Starting Project... What else? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-14-2010, 09:35 PM   #1
York
My Ride: 01 330Ci
OK - I have a stock 2001 330Ci, 5-Speed with 100K miles. I picked it up last April and it currently has no issues. Well, maybe one, but not a biggy - the oil light comes on for minute after starting. Anyway, here are the parts I've picked up, but was wondering what else you'd do at the same time. You know - while I'm under the hood, under the car.
Complete cooling system overhaul - radiator, expansion tank, thermostat, upper and lower radiator hoses, water pump, new belts, tensioner, idler pulley, tensioner dampner.
Valve cover gasket, valve cover seals, spark plugs (NGK BKR6EQUP), Vanos kit.
Things I'm picking up this week: Oil level sensor, synthetic oil, oil filter, LCA bushings, Vanos oil pipe, temp sensor for lower radiator hose, fuel filter.
What else should I be doing while I'm in there? Should I go ahead a change the transmission and differential oil? Thanks for any suggestions.
330Ci
York is offline   Reply With Quote
Old 03-15-2010, 08:49 AM   #2
York
My Ride: 01 330Ci
A friend just mentioned engine and tranny mounts. I guess I'll do a search to see how hard it is to replace those.
330Ci
Old 03-15-2010, 09:03 AM   #3
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Supercharger
In all seriousness, sounds like you've got a good list
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 03-15-2010, 12:24 PM   #4
firefirefire90
Banned
My Ride: suce ma bite
Send a message via AIM to firefirefire90
the only other thing I would add to that list if you are going to dive deep into the engine, is a new CCV w/hoses. Looks like you're off to a great start!
firefirefire90 is offline   Reply With Quote
Old 03-15-2010, 03:33 PM   #5
York
My Ride: 01 330Ci
Supercharger :
Not yet!
330Ci
Old 03-15-2010, 03:34 PM   #6
York
My Ride: 01 330Ci
This might be good to do. I just checked some DIY threads and even though some say it's hard, most say it's doable. Thanks for the tip.
330Ci
Old 04-19-2010, 11:45 AM   #7
York
My Ride: 01 330Ci
Wow - Long weekend! This was my first maintenance on a car I bought last summer. Car has 100K miles. Let's see what I completed: Changed oil and filter (Pentosin 5W-30) and installed new oil level sensor. Refreshed entire cooling system - radiator, water pump, thermostat, upper and lower hoses and expansion tank. Replaced both belts, tensioners and pulleys. Installed new spark plugs (NGK) and valve cover gasket. Installed new fuel filter. Reset service indicator.
I learned a lot this weekend. Just wanted to give thanks to all that have posted DIY's - you are all life savers.
One thing - I thought I had a new lower radiator hose temp sensor, but couldn't find it in the garage. I ended up reusing my old one and yes, there is a very small leak now. I went to the hardware store and picked up a new O-ring and reinstalled. No leak. My question - does the temp sensor come with an O-ring made of special material or should I be OK?
330Ci
Old 04-21-2010, 01:11 PM   #8
chris10492
My Ride: 14 Camaro 06 R1
i think it should be ok, but when i did me coolant overhaul i thought i had ordered a new temp sensor loll but nope, so i just cleaned out the old one and reused it. no leaks at all and still going great
chris10492 is offline   Reply With Quote
