Sponsored by The Tire Rack
Old 03-14-2010, 06:30 PM   #1
e46acs3coupe
My Ride: e46 acs3
fender rolling what to do with te plastik parts in the rear fenders
hello.
i had some rubbing issues at the rear of my car with my acs typeIII racing wheels 19''x9 with 265/30/19 tires,so yesterday i rolled-bent the fenders they are only about 5mm thick now and still look like oem on the outside. so the wheel wont rub there anymore. then i refit my rear bumper and the plastik parts in the rear fender, and gues what these still rub a bit there also is a little hole in the plastik from the tires rubbing.
now the question, how or what do you guys do about this? i want to do this in a decent way. i do not want to cut a bigger hole in the plastik to have no rubbing.
here are some pictures hope you can see what i mean
ID:	352078   Click image for larger version
ID:	352079   Click image for larger version
ID:	352080   Click image for larger version
ID:	352084   Click image for larger version
e46acs3coupe is offline   Reply With Quote
Old 03-14-2010, 11:55 PM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Seriously? You are going to drive the car like that?
You will probably need to just take out the plastic piece.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 03-15-2010, 12:05 AM   #3
10psie46
My Ride: e46 non m
I think that look ****in sick like that. I love it. what suspension do you have?
10psie46 is offline   Reply With Quote
Old 03-15-2010, 12:25 AM   #4
be-doubleyou
My Ride: 02 325ci
Im pretty sure the only options are to cut/dremel the area, take it out, or just let it rub until it doesn't rub anymore. I cut mine out and dont have anymore rubbing. In for other options though.
Bill
be-doubleyou is offline   Reply With Quote
Old 03-15-2010, 07:36 AM   #5
e46acs3coupe
My Ride: e46 acs3
no im not going to run the car like that.
i took the springs out to test if the fenders woud clear the wheels.
and they can go this deep without rubbing so thats good, just need to find a way to mod the plastik covers in a decent way.
Old 03-15-2010, 10:36 PM   #6
simsima325
'a certain moderator'
simsima325's Avatar
My Ride: Honda Civic
cut a big hole in the plastic, so as to have no rubbing. u will need to cut off part of the bracket as well, in the rear bumper.
dope dope setup. want.
-Brendan
Old 03-16-2010, 12:07 PM   #7
WSTO
Past Site Sponsor
you should run like that, looks nice!!
you have 3 options, remove the plastic, take a dremel to it, or let it rub until it clearances itself.
either one works
WSTO is offline   Reply With Quote
