Old 03-14-2010, 12:36 PM   #1
The-Traveler
My Ride: 2004 330Ci ZHP
Has anyone put spacers on ZHP wheels?
I'm thinking about getting wheel spacers for my car to make it look more aggressive, but I can't seem to find any pictures or sizes for these wheels.
Has anyone gone this?
I saw a stanced out non-m coupe and it looked really wide from behind, as if it was an m3, but It was just a really nice wheel setup. I would like to do the same, but keep the 135M wheels if possible since I think they're very nice.
Advice?
Thanks!
The-Traveler is offline   Reply With Quote
Old 03-14-2010, 01:06 PM   #2
ferrarix99
ferrarix99's Avatar
My Ride: 87 325e - 05 M3 Vert
ive read that 10mm all around is a nice setup, but you should measure yourself to see how far out you want them to be
click for pics of the old ride...
-Nick the Greek-
euro.techniks
Bimmerworld Epic Tune | OEM Euro Headers | CSL Brakes | B&B TriFlo | aFe SuperStock | PSS10 | Varrstoen TE37 | V1 | ZKW Lens Swap | Orion Golds
Want your car coded? PM me.
ferrarix99 is offline   Reply With Quote
Old 03-14-2010, 01:33 PM   #3
MacFady
My Ride: 330i ZHP
Here's a random pic of 10mm spacers on my 330i ZHP with stock suspension. Sorry for the poor quality pic but hopefully it gives you an idea. I know there are lots of other people on here with 10mm spacers and 135M wheels.
MacFady is offline   Reply With Quote
Old 03-21-2010, 03:51 PM   #4
MacFady
My Ride: 330i ZHP
Wow, a week and no one commented on the cupping on the inside edge of both tires in the first picture.
Old 03-21-2010, 06:57 PM   #5
zhp pilot
Falling from 14k ft.
zhp pilot's Avatar
My Ride: is totaled :(
The most common set up on the ZHP is 12mm front and 15mm rear. This is what I have.
zhp pilot is offline   Reply With Quote
Old 03-22-2010, 06:49 PM   #6
The-Traveler
Thank you ZHP Pilot.. that's perfect! There aren't any fender issues with that setup are there? Are those the Tischer splitters, I know that they want $450+ for the CF ones and it's too much.
Old 03-22-2010, 07:39 PM   #7
ZZen330
My Ride: 2002 330Ci
ZHP Pilot - that stance with ther OEM rims looks fantastic. There was an M3 I saw on here recently that had stock rims with spacers and it looked so clean and stock yet more aggressive with the stance.
ZZen330 is offline   Reply With Quote
Old 03-22-2010, 09:51 PM   #8
zhp pilot
zhp pilot's Avatar
If you add a drop, you might have some issues unless you fender roll or prevent it with camber in the rear. Right now I have the rear at -2° camber on both sides and if I went any lower on height, I would have rubbing issues. I don't have my fenders rolled. The front is a non-issue since you can't add that much camber for you to worry about. I'm considering putting the 15's in the front and the 12's in the back. Yeah, they are OEM CF splitters. Here's a more recent pic:
Old 04-08-2010, 09:43 AM   #9
ricke46
My Ride: e46
lowered on h&r, 10mm all around. wouldn't be able to go any bigger in the rear without a fender roll
ID:	355302   Click image for larger version
ricke46 is offline   Reply With Quote
Old 04-08-2010, 09:54 AM   #10
joshzhp
My Ride: ZHP--Stock
I run 15mm in the front and 12mm in the rear since the rear rims are .5 wider. PM a email address and will send some pics.
joshzhp is offline   Reply With Quote
Old 04-08-2010, 10:27 AM   #11
DJ Reminisce
My Ride: Knows Dubstep SUCKS
I run 10mm front, and 15mm back
Let me see if I can hunt down some pics
Im actually considering putting on 20mm in the back....
Pilot: Where'd you grab those mirrors?
Dinan CAI_Stage II_3.46 Dif
OEM CF Strut Bar_Eibach Sportline_GC Konis
OEM Gloss Grills_H&R Spacers_Clubsport Sills_Painted Splitters
Amber LED Corners/6k HID Fogs/LED Interior_Shadow Emblems
500W_RE Audio_Hertz Components
House Mixes:
DJ Reminisce is offline   Reply With Quote
Old 04-09-2010, 07:14 AM   #12
zhp pilot
zhp pilot's Avatar
What is your camber in the rear? I'm running 12mm's with no rubbing issues. I did have to swap the 15's to the front though so I could lowered the rear some more.
Old 04-09-2010, 07:25 AM   #13
BMWespresso
My Ride: 2005 325CI
Spacers+Drop is a must
BMWespresso is offline   Reply With Quote
Old 04-09-2010, 08:40 AM   #14
calialx1
My Ride: FL 330i, 3000GT
what kind of spacers are you guys using? hubcentric? brand? will I need new lugbolts?
calialx1 is offline   Reply With Quote
Old 04-09-2010, 09:20 AM   #15
zhp pilot
zhp pilot's Avatar
I have Macht Schnell spacers which are hubcentric and come with extended lugs. I bought them from EAS: http://www.europeanautosource.com/in...ath=67_203_394
Old 04-09-2010, 03:41 PM   #16
starlights
My Ride: 2006 330Ci
on a side note, whats the offset on the OEM ZHP rear wheel? (I am guessing putting a 15mm spacer will reduce, the offset by 15mm - is that correct?)
starlights is offline   Reply With Quote
Old 04-09-2010, 05:52 PM   #17
zhp pilot
zhp pilot's Avatar
IIRC, the front and the rear are 38.
Old 04-09-2010, 05:55 PM   #18
zhp pilot
zhp pilot's Avatar
I now have my 15mm spacers installed up front with the 12's in the rear.
Old 04-11-2010, 10:58 PM   #19
starlights
My Ride: 2006 330Ci
Looks good - why did you change though? So were you able to remove your -2 camber at the back by swapping spacers?
Can one run 15front and 15 rear?
Old 04-11-2010, 11:23 PM   #20
ZZen330
My Ride: 2002 330Ci
The offset of the OEM rear ZHP wheel is +51, so a 15mm spacer would make it like a +36. Front OEM ZHP is +47 offset.
