Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 03-15-2010, 06:47 AM   #1
jjrichar
Modded ///Member
My Ride: 330 CiC, 330i
Arm rest removal prior to centre console
I've seen a number of posts here that describe how to remove the centre console. On all I've seen they show pulling the centre console up and over the arm rest. Whilst this can be done, it damages the leather on the arm rest, and also the paint on the underside.
The arm rest is designed to be removed prior to pulling off the centre console so it doesn't get damaged. Below are instructions on how to do this. It's more effort (a couple of minutes extra), but stops you damaging the arm rest.
Note the photos have been taken with the arm rest and centre console out of the car (and screwed back together again like they are in the car), so you can see more easily what I'm describing.
How to do it:
1. As normal, remove the rear ashtray, the expansion rivets below, and then the ash tray housing.
2. Remove the two screws below, and then the housing that has the covers that go over the arm rest pivot.
3. Get some pliers and remove the springs on either side. They are easy to remove and reinstall later.
4. Lift the arm rest up, and then get a tool that will allow you to pull out the cover on the inside. It just pulls straight out.
5. Get a small screwdriver and push in the two tabs.
6. Pull out the barrels at each end.
7. Lower the arm rest, and press the normal release button to separate both halves, and you can pull off the top part which has the leather cover.
8. Remove each of the semi circular clips on each end.
9. Now you can remove the bottom, and the center console comes off really easily.
10. Finally, you can see from the photo the parking brake boot is just connected using a zip tie. Very easy to just cut this off and remove the boot completely. Stops having to feed the boot through the hole in the center console and consequent damage.
Obviously installation is the reverse.
Name:	01 remove ash tray.jpg
ID:	352172   Click image for larger version
Name:	2 push out centre panel.jpg
ID:	352173   Click image for larger version
Name:	03 remove centre panel.jpg
ID:	352174   Click image for larger version
Name:	04 push in tabs.jpg
Name:	05 pull out centre barrels.jpg
ID:	352176   Click image for larger version
Name:	06 pull off top.jpg
ID:	352177   Click image for larger version
Name:	07 pull off end clips.jpg
ID:	352178   Click image for larger version
Name:	08 pull off bottom.jpg
Name:	09 park brake boot.jpg
ID:	352180   Click image for larger version
Name:	02 remove springs.jpg
jjrichar is offline   Reply With Quote
Old 03-15-2010, 04:27 PM   #2
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
sweet!
I just did this as well over the weekend...but the pictures I did not have.
http://forum.e46fanatics.com/showthread.php?t=748066
I used a video:
Your pics are excellent and 100% backs me up when I tell people they DO NOT have to remove the entire console to change out the armrest upper lid/cup part.
PART ONE: Taking it apart
PART TWO: Putting it back together
delmarco is offline   Reply With Quote
Old 03-15-2010, 04:49 PM   #3
Art Bimmer
My Ride: 2004 E46 Coupe
Bump. Gotta order a new cover
Good job you guys
Art Bimmer is offline   Reply With Quote
Old 03-15-2010, 04:56 PM   #4
delmarco
Good job you guys
wow a 20 minute bump!
Old 03-15-2010, 05:05 PM   #5
Art Bimmer
Wonder how many jacked up console covers are out there?
Old 03-18-2010, 04:23 AM   #6
buddyclubinteg
My Ride: hates pot holes...
mines are jacked and so are all my buddies with e46. such a shame everything oem inside a e46 is tender. gonna remove the rubbish coating on my console, fine wet sand then spray matte clear coat on it this weekend. i've seen the finish, looks awesome and saves you $
buddyclubinteg is offline   Reply With Quote
Old 04-20-2011, 03:48 PM   #7
cmpcpro
My Ride: 2000 Mercedes S430
I just replaced my whole center console with a brand new one because the old one was peeling a little on the corner and it wasn't fitting with my theme of a perfect interior Anyway, I was all ready to tackle this to remove the center console but then I realized the piece slips off over the center console super easy and wasn't even close to rubbing or messing anything up if you do it right.. no need to do this.
cmpcpro is offline   Reply With Quote
Old 06-09-2013, 02:29 PM   #8
BonesXX
My Ride: Vert
Works Great !!!! Thanks so much for this write up. I did not need to remove my whole console just the arm rest portion to repair the broken outer ring ( JB Plastic Weld ). This made the job easy. Thanks again !!
BonesXX is offline   Reply With Quote
Old 08-31-2015, 04:36 PM   #9
CharlieFoxtrot
My Ride: 02 330Ci
Excellent post, thanks! The Bentley manual doesn't cover this.
A little thing I might add, if this is part of a larger project and if you have power seats and if your project requires disconnecting the battery, do this part first.
It's easier to get the armrest pivot barrels out if the seats aren't in the way. But they do come out even if the seats are in the way. Just easier if they aren't.
CharlieFoxtrot is offline   Reply With Quote
