quote
Old 03-15-2010, 09:46 AM   #19
Focal E46
My Ride: is a DIYer
Glad to have helped
I just subscribed myself to this thread so if anyone has any questions I should be back to answer within a day.
Old 03-16-2010, 05:10 PM   #20
330icrazy
My Ride: 01 330i
Great write up about to go epoxy mine back in thanks. hopefully just saved me 200 bucks I'll report back if it works!
Been a day now no rattle sounds good
330icrazy is offline   Reply With Quote
