Sponsored by The Tire Rack
Old 03-12-2010, 11:27 PM   #1
AWD325XI
My Ride: 03 325xi
Need help
i have a 325xi
i need to know if 19x9s will fit all around. please let me know!@!
AWD325XI is offline   Reply With Quote
Old 03-13-2010, 03:59 AM   #2
mkodama
mkodama's Avatar
1. Search next time please. Every question you need to know has already been answered, and then some, on this forum.
2. Yes, that wheel size will fit only if the offset is correct and bolt pattern is correct.
Old 03-13-2010, 12:54 PM   #3
AWD325XI
My Ride: 03 325xi
thanks for the reply
i have searched but cant find much on the 19x9. the offset is ET +48. sorry for the inconvenience. but if you could help me out it would be great
Old 03-13-2010, 03:42 PM   #4
mkodama
mkodama's Avatar
Hmm, with an offset like that, you will probably run into clearance problems with the front struts. You would probably need some spacers, and make sure you don't run a tire that is too wide. That fitment will be very aggressive, but with the right spacers and tires, it could look nice.
Old 03-13-2010, 08:06 PM   #5
AWD325XI
My Ride: 03 325xi
thanks so much very appreciated!
Old 03-13-2010, 09:05 PM   #6
BartenderPlease
My Ride: '03 540i/6 M-Sport
5mm spacers all around would make a pretty nice fitment and will guarantee you won't rub on the struts. You probably won't without any spacers though. A member here is using a 9.5" wide front with an offset of +45 and he does not rub on OEM struts.
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 03-15-2010, 11:03 AM   #7
AWD325XI
My Ride: 03 325xi
does it make a difference that i have an xi? that is my main concern
Old 03-15-2010, 11:25 AM   #8
xixixi
Banned User
My Ride: 01 330x-xi
having an xi gives you more choices with tire/rim setups. why? b/c our xi's have a 1 inch body lift from the factory. so lowering your car 1 inch will put it at the stock height of a reg 330i. A 330i sport has an even lower stance. think that should answer everything you wanted to know about your xi concerns
Old 03-15-2010, 11:55 AM   #9
AWD325XI
My Ride: 03 325xi
haha that does make me feel better. maybe i will pick these up then. hopefully with 19's and no drop yet my car doesn't look like a monster truck!
Old 03-15-2010, 03:29 PM   #10
BartenderPlease
Its going to look lifted dude, don't don't don't do it until you can drop it
