Thread Tools Search this Thread Rating: Thread Rating: 34 votes, 5.00 average. Display Modes
Old 03-15-2010, 11:46 AM   #1
mvrk10256
My Ride: E30 325i
Thumbs Up MVRK's Interior Trim Cloth Wrap DIY
So sometimes you just get tired of the old interior trim. And that means you have to either replace it, paint it, wrap it in CF, or a fabric. Fabric lets you have something that is both unique and has texture.
DISCLAIMER: you fvck up its not on me.
Supplies:
3M Super 77
ScotchGuard
1 yard of fabric (2 if you are doing c pillars as well)
Tools:
Flathead and Phillips screwdriver
scissors - sharp and small is nice too.
several flat clean surfaces.
So first we need to do a test run.
TEST RUN:
1. cut a small piece of fabric
2. scotchgaurd it
3. stick it onto something you dont care about
4. let it dry
5. Visual inspection - is anything staining, does the glue make it look wrong, is it bleeding ect.....
6. try water test and the rub test, no pigment should come off on your hand.
so if everything is good we can move on to the wrap.
STEP A: Scotchgaurd everything
1. place the whole sheet of fabric on the floor or a large table
2. give it 3/4 light coats of gaurd
3. Let it dry
STEP B: Wrapping Trim pieces
1. Pull trim pieces
2. wash with soap and water, get all the armor all/finger oil and everything else off the pieces
3. take them to a table with fabric, cut a piece of fabric around the trip piece with plenty of spare room
4. take to a separate clean surface and place the trim, trim side up, spray it with super 77 from about 12 inches with quick strokes(basically same technique as spray paint)
5. take your strip and place it on the glue part
6. VERY IMPORTANT: immediately stretch/rub it smooth. make sure there are no bubble or wrinkles while the glue is still wet.
a. this is easy to do on all the pieces except the long curved one in front of the passenger. what you need to do here is cut a large piece and start from the left, go about 3 inches and make a cut from the edge of the fabric to about a centimeter away from the trim piece. this will allow the fabric to "bend" w/o causing bubbles.
b. The trick to corners is this. wrap like you would a present. so you get this triangular thing sticking up with fabric stuck to itself. then simply snip it off. that way there is a great perfect corner, but no material sticking up in the back.
7.now that you are all flush and even on the other side, flip the trim piece.
8. fold the fabric over and use the scissors to trim the fabric in such a way that it will only wrap around the edge a little,and doesn't get in the way of the pegs. When wrapping the shifter piece, you will need to cut to the corners of the holes for the switches and scissors. it is important that your wrap as close to the corners as possible to avoid bunching and so the switches fit.
9. spray the backside with super 77
10. wrap the trim around and let it stick to the back of the trim
11. look over your work and rewrap if necessary.
12. reinstall everything in the car and enjoy.
ID:	352197   Click image for larger version
ID:	352198   Click image for larger version
ID:	352199   Click image for larger version
ID:	352201   Click image for larger version
ID:	352202   Click image for larger version
ID:	352203   Click image for larger version
ID:	352205   Click image for larger version
ID:	352206   Click image for larger version
ID:	352207   Click image for larger version
Old 03-15-2010, 12:03 PM   #2
UNFORGIVEN
My Ride: Bagged Stang, 330CI
I don't really like that print, but that's what makes us all different.
Thanks for the DIY. You made it all so simple. Love the disclaimer.
...is rocking a new look!
Special thanks to Mr. AWD for the new sig...
UNFORGIVEN is offline   Reply With Quote
Old 03-15-2010, 12:17 PM   #3
mvrk10256
My Ride: E30 325i
unfortunatly my camera is POS, and it doesnt do the fabric justice.
It looks really excellent in person, kind of subdued and classy, but i was at a party last night, and i had to give some chicks a ride back to campus, and i got a few compliments
Old 03-15-2010, 12:17 PM   #4
Stew330i
My Ride: Size 12 shoes, Damn!
Send a message via AIM to Stew330i Send a message via Yahoo to Stew330i
Looks great good job!
Boys Do What They Can, Men Do What They Want
Stew330i is offline   Reply With Quote
Old 03-15-2010, 06:45 PM   #5
mvrk10256
My Ride: E30 325i
Old 03-15-2010, 10:05 PM   #6
miiikey31
My Ride: 00 BMW 323CI Coupe
are you doing your mom's car? jk
good diy
miiikey31 is offline   Reply With Quote
Old 03-15-2010, 10:09 PM   #7
Define ///M3
My Ride: E92
haha now you just need curtains and some plush pillows for the back seet and its already more luxurious then my house!
