Suspension & Braking
Have some questions about suspension or brake setups for your E46 BMW? Get all your answers here! |
Rating:
Display Modes |
#1 |
Basic OEM brake info - http://forum.e46fanatics.com/showthread.php?t=456412
Long thread on brake choices (plain/slotted/drilled/etc) - http://forum.e46fanatics.com/showthread.php?t=449052 There's no such thing as warped rotors - http://forum.e46fanatics.com/showthread.php?t=402902 The Effect of Rotor Crossdrilling on Brake Performance - http://forum.e46fanatics.com/showthread.php?t=500950 How to bleed your brakes using a Power Bleeder - http://forum.e46fanatics.com/showthread.php?t=489727 Brake Pad Replacement DIY - http://www.e46fanatics.com/howto/how...hp?howto_id=29 Many more E46 DIY'd on brakes (and more) - http://www.bimmerdiy.com/dir/e46 StopTech White Papers - http://www.stoptech.com/tech_info/te...e_papers.shtml Tech Info from Zeckhausen - http://www.zeckhausen.com/technical.htm
#2 |
More brake thread goodness -
BMW Motorsport brake rotor install on 330Ci - http://forum.e46fanatics.com/showthread.php?t=504694 Update on BMW Performance Brake Rotors - http://forum.e46fanatics.com/showthread.php?t=516652 Brake rotor and brake pad compatibility - http://forum.e46fanatics.com/showthread.php?t=505464
#3 |
You the man!
![]() Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt. S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip |
#4 |
cough**sticky**cough
#5 |
325xi 27k miles brake pad warning light came on
My girlfriend has a 2005 325XI and last weekend her brake pad warning light came on. She, although not a great driver, does not drive hard and has never put the car on a track. This seemed early to need pad replacement. Does anyone have insight if this is normal at this mileage level or year?
#6 |
Article on choosing the right brake pads for your application
How to Choose the Best Street and Track Brake Pads |
#7 |
My Ride: 1996 BMW 318ti Compa
Nice to get everything in one place thankyou
#8 |
Thanks for doing this I need new front brakes for the summer and needed help figuring out what to get.
#9 |
im looking to upgrade my calipers, and rotors for my 2003 325i any ideas?
#10 |
Brake upgrade on 325i
I asked this question a few years ago, found one person a racer who sent photos that showed shaving M3 brake brackets to fit the spindles on a std 325I . So I purchased a complete set of M3 brakes, I am sure it is very possible. Something about milling off 4 to 7 mm and just bolting them on. Big drilled rotors the size of dinner plates make a statement.
"If you want something you will make it happen, if not you will make an excuse"
#11 |
Brake upgrade
Oh yes, I have purchased new 18" wheels and tires so I was sure the big brakes would fit inside.
| Tags |
| brakes |