Define M3
tiag 2000 323ci - sold
BSM 2004 325ci - sold
AW 2013 328i - sold
MWM 2012 e92 328i - current
Looking 4 e46 M3
Define ///M3 is offline   Reply With Quote
Old 03-15-2010, 10:24 PM   #8
syl3ntforce
My Ride: E46 M3
Send a message via AIM to syl3ntforce
whats a good fabric to wrap the trim in everyone has cf so im tired of that look where can i find good fabric that wont bleed and that the pigments wont rub off on your hand?
thanks
very good DIY
-Paul
318i>328i>328i>EK Civic SI>328ci>328xi>E46 M3
syl3ntforce is offline   Reply With Quote
Old 03-16-2010, 01:46 AM   #9
mvrk10256
My Ride: E30 325i
good diy
what can i say. i is classy.
thanks
very good DIY
basically i test sprayed some flannel, and some linen. I would say the linen works best because you need a thin fabric. especially when wrapping the shifter trim. CF is gay, everyone has it, and while it looks ok its really not unique.. basically goto Joannes and buy the scotchgaurd and glue, and buy 6" strips of several fabric you like.
then simply spray them and glue them to a milk bottle or some plastic and see how it looks. i cant tell you one fabric will work best, just gotta experiment.
Old 03-18-2010, 07:28 AM   #10
Jmanscotch
My Ride: makes my pants tight
I'm liking your idea, a lot cheaper then replacing the trim, thanks!
My only concern would be that after a while I'd get tired of the look and want to change it up, does the 3M super 77 set up real solid or do you think you could peel off the fabric and use something like WD40, Goo Gone etc to remove the glue residue thus returning the trim to its previously appearance?
I might just have to try it on some scrap platic and give it a shot....
-Jake
2004 325CI - 2003 3.0 Z4 - 1994 325i - 1967 1602 - 2008 328XI - 2009 135i - 2007 Jeep Wrangler - 2014 *Loading*
Jmanscotch is offline   Reply With Quote
Old 03-18-2010, 01:11 PM   #11
mvrk10256
My Ride: E30 325i
It peels off pretty easily, however i do not know if you will be able to return it to the original finish, its possible but it would take quite a bit of goo gone and a lot of creditcard scraping.
my suggestion is if you get bored, wrap it in something else, or sand it and spray it.
Old 03-18-2010, 01:50 PM   #12
LehiZHP
My Ride: '03 330i ZHP
Tell me you're only kidding! What's next? Dingle balls and a furry kitty in the back window? Maybe a nice pastel floral print?
LehiZHP is offline   Reply With Quote
Old 03-18-2010, 01:53 PM   #13
mvrk10256
My Ride: E30 325i
yup pink faux fur, and big pink furry dice actually. The pictures dont really give it justice the black blends perfectly. took it out to a meet last night, and got tons of compliments.
Old 03-19-2010, 12:49 AM   #14
syl3ntforce
My Ride: E46 M3
thanks for the info i was searching joannes but i didnt like the print on the fabric im looking for something more abstract any other places you could recommend ? thanks
-Paul
Old 03-19-2010, 12:53 AM   #15
mvrk10256
My Ride: E30 325i
google maps your adress and search for fabric near you. There is a a place near me called fabric fabrique that had cool ****. mostly places that do dresses and stuff.
Old 03-19-2010, 01:45 AM   #16
kushy
My Ride: automatic m3
Love the way it turned out. Thumbs up!
kushy is offline   Reply With Quote
Old 03-19-2010, 02:02 AM   #17
mvrk10256
My Ride: E30 325i
thanks.
Old 03-20-2010, 08:01 PM   #18
Brilliant
My Ride: E46M3 Blk/Blk
What about a headliner to match?
Brilliant is offline   Reply With Quote
Old 03-20-2010, 08:52 PM   #19
mvrk10256
My Ride: E30 325i
maybe a bit much to do the whole headliner. May do the dome light/sensor thing between the front seats though.
Old 03-24-2010, 04:40 PM   #20
rEid46_323
My Ride: 2000 323i sedan
pull the fabric, sand off glue, put on new fabric
it looks b1tchin in person. its so subtle u might miss it at first. people get in and are like did the car come from the factory like this cuz your is sorta ballin.
that would be overkill.
i would
rEid46_323 is offline   Reply With Quote
cloth trim, cool, diy, e46, trim wrap
